After SSL - Hostname not verified
I was able to configure SSL with self signed certs
Mongo, Elastic, and Graylog on the same server
All inputs, alerts, etc… are working
BUT…
All my Inputs show NOT RUNNING
In the log I see…
2021-03-05T09:27:28.737-05:00 WARN [ProxiedResource] Unable to call https://…/api/system/inputstates on node <000>: Hostname host not verified:
certificate:
I’m not sure how to verify it.
I’ve tried several versions of the http_publish_uri in server.conf
https://host:9000
https://host.domain.com:9000
I’ve tried several versions of the http_bind_address in server.conf
hostname:9000
hostname.domain.com:9000
Thank you!
I’m thinking I messed up the cert some where.
certificate: sha256/
DN: CN= StorageXX, OU=XX, O=XX, L=XX, ST=XX, C=XX
subjectAltNames:
I edited some of that stuff out to obvuscate. But not the subjectAltNames: , that’s how it looks
and if I look at the cert in my browser, I don’t see any mention of my hostname
But when I look at the cert I’m using I see the info.
And something like this seems OK:
keytool -list -v -keystore keystore.jks
I feel like I am very close…
Thought I had it with a bad Common Name, but now it looks right and the issue persists:
Guess I’ll put this to bed for the week. I thought I had it again with
-Djavax.net.ssl.trustStore= and -Djavax.net.ssl.trustStorePassword=
needing to be set in the graylog-server file
I am using the default cacerts store with a new password
No luck
What are you using for your SAN names? I’ve configured ours for DNS=fqdn and IP=ip address of the host, and it works for the web interfaces and the inputs.
Subject:
CN = graylog.contoso.com
OU = IT
O = Awesome IT
L = Kansas City
S = Missouri
C = US
Subject Alternative Name:
DNS Name=graylog01
DNS Name=graylog01.contoso.com
IP Address=192.168.1.220
I have something that looks like this:
CN=graylog.domain.com
OU=Storage
O=Company
L=GR
ST=MI
C=US
subjectAltNames:
At what step in the instructions (Using HTTPS — Graylog 4.0.0 documentation) do you set the SANs on the cert?
It prompts me for all sorts of info, but I don’t see where I put SANs.
Thank you, Zach.
In the document you linked it’s in the request file under alt_names (the block under “Create a file named openssl-graylog.cnf with the following content (customized to your needs):”), but it can vary based on the CA/request you’re submitting. We use an AD enterprise CA and our request looks like this:
user@graylog01:/etc/graylog/certs/domain$ cat graylog01-cert-req.cnf
[ req ]
default_bits = 2048
default_keyfile = key.pem
distinguished_name = req_distinguished_name
encrypt_key = no
prompt = no
string_mask = nombstr
req_extensions = v3_req
[ v3_req ]
basicConstraints = CA:FALSE
keyUsage = digitalSignature, keyEncipherment
extendedKeyUsage = serverAuth
subjectAltName = DNS:graylog01, DNS:graylog01.contoso.com, DNS:192.168.1.220
[ req_distinguished_name ]
0.organizationName = Awesome IT
organizationalUnitName = IT
commonName = graylog01.contoso.com
countryName = US
stateOrProvinceName = Missouri
localityName = Kansas City
@dickinsonzach
I concur with @ttsandrew about having SAN, and this is a peak at my keystore for my lab certificate. Sorry I had to block my private info but you can see in the red box it shows what @ttsandrew was saying.
Since this was a lab VM I didn’t use a config file, I used my /etc/pki/tls/openssl.cnf file instead. I’m lazy :slight_smile: Shown below in red boxes is where i configured my SAN.
This is all very helpful. I have tried to detail my process here:
Generate a blank keystore.jks
keytool -genkey -keyalg RSA -validity 1095 -keystore keystore.jks
Create a cert using my req.txt which has my SANs in it
openssl req -x509 -days 1095 -nodes -newkey rsa:2048 -config req.txt -keyout pkcs5-plain.pem -out cert.pem
Import the cert into the blank keystore.jks
keytool -importcert -keystore keystore.jks -storepass mypassword -alias host.domain -file cert.pem
Check to see if the keystore alias looks good. It does complete with SANs
keytool -list -v -keystore keystore.jks -alias host.domain
Do some openssl work to get things in the right format
openssl pkcs8 -in pkcs5-plain.pem -topk8 -nocrypt -out pkcs8-plain.pem
openssl pkcs8 -in pkcs5-plain.pem -topk8 -v2 des3 -out pkcs8-encrypted.pem -passout pass:mypassword
Export keystore.jks to .p12 so openssl can work with it
keytool -importkeystore -srckeystore keystore.jks -destkeystore keystore.p12 -deststoretype PKCS12
More SSL work to generate certs in the right format
openssl pkcs12 -in keystore.p12 -nokeys -out graylog-certificate.pem
openssl pkcs12 -in keystore.p12 -nocerts -out graylog-pkcs5.pem
openssl pkcs8 -in graylog-pkcs5.pem -topk8 -out graylog-key.pem
Import keystore.jks into the default cacerts store so I don’t have to mess with Java arguments
keytool -import -trustcacerts -file graylog-certificate.pem -alias host.domain -keystore /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.272.b10-3.el8_3.x86_64/jre/lib/security/cacerts
Check to see if the alias looks correct in the default cacerts. It does complete with SANs
keytool -list -v -keystore /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.272.b10-3.el8_3.x86_64/jre/lib/security/cacerts -alias host.domain
Give the graylog user rights to all the files where the install is and I’ve been doing the cert work
chown graylog:graylog -R /etc/graylog
Reboot server and check the log
/etc/graylog/server/server.conf
http_bind_address = host.domain:9000
http_enable_tls = true
http_tls_cert_file = /etc/graylog/graylog-certificate.pem
http_tls_key_file = /etc/graylog/graylog-key.pem
Everything looks fine in the log. Last message is that all my inputs are running, but the Web UI is un-reachable. Browser says: ERR_SSL_KEY_USAGE_INCOMPATIBLE
https://docs.graylog.org/en/4.0/pages/configuration/https.html
The part I’m struggling with is that we generate a cert.pem from a request file, and the next work with it is when we import it into the copied cacerts file
keytool -importcert -keystore /path/to/cacerts.jks -storepass changeit -alias graylog-self-signed -file cert.pem
I see how that will get the cert, including the SANs, into the copied cacerts file.
BUT the whole middle part has us starting with keystore.jks, exporting that as .p12, so we can work with it and eventually end up with the cert and key file to use in the Graylog config.
Where does that keystore.jks file com from and how do we get the SANs/cert from the request in there?
Thank you, Zach,.
@dickinsonzach
Sorry for the delay, I had work over the weekend.
Correct me if im wrong, but I believe this issue is related to the value of the ‘KeyUsage’ parameter in the SSL config of ‘v3_req’.
My problem might be a little different but I solved this by changing keyUsage = keyEncipherment, dataEncipherment to keyUsage = nonRepudiation, digitalSignature, keyEncipherment in the section v3_req in file openssl-graylog.cnf. This means you might have to recreate your certs again.
[req]
x509_extensions = v3_req
prompt = no
# Details about the issuer of the certificate
[req_distinguished_name]
C = US
ST = Some-State
L = Some-City
O = My Company
OU = My Division
CN = graylog.example.com
[v3_req]
keyUsage = keyEncipherment, dataEncipherment, **nonRepudiation**
subjectAltName = @alt_names
# IP addresses and DNS names the certificate should include
# Use IP.### for IP addresses and DNS.### for DNS names,
# with "###" being a consecutive number.
[alt_names]
IP.1 = 203.0.113.42
DNS.1 = graylog.example.com
I belive you generate it here:
If you need to add more certs to the keystore you can always use keytool to import it.
keytool -import -trustcacerts -file some_file.pem -alias dns.name.of.server -keystore keystore.jks
Thank you to the community with a special shout out to @gsmith
In the end I ended up doing the following. It seems the documentation is a general guide to ALL the ways in which you can secure Graylog with SSL/TLS/Cert. In the end, all I wanted to do was use a self cert in the default Java Keystore.
Create a cert from a config file. I did have to use keyUsage = nonRepudiation, digitalSignature, keyEncipherment as suggested by @gsmith to get it to work with Chrome and not disable TLS 1.3 I made mine valid for 3 years
openssl req -x509 -days 1095 -nodes -newkey rsa:2048 -config openssl-graylog.cnf -keyout pkcs5-plain.pem -out cert.pem
Convert the pkcs5 to pkcs8
Create an encrypted version of the pkcs8
openssl pkcs8 -in pkcs5-plain.pem -topk8 -out pkcs8-encrypted.pem -passout pass:changeit
Make sure my entry was not already in the keystore
keytool -list -v -keystore /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.272.b10-3.el8_3.x86_64/jre/lib/security/cacerts -alias host.domain -storepass changeit
It was because of previous work, so delete it
keytool -delete -keystore /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.272.b10-3.el8_3.x86_64/jre/lib/security/cacerts -alias host.domain -storepass changeit
Import the cert.pem created above into the keystore
keytool -importcert -keystore /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.272.b10-3.el8_3.x86_64/jre/lib/security/cacerts -storepass changeit -alias host.domain -file cert.pem
Verify the new cert is in the keystore
Clean up all my other cert stuff that didn’t work
rm /etc/graylog/.
Copy the new certs from where I had been working to where I want my certs
cp /tmp/zach/. /etc/graylog
Give the graylog user ownership of all the certs. Otherwise you get a cannot verify private key error because Graylog cannot access the files
Edit the graylog server config
http_tls_cert_file = /etc/graylog/cert.pem
http_tls_key_file = /etc/graylog/pkcs8-encrypted.pem
http_tls_key_password = changeit
Add the path and password to the default Java Keystore. You don’t have to do this if you don’t change the password. I had, but obfuscate in this post
/etc/sysconfig/graylog-server GRAYLOG_SERVER_JAVA_OPTS=
-Djavax.net.ssl.trustStore=/usr/lib/jvm/java-1.8.0-openjdk-1.8.0.272.b10-3.el8_3.x86_64/jre/lib/security/cacerts -Djavax.net.ssl.trustStorePassword=changeit
Restart the Graylog server
systemctl restart graylog-server
Watch the logs
At this point SSL on the website, all APIs, TLS 1.3, and Chrome are working. Now to see I can get an Input to use it :slight_smile: See you back in the forums, Zach.
@dickinsonzach
Nice, seams like your getting closer.
FYI:
Be careful when updating java on your server, that path might change on you.
