I am using SSL to access the web GUI and with my server inputs. I am using the server hostname (not IP) as http_bind_address
When I changed http_bind_address to be an IP, the GUI was no longer accessible, so that is why I had to add make http_bind_address be my server name instead since that is what my certificate has.
My inputs won’t start though. Everything was working before upgrade to 3.0. Previous version was 2.3. Interestingly, all my inputs say ‘NOT RUNNING’ but they are showing current messages being received.
I am seeing the below error…
2019-07-03T14:16:26.370-04:00 WARN [ProxiedResource] Unable to call https://SERVERNAME:9000/api/system/metrics/multiple on node
javax.net.ssl.SSLPeerUnverifiedException: Hostname SERVERNAME not verified:
certificate: sha256/bdxK4kLkJbrgVFqmHTezY3VUz5PGW8iGnX2T/uGo7J4=
DN: EMAILADDRESS=xx@xx.net, CN=SERVERNAME, OU=Technology Dept, O=XX, L=XX, ST=XX, C=XX
subjectAltNames:
at okhttp3.internal.connection.RealConnection.connectTls(RealConnection.java:329) ~[graylog.jar:?]
at okhttp3.internal.connection.RealConnection.establishProtocol(RealConnection.java:282) ~[graylog.jar:?]
at okhttp3.internal.connection.RealConnection.connect(RealConnection.java:167) ~[graylog.jar:?]
at okhttp3.internal.connection.StreamAllocation.findConnection(StreamAllocation.java:257) ~[graylog.jar:?]
at okhttp3.internal.connection.StreamAllocation.findHealthyConnection(StreamAllocation.java:135) ~[graylog.jar:?]
at okhttp3.internal.connection.StreamAllocation.newStream(StreamAllocation.java:114) ~[graylog.jar:?]
at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:42) ~[graylog.jar:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:147) ~[graylog.jar:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:121) ~[graylog.jar:?]
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:126) ~[graylog.jar:?]
at org.graylog2.rest.RemoteInterfaceProvider.lambda$get$0(RemoteInterfaceProvider.java:61) ~[graylog.jar:?]
at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:200) ~[graylog.jar:?]
at okhttp3.RealCall.execute(RealCall.java:77) ~[graylog.jar:?]
at org.graylog2.shared.rest.resources.ProxiedResource.lambda$getForAllNodes$0(ProxiedResource.java:78) ~[graylog.jar:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_131]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:1.8.0_131]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:1.8.0_131]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_131]
I did read it… Would you please clarify what you think I am possibly missing?
Under 2.3 I used the server host name (not IP) for SSL connections and everything worked fine… I did not see anything in the notes that would account for why I am seeing the errors above.
When I made http_bind an IP address, then I could no longer access Graylog in my web browser. This is not good.
The network interface used by the Graylog HTTP interface.
This network interface must be accessible by all Graylog nodes in the cluster and by all clients using the Graylog web interface.
If the port is omitted, Graylog will use port 9000 by default.
http_publish_uri = http://$http_bind_address/
The HTTP URI of this Graylog node which is used to communicate with the other Graylog nodes in the cluster and by all clients using the Graylog web interface.
The URI will be published in the cluster discovery APIs, so that other Graylog nodes will be able to find and connect to this Graylog node.
This configuration setting has to be used if this Graylog node is available on another network interface than $http_bind_address, for example if the machine has multiple network interfaces or is behind a NAT gateway.
This configuration setting must not be configured to a wildcard address!
If http_bind_address contains a wildcard IPv4 address (0.0.0.0), http_publish_uri will be filled with the first non-loopback IPv4 address of this machine instead.
http_external_uri = $http_publish_uri
The public URI of Graylog which will be used by the Graylog web interface to communicate with the Graylog REST API.
The external Graylog URI usually has to be specified, if Graylog is running behind a reverse proxy or load-balancer and it will be used to generate URLs addressing entities in the Graylog REST API (see $http_bind_address).
When using Graylog Collector, this URI will be used to receive heartbeat messages and must be accessible for all collectors.
This setting can be overriden on a per-request basis with the “X-Graylog-Server-URL” HTTP request header.
For your Setup:
leave all others default and it should work. But with no additional information about the setup that is impossible to say.
I tried that. 0.0.0.0:9000… I am still receiving the same certificate error except now it is for the IP address instead of the server name as above…
Basically it’s saying Hostname 10.X.X.X not verified
Earlier when I used the server name as the hostname it was still saying host is not verified though my cert uses server name instead of IP address. Either way, IP or server name, I keep getting the below error since upgrade.
2019-07-04T08:22:06.450-04:00 WARN [ProxiedResource] Unable to call https://10.X.X.X:9000/api/system/metrics/multiple on node
javax.net.ssl.SSLPeerUnverifiedException: Hostname 10.X.X.X not verified:
DN: EMAILADDRESS=admin@xx.net, CN=SERVERNAME, OU=Technology Dept, O=XX , L=XX, ST=XX, C=US
subjectAltNames:
Yes I know… I did all that and it was all working when I was on 2.3. I upgraded from 2.3 to 3.0. I see no reason why a simple upgrade should stop my JVM cert from working anymore is baffling to me.
I actually saw another thread that is now closed that spoke about the issue but does not appear to ever been resolved. One person created a SAN but the other person didn’t receive an answer so I know I am not the only person who had experienced their JVM cert no longer being accepted.
I guess what I want to know is was there some significant change between 2.3 and 3.0 that would break a previously working cert that was working fine before in the JVM?
This is not like the first time I am setting this up. It was working fine and then broke. So far I don’t see any reason why a previously working config and cert broke. Unless you know of some change that would cause it to break.
You need to adjust the configuration settings from rest_* and web_* to http_* that might result in different hostname/ip usage. As Graylog checks the certificates and connects to itself via the API - so verifying the self used certificate it might not accept its own certificate.
Starting one input is a connection to the API - if that is refused based on bad certificates, the input will not be started.
OK, I finally figured it out. I was using SAN but I misconfigured the IP part. I have never had to use a SAN cert before. So here are some of my settings for anyone else reading this in the future to maybe save some time. The below is for a self-signed cert on Centos 7.
