After Securing Graylog with TLS no access to logdata anymore
After enabling TLS as described at How-To Guide: Securing Graylog with TLS I’m able to log in and navigate through the UI. But I don’t have access to the log data. The message “Updating log data” appears.
  • OS Information:
    Ubuntu 22.04.5 LTS
  • Package Version:
    Graylog 6.1.3-1
    Graylog-datanode 6.1.3
    MongoDB 7.0.15
tail /var/log/graylog-server/server.log
2024-11-26T07:57:59.270Z INFO  InputStateListener Input [GELF UDP/GELF UDP | Windows Events | Domain Computers/673ef639412a2b2c68e0c2bd] is now RUNNING
2024-11-26T07:58:01.766Z WARN  ProxiedResource Failed to call API on node <9e429e13-6e85-4d39-a6cc-a6be9fd5a696>, cause: Failed to connect to ift-sl040/127.0.1.1:80 (duration: 16 ms)
2024-11-26T07:58:03.739Z WARN  ProxiedResource Failed to call API on node <9e429e13-6e85-4d39-a6cc-a6be9fd5a696>, cause: Failed to connect to ift-sl040/127.0.1.1:80 (duration: 4 ms)
2024-11-26T07:58:05.739Z WARN  ProxiedResource Failed to call API on node <9e429e13-6e85-4d39-a6cc-a6be9fd5a696>, cause: Failed to connect to ift-sl040/127.0.1.1:80 (duration: 4 ms)
2024-11-26T07:58:07.743Z WARN  ProxiedResource Failed to call API on node <9e429e13-6e85-4d39-a6cc-a6be9fd5a696>, cause: Failed to connect to ift-sl040/127.0.1.1:80 (duration: 3 ms)
2024-11-26T07:58:09.734Z WARN  ProxiedResource Failed to call API on node <9e429e13-6e85-4d39-a6cc-a6be9fd5a696>, cause: Failed to connect to ift-sl040/127.0.1.1:80 (duration: 1 ms)
2024-11-26T07:58:11.737Z WARN  ProxiedResource Failed to call API on node <9e429e13-6e85-4d39-a6cc-a6be9fd5a696>, cause: Failed to connect to ift-sl040/127.0.1.1:80 (duration: 2 ms)
2024-11-26T07:58:13.727Z WARN  ProxiedResource Failed to call API on node <9e429e13-6e85-4d39-a6cc-a6be9fd5a696>, cause: Failed to connect to ift-sl040/127.0.1.1:80 (duration: 1 ms)
server.conf
is_leader = true
password_secret =HS08cEQzvukdFQL-uNfdztxSe8AT-Ki1CGrfSS3DPdhw9E1ABDChfjyHt6eTRyyqwK0-Ox22XDFIeKUdf9iHcj1ZPuXbA4be6
root_password_sha2 =c13c9e222657bc5907fbd687dfb39fe6dfb757b86b44d67cdfc8ff7814238de9
http_bind_address = 10.77.33.86:443
http_publish_uri = http://host123/
http_enable_tls = true
http_tls_cert_file = /opt/graylog/tls/public.pem
http_tls_key_file = /opt/graylog/tls/private.key
http_tls_key_password = myPassW0rd
disabled_retention_strategies = none,close
allow_highlighting = false
field_value_suggestion_mode = on
output_batch_size = 500
output_flush_interval = 1
ring_size = 65536
inputbuffer_ring_size = 65536
transport_email_hostname = company-de0i.mail.protection.outlook.com
transport_email_port = 25
transport_email_from_email = it@domain.de
transport_email_socket_connection_timeout = 10s
transport_email_socket_timeout = 10s
transport_email_use_tls = true
transport_email_web_interface_url = https : //graylog.example.com
integrations_scripts_dir = /usr/share/graylog-server/scripts
Everything I found with google.
Maybe someone has an idea what else I could try.
Kind regards
Sven
Is your publish_uri in server.conf http:// , thats most likely your problem, publish uri is what it uses to call the api, even when its calling it itself. Second most common reason is that it doesnt trust its own cert to call the api, but i think the error for that one is different.
As a test, I changed the value of “http_publish_uri” to https://ift-sl040/, but this does not change the behavior.
Another installation with Graylog 6.0.x works perfectly with the same configuration (server.conf). But I installed this installation with opensearch v2.18.0 by mistake. This worked until Graylog v6.0.7, but an upgrade to Graylog v6.1 crashed the system. But that is another topic.
I have imported the required Import Root and Intermediate certificates into the Java Key Store (JKS). So this should not be the problem. Otherwise, HTTPS access to the UI would probably not work either.
I suspect that something fundamental has changed from v6.0.x to v6.1.x.
With the following server.conf the access to the log files works now:
is_leader = true
http_publish_uri = https://host123.intra.company.com:443/
ring_size = 65536
It is important that the web interface is then accessed via https://host123.intra.company.com:443/. Otherwise, when the API browser is viewed, it is called up via the IP and a new password request is made.
Ya I see it now, your publish uri needs to match exactly how it would comunicate to the API so it needed the https and the port. Think of it as if you needed to send the link to someone, it needs to be everything because it’s not infering port etc from anywhere else just what is in that config line.
