I just explored pipelines
to add fieldnames to a csv data
Below rule works fine:
rule "add_field" when has_field("message") then let m = split(",", to_string($message.message)); set_field("field1A", m[0]); set_field("field1B", m[1]); end
But if I had say 100 fields, then setting for each index will be very time consuming.
Is there a better way to get this done by another technique?
Please suggest.
