About MongoDB profiler
Hi guys,
Did anyone config mongodb profiler plugin success?Can show me the options in Mongodb Profiler Input?
Thanks.
I met the same problem as I wanna monitor a mongodb shard cluster through Graylog. I installed Graylog,elastisearch and jdk on CentOS, then I downloaded the mognodb plug-in to drop it in the plug-ins directory. Now I can access the web console and configure some inputs of MongoDB, but it cannot receive msg from Mongo Server.
I wanna know how it actually works for mongodb monitoring and how to configure it correctly.
NEED HELP.:wink:
