502 message/mongodb not running
I am trying to install one graylog node and elasticsearch nodes on ubuntu 16.04 using ansible. even though the playbook is fully working, when I call my web-uri I get a 502 nginx message. Also I checked graylog logs and here is the output.
2017-08-03T10:28:20.221+02:00 INFO  [CmdLineTool] Loaded plugin: Elastic Beats Input 2.2.3 [org.graylog.plugins.beats.BeatsInputPlugin]
2017-08-03T10:28:20.223+02:00 INFO  [CmdLineTool] Loaded plugin: Collector 2.2.3 [org.graylog.plugins.collector.CollectorPlugin]
2017-08-03T10:28:20.223+02:00 INFO  [CmdLineTool] Loaded plugin: Enterprise Integration Plugin 2.2.3 [org.graylog.plugins.enterprise_integration.EnterpriseIntegrationPlugin]
2017-08-03T10:28:20.224+02:00 INFO  [CmdLineTool] Loaded plugin: MapWidgetPlugin 2.2.3 [org.graylog.plugins.map.MapWidgetPlugin]
2017-08-03T10:28:20.232+02:00 INFO  [CmdLineTool] Loaded plugin: Pipeline Processor Plugin 2.2.3 [org.graylog.plugins.pipelineprocessor.ProcessorPlugin]
2017-08-03T10:28:20.233+02:00 INFO  [CmdLineTool] Loaded plugin: Anonymous Usage Statistics 2.2.3 [org.graylog.plugins.usagestatistics.UsageStatsPlugin]
2017-08-03T10:28:20.567+02:00 INFO  [CmdLineTool] Running with JVM arguments: -Djava.net.preferIPv4Stack=true -Xms1500m -Xmx1500m -XX:NewRatio=1 -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:+UseParNewGC -XX:-OmitStackTraceInFastThrow -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=deb
2017-08-03T10:28:20.789+02:00 INFO  [Version] HV000001: Hibernate Validator null
2017-08-03T10:28:26.438+02:00 INFO  [InputBufferImpl] Message journal is enabled.
2017-08-03T10:28:26.590+02:00 INFO  [NodeId] Node ID: e591a5c0-4d64-47d7-99be-64a96550ad5c
2017-08-03T10:28:27.611+02:00 INFO  [LogManager] Loading logs.
2017-08-03T10:28:27.618+02:00 INFO  [LogManager] Logs loading complete.
2017-08-03T10:28:27.658+02:00 INFO  [LogManager] Created log for partition [messagejournal,0] in /var/lib/graylog-server/journal with properties {file.delete.delay.ms -> 60000, compact -> false, max.message.bytes -> 104857600, min.insync.replicas -> 1, segment.jitter.ms -> 0, index.interval.bytes -> 4096, min.cleanable.dirty.ratio -> 0.5, unclean.leader.election.enable -> true, retention.bytes -> 5368709120, delete.retention.ms -> 86400000, flush.ms -> 60000, segment.bytes -> 104857600, segment.ms -> 3600000, retention.ms -> 43200000, flush.messages -> 1000000, segment.index.bytes -> 1048576}.
2017-08-03T10:28:27.658+02:00 INFO  [KafkaJournal] Initialized Kafka based journal at /var/lib/graylog-server/journal
2017-08-03T10:28:27.772+02:00 INFO  [InputBufferImpl] Initialized InputBufferImpl with ring size <65536> and wait strategy <BlockingWaitStrategy>, running 2 parallel message handlers.
2017-08-03T10:28:27.831+02:00 INFO  [cluster] Cluster created with settings {hosts=[127.0.0.1:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout='30000 ms', maxWaitQueueSize=500}
2017-08-03T10:28:27.929+02:00 INFO  [cluster] Exception in monitor thread while connecting to server 127.0.0.1:27017
com.mongodb.MongoSocketOpenException: Exception opening socket
	at com.mongodb.connection.SocketStream.open(SocketStream.java:63) ~[graylog.jar:?]
	at com.mongodb.connection.InternalStreamConnection.open(InternalStreamConnection.java:115) ~[graylog.jar:?]
	at com.mongodb.connection.DefaultServerMonitor$ServerMonitorRunnable.run(DefaultServerMonitor.java:113) [graylog.jar:?]
	at java.lang.Thread.run(Thread.java:748) [?:1.8.0_144]
Caused by: java.net.ConnectException: Connection refused (Connection refused)
	at java.net.PlainSocketImpl.socketConnect(Native Method) ~[?:1.8.0_144]
	at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) ~[?:1.8.0_144]
	at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) ~[?:1.8.0_144]
	at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) ~[?:1.8.0_144]
	at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) ~[?:1.8.0_144]
	at java.net.Socket.connect(Socket.java:589) ~[?:1.8.0_144]
	at com.mongodb.connection.SocketStreamHelper.initialize(SocketStreamHelper.java:57) ~[graylog.jar:?]
	at com.mongodb.connection.SocketStream.open(SocketStream.java:58) ~[graylog.jar:?]
	... 3 more
2017-08-03T10:28:27.972+02:00 INFO  [cluster] No server chosen by ReadPreferenceServerSelector{readPreference=primary} from cluster description ClusterDescription{type=UNKNOWN, connectionMode=SINGLE, serverDescriptions=[ServerDescription{address=127.0.0.1:27017, type=UNKNOWN, state=CONNECTING}]}. Waiting for 30000 ms before timing out
2017-08-03T10:28:46.038+02:00 INFO  [CmdLineTool] Loaded plugin: Elastic Beats Input 2.2.3 [org.graylog.plugins.beats.BeatsInputPlugin]
2017-08-03T10:28:46.040+02:00 INFO  [CmdLineTool] Loaded plugin: Collector 2.2.3 [org.graylog.plugins.collector.CollectorPlugin]
2017-08-03T10:28:46.041+02:00 INFO  [CmdLineTool] Loaded plugin: Enterprise Integration Plugin 2.2.3 [org.graylog.plugins.enterprise_integration.EnterpriseIntegrationPlugin]
2017-08-03T10:28:46.041+02:00 INFO  [CmdLineTool] Loaded plugin: MapWidgetPlugin 2.2.3 [org.graylog.plugins.map.MapWidgetPlugin]
2017-08-03T10:28:46.049+02:00 INFO  [CmdLineTool] Loaded plugin: Pipeline Processor Plugin 2.2.3 [org.graylog.plugins.pipelineprocessor.ProcessorPlugin]
2017-08-03T10:28:46.050+02:00 INFO  [CmdLineTool] Loaded plugin: Anonymous Usage Statistics 2.2.3 [org.graylog.plugins.usagestatistics.UsageStatsPlugin]
2017-08-03T10:28:46.305+02:00 INFO  [CmdLineTool] Running with JVM arguments: -Djava.net.preferIPv4Stack=true -Xms1500m -Xmx1500m -XX:NewRatio=1 -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:+UseParNewGC -XX:-OmitStackTraceInFastThrow -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=deb
2017-08-03T10:28:46.547+02:00 INFO  [Version] HV000001: Hibernate Validator null
2017-08-03T10:28:48.693+02:00 INFO  [InputBufferImpl] Message journal is enabled.
2017-08-03T10:28:48.716+02:00 INFO  [NodeId] Node ID: e591a5c0-4d64-47d7-99be-64a96550ad5c
2017-08-03T10:28:48.920+02:00 INFO  [LogManager] Loading logs.
2017-08-03T10:28:48.950+02:00 WARN  [Log] Found a corrupted index file, /var/lib/graylog-server/journal/messagejournal-0/00000000000000000000.index, deleting and rebuilding index...
2017-08-03T10:28:48.976+02:00 INFO  [LogManager] Logs loading complete.
2017-08-03T10:28:48.976+02:00 INFO  [KafkaJournal] Initialized Kafka based journal at /var/lib/graylog-server/journal
2017-08-03T10:28:48.995+02:00 INFO  [InputBufferImpl] Initialized InputBufferImpl with ring size <65536> and wait strategy <BlockingWaitStrategy>, running 2 parallel message handlers.
2017-08-03T10:28:49.016+02:00 INFO  [cluster] Cluster created with settings {hosts=[127.0.0.1:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout='30000 ms', maxWaitQueueSize=500}
2017-08-03T10:28:49.073+02:00 INFO  [cluster] No server chosen by ReadPreferenceServerSelector{readPreference=primary} from cluster description ClusterDescription{type=UNKNOWN, connectionMode=SINGLE, serverDescriptions=[ServerDescription{address=127.0.0.1:27017, type=UNKNOWN, state=CONNECTING}]}. Waiting for 30000 ms before timing out
2017-08-03T10:28:49.081+02:00 INFO  [cluster] Exception in monitor thread while connecting to server 127.0.0.1:27017
	... 3 more
2017-08-03T10:29:19.074+02:00 ERROR [MongoConnectionProvider] Error connecting to MongoDB: Timed out after 30000 ms while waiting for a server that matches ReadPreferenceServerSelector{readPreference=primary}. Client view of cluster state is {type=UNKNOWN, servers=[{address=127.0.0.1:27017, type=UNKNOWN, state=CONNECTING, exception={com.mongodb.MongoSocketOpenException: Exception opening socket}, caused by {java.net.ConnectException: Connection refused (Connection refused)}}]
2017-08-03T10:29:19.324+02:00 INFO  [cluster] No server chosen by WritableServerSelector from cluster description ClusterDescription{type=UNKNOWN, connectionMode=SINGLE, serverDescriptions=[ServerDescription{address=127.0.0.1:27017, type=UNKNOWN, state=CONNECTING, exception={com.mongodb.MongoSocketOpenException: Exception opening socket}, caused by {java.net.ConnectException: Connection refused (Connection refused)}}]}. Waiting for 30000 ms before timing out
Here is my playbook:
- name: Dummy play to force gathering facts on all hosts
  hosts: all
  tasks: []
- name: Deploy elasticsearch primary node
  hosts: elasticsearch-primary
  become: yes
  roles:
    - role: elastic.elasticsearch
      es_instance_name: "{{inventory_hostname}}"
      es_config:
        node.name: "{{inventory_hostname}}"
        cluster.name: graylog
        discovery.zen.ping.multicast.enabled: false
        discovery.zen.ping.unicast.hosts: "{{ lookup('template', 'elasticsearch-hosts.json.j2') }}"
        http.port: 9200
        transport.tcp.port: 9300
        network.host: "{{ansible_default_ipv4.address}}"
        node.data: true
        node.master: tru
        bootstrap.mlockall: true
  vars:
    es_major_version: "2.x"
    es_scripts: false
    es_templates: false
    es_version_lock: false
    es_heap_size: 512m
  tasks:
    - name: Open necessary ports for elasticsearch (master node)
      ufw: from="{{ item.0 }}" port="{{ item.1 }}" rule=allow
      with_nested:
        - "{{ lookup('template', 'elasticsearch-nodes.yaml.j2', convert_data=True) | from_yaml }}"
        - [9300, 9200]
- name: Deploy Elasticsearch data nodes
  hosts: elasticsearch-nodes
  become: yes
  roles:
      es_config:
        discovery.zen.ping.unicast.hosts: ["{{hostvars['elasticsearch-primary'].ansible_default_ipv4.address}}:9300"]
        http.port: 9201
        transport.tcp.port: 9301
        node.data: true
        node.master: false
  vars:
    es_scripts: false
    es_templates: false
    es_heap_size: 1g
  tasks:
    - name: Open necessary ports for elasticsearch (data nodes)
      ufw: from="{{hostvars['elasticsearch-primary'].ansible_default_ipv4.address}}" port="{{ item }}" rule=allow
      with_items:
        - 9301
        - 9201
- name: Set up SSL certificates
  hosts: graylog-primary,graylog-nodes
  vars_files:
    - "vars/main.yml"
    - "vars/secret.yml"
 tasks:
 - name: Ensure OpenSSL is installed
   package: name=openssl state=present
   become: yes
- name: Ensure ssl folder exist
  file:
     path: "{{ ssl_certs_path }}"
     state: directory
     owner: "{{ ssl_certs_path_owner }}"
     group: "{{ ssl_certs_path_group }}"
     mode: "{{ ssl_certs_dir_mode }}"
     become: yes
- name: Copy SSL certificate data
   copy:
        content: "{{ item.content }}"
        dest: "{{ item.dest }}"
        mode: "{{ ssl_certs_file_mode }}"
   with_items:
      - { content: "{{ ssl_certs_local_certificate_data|default }}", dest: "{{ ssl_certs_certificate_path }}" }
      - { content: "{{ ssl_certs_local_privkey_data|default }}", dest: "{{ ssl_certs_privkey_path }}" }
#    - { content: "{{ ssl_certs_password|default }}", dest: "{{ ssl_certs_password_file_path }}" }
   no_log: true
   become: yes
- name: Generate strong DHE parameter - https://weakdh.org/
  command: openssl dhparam -out {{ssl_certs_dhparam_path}} {{ssl_certs_dhparam_size}} creates={{ssl_certs_dhparam_path}}
  become: yes
- name: Deploy graylog2 nodes
  vars_files:
    - "vars/main.yml"
    - "vars/secret.yml"
  become: yes
vars:
    # We installed elasticsearch ourselves
    graylog_install_elasticsearch: false
    # Basic server settings
    # Optional: Specify which Graylog version should be installed. Defaults to latest
    # graylog_server_version = '2.2.2-1'
    # Used for certain jobs that should only run on one server
    graylog_is_master: "{{ hostvars[inventory_hostname]['graylog_master'] | default('false') }}"
    # A secret that graylog uses for salting its password hashes. Generate with `pwgen -s 96 1`
    # graylog_password_secret: "{{graylog_password_secret}}"
    # A SHA2 hash of a password you will use for your initial login.
    # Create a password hash using: echo -n yourpassword | shasum -a 256
    # graylog_root_password_sha2: "{{graylog_root_password_sha2}}"
    graylog_elasticsearch_network_host: "{{ansible_default_ipv4.address}}"
    graylog_elasticsearch_discovery_zen_ping_unicast_hosts: "{{hostvars['elasticsearch-primary'].ansible_default_ipv4.address}}:9300"
    graylog_elasticsearch_cluster_name: 'graylog'
    # The web interface and the rest api should be accessable by the web browser
    graylog_web_listen_uri: "http://{{ansible_default_ipv4.address}}:9000"
    # This tells the browser how to connect to the Graylog API
    graylog_web_endpoint_uri: "http://{{ansible_default_ipv4.address}}:12900"
    # graylog_web_enable_tls: true
    # graylog_web_tls_key_file: "{{ssl_certs_privkey_path}}"
    # graylog_web_tls_cert_file: "{{ssl_certs_certificate_path}}"
    # graylog_web_tls_key_password: "{{ssl_certs_password}}"
    # REST API config
    graylog_rest_listen_uri: "http://{{ansible_default_ipv4.address}}:12900"
    graylog_rest_transport_uri: "http://{{ansible_default_ipv4.address}}:12900"
    # graylog_rest_enable_tls: true
    # graylog_rest_tls_key_file: "{{ssl_certs_privkey_path}}"
    # graylog_rest_tls_cert_file: "{{ssl_certs_certificate_path}}"
    # graylog_rest_tls_key_password: "{{ssl_certs_password}}"
nginx_sites:
      default:
        - listen 80
        - listen 443 ssl default_server
        - server_name server.example.org
        - sub_filter_once     off
        - sub_filter_types    *
        - sub_filter          'http://{{ansible_default_ipv4.address}}:12900' 'https://server.example.org/api'
        - sub_filter          'http://{{ansible_default_ipv4.address}}:9000' 'https://server.example.org'
        - location /api/ {
          proxy_set_header    X-Forwarded-For $proxy_add_x_forwarded_for;
          proxy_set_header    Host $http_host;
          proxy_set_header    Accept-Encoding "";
          rewrite ^/api(.*)$  $1 break;
          proxy_redirect      http://{{ansible_default_ipv4.address}}:12900 https://server.example.org/api;
          proxy_pass          http://{{ansible_default_ipv4.address}}:12900; }
        - location / {
          proxy_redirect      http://{{ansible_default_ipv4.address}}:9000 https://server.example.org;
          proxy_pass          http://{{ansible_default_ipv4.address}}:9000; }
      graylog: []
  nginx_configs:
      ssl:
         - "ssl_certificate      {{ssl_certs_certificate_path}}"
         - "ssl_certificate_key  {{ssl_certs_privkey_path}}"
#       - "ssl_password_file    {{ssl_certs_password_file_path}}"
         - "ssl_dhparam          {{ssl_certs_dhparam_path}}"
         - "ssl_session_cache    shared:SSL:10m"
         - "ssl_session_timeout  5m"
         - "ssl_protocols        TLSv1 TLSv1.1 TLSv1.2"
         - "ssl_ciphers          'EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH'"
         - "ssl_prefer_server_ciphers on"
  roles:
    - role: 'Graylog2.graylog-ansible-role'
      tags:
        - graylog
        - graylog2_servers
    - role: geerlingguy.java
      when: ansible_distribution_release == 'xenial'
      java_packages:
        - openjdk-8-jdk
      tags:
        - elasticsearch
        - graylog
        - graylog2_servers
  tasks:
    - name: Create filter.d directory
      file: path=/etc/fail2ban/filter.d/ state=directory mode=0755
    - name: Create jail.d directory
      file: path=/etc/fail2ban/jail.d/ state=directory mode=0755
    - name: Deploy fail2ban config for nginx/Graylog proxy_pass
      template: src="{{ item.src }}" dest="{{ item.dest }}"
      notify: Restart fail2ban
      with_items:
        - { src: 'fail2ban-filter.conf.j2', dest: '/etc/fail2ban/filter.d/nginx-graylog-auth-fail.conf' }
        - { src: 'fail2ban-jail.conf.j2', dest: '/etc/fail2ban/jail.d/nginx-graylog-auth-fail.conf' }
    - name: Open necessary ports for graylog
      with_nested:
        - "{{ lookup('template', 'elasticsearch-ips.yaml.j2', convert_data=True) | from_yaml }}"
        - [9350]
    - name: Open port for graylog from the office & server IP
      with_nested:
        - [9350]
      with_nested:
        - ["ip1", "ip2"]
        - ["9000", "12900"]
    - name: Open ports for graylog inputs
      with_nested:
        - "{{ lookup('template', 'graylog-source-list.yaml.j2', convert_data=True) | from_yaml }}"
        - [12201, 12202, 12203]
    - name: Open ports for logging into Graylog from the office IP
      ufw: from="ip1" port="{{item}}" rule=allow
      with_items:
    - name: Open HTTPS port from any IP
      ufw: from="any" port="443" rule=allow
    - name: Open port for mongodb
      ufw: from="127.0.0.1" port="27017" rule=allow
    handlers:
    - name: Restart fail2ban
      service: name=fail2ban state=restarted
Graylog is unable to connect to MongoDB, which is required to start.
yes, but how do I debug this? for now I am using this as my mongodb_uri= mongodb_uri = mongodb://127.0.0.1:27017/graylog
bind_ip=127.0.0.1
Did you install and configure MongoDB correctly?
I used the mongodb role in the requirements file, also here is the ansible output:
TASK [lesmyrmidons.mongodb : Include OS-specific variables.] ********************************************************************************************
ok: [graylog-primary]
TASK [lesmyrmidons.mongodb : RedHat | Install dependencies packages] ************************************************************************************
skipping: [graylog-primary]
TASK [lesmyrmidons.mongodb : RedHat | Add source sources] ***********************************************************************************************
TASK [lesmyrmidons.mongodb : RedHat | Install Packages] *************************************************************************************************
skipping: [graylog-primary] => (item=[])
TASK [lesmyrmidons.mongodb : Debian | Add keys authenticity] ********************************************************************************************
TASK [lesmyrmidons.mongodb : Debian | Add source sources] ***********************************************************************************************
TASK [lesmyrmidons.mongodb : Debian | Install Packages] *************************************************************************************************
ok: [graylog-primary] => (item=[u'mongodb-org'])
I won’t debug your Ansible playbook nor the MongoDB role it’s using.
Simple fact is that Graylog is unable to connect to MongoDB using the configured MongoDB Connection String.
Many thanks for the quick response. Ansible wasn’t configuring the mongodb, so I will do it manually.
