Z-system compatibility
Is it possible to install Graylog on IBM z-system
Is it possible to use the Docker version to install on z-system?
Are available installation packages for z-system (RedHat) in the dowload area, or is it necessary to recompile the source code on z-system?
As long as it can fulfill all the system requirements, that should be possible:
http://docs.graylog.org/en/2.4/pages/installation.html#system-requirements
This being said, we neither test nor officially support running Graylog on an IBM zSeries mainframe.
I don’t know. Test it and give us feedback. :slight_smile:
We offer official RPM packages, but they only support x86 and x86_64 for the platform-dependent parts of Graylog.
Thanks for the answers. I’ll certanly give you my feedback when i finished to deploy Graylog on z-system.
