Wrong URI for API
I have problem with getting information about nodes. There is wrong API. It happened after I installed SSL certificate and now service works with HTTPS instead of HTTP.
Now Graylog tries to send API requests to graylog.tilog.corp/10.100.18.7:443 and it is totally wrong. I have such error:
  • FetchError: There was an error fetching a resource: Internal Server Error. Additional information: Failed to connect to graylog.tilog.corp/10.100.18.7:443
  • OS: Ubuntu 20.04
  • Package Version: 5.1.5-1
In graylog-server conf I have following http_uris:
http_bind_address = 10.100.18.7:9000
http_publish_uri = https://graylog.tilog.corp
http_external_uri is commented
Full configuration
is_leader = true
password_secret = <my secret>
root_username = admin
root_password_sha2 = <my_pass>
root_timezone = Europe/Moscow
http_enable_tls = true
http_tls_cert_file = /opt/graylog/tls/graylog.pem
http_tls_key_file = /opt/graylog/tls/graylog.key
elasticsearch_hosts = http://10.100.18.8:9200
elasticsearch_version_probe_attempts = 5
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 6
outputbuffer_processors = 6
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
mongodb_uri = mongodb://127.0.0.1:27017/graylog
I tried to set http_external_uri as either http_bind_address and http_publish_uri. When I had started service after these changes, it failed.
I think, there is something that I missed in URIs’ configuration.
How can I improve my configuration to avoid this error? I still need secure connection. What I should change to see nodes state again?
This should be easily fixed. You are missing a port on your http_publish_uri. If you change it to the below, it should work as expected.
http_publish_uri = https://graylog.tilog.corp:9000
Kyle, thanks a lot! It really works!
