Workaround for CEF - Integer/Double
Hi!
I am sending CEF-logs from Fortigate-firewalls to graylog.
IN/OUT-bytes are sometimes bigger than the integer limits. This is already a known issue:
But: Do you have any idea on how to do a workaround to this? Do you have any idea for an alternative handling of the logs?
Currently, I am using a pipeline-rule to extract CEF:
let result = regex(("(CEF:.*)$"),to_string($message.message));
But there is:
WARN [MappedMessage] Could not transform CEF field [out] according to standard. Skipping.
java.lang.NumberFormatException: For input string: “2273997656”
Thank you for your thoughts
KPS
Hi!
I just found a “nasty” workaround:
My rule-order is: Pipeline->Extractor
Pipeline:
rule "Fortigate Process CEF for traffic"
		contains(to_string($message.message), "CEF:0", true)
        let pure_cef = to_string(result["0"]);
        // Remove in and out for later extraction from message field by EXTRACTOR
        let pure_cef = regex_replace("(.*)( out=[0-9]{1,10} )(.*)", pure_cef, "$1 $3");
        let pure_cef = regex_replace("(.*)( in=[0-9]{1,10} )(.*)", pure_cef, "$1 $3");
        set_fields(parse_cef(to_string(pure_cef), false));
        set_field("message", to_string(result["0"]));
And extractors from message-field later.
KPS
Hi!
I had to change the rules and go to “pipeline-only” to be able to convert to “double”:
        let pure_cef = regex_replace("(.*)( out=[0-9]{1,20} )(.*)", pure_cef, "$1 $3");
        let pure_cef = regex_replace("(.*)( in=[0-9]{1,20} )(.*)", pure_cef, "$1 $3");
        // set_field("pure_cef", to_string(pure_cef));
rule "Fortigate Process Traffic Counters Full Sessions"
		contains(to_string($message.message), " in=", true)
		AND contains(to_string($message.message), " out=", true)
		AND NOT contains(to_string($message.message), " FTNTFGTlogid=0000000020 ", true)
	    let intotal = to_double(regex_replace("(.* in=)([0-9]{1,20})( .*)",to_string($message.message),"$2"));
	    let outtotal = to_double(regex_replace("(.* out=)([0-9]{1,20})( .*)",to_string($message.message),"$2"));
	    set_field("in", to_double(intotal));
	    set_field("out", to_double(outtotal));
rule "Fortigate Process Traffic Counters Partial Sessions"
		AND contains(to_string($message.message), " FTNTFGTlogid=0000000020 ", true)
	    set_field("intotal", to_double(intotal));
	    set_field("outtotal", to_double(intotal));
	    let inbyte = to_double(regex_replace("(.* FTNTFGTrcvddelta=)([0-9]{1,20})(.*)",to_string($message.message),"$2"));
	    let outbyte = to_double(regex_replace("(.* FTNTFGTsentdelta=)([0-9]{1,20})(.*)",to_string($message.message),"$2"));
	    set_field("in", to_double(inbyte));
	    set_field("out", to_double(outbyte));
Hello @KPS
Nice I was wondering if you have seen the category in the forum below. It would be nice if you could write up something under pipelines there for future community members. This would give a better search later on. Also thank you for posting your resolution to the issue :slight_smile:
