Graylog doesn't work with CEF input
Hi all,
I’ve come across with a problem where graylog doesn’t show messages coming in CEF format.
I am using Arcsight connector to gather log from a Domain controller. The Connector, in turn, sends logs to Graylog server in CEF format (UDP). On Graylog server I’ve used CEF plugin in order to create CEF UDP input. The problem is I see the traffic that comes to the CEF input but it can’t be parsed by graylog and therefore messages are not displayed.
Guys, maybe someone has faced such issue. Could you help me to resolve it.
Graylog version is Graylog v2.4.3+2c41897
CEF last updated plugin
The following messages i see in graylog’s logs
2018-04-13T10:51:52.109+06:00 ERROR [DecodingProcessor] Unable to decode raw message RawMessage{id=61e485d2-3ed6-11e8-8250-a0086f465651, journalOffset=26083484494, codec=CEF, payloadSize=934, timestamp=2018-04-13T04:51:52.109Z, remoteAddress=/10.1XXXXXX:48662} on input <5ad03657b1af719aa2846c84>.
2018-04-13T10:51:52.109+06:00 ERROR [DecodingProcessor] Error processing message RawMessage{id=61e485d2-3ed6-11e8-8250-a0086f465651, journalOffset=26083484494, codec=CEF, payloadSize=934, timestamp=2018-04-13T04:51:52.109Z, remoteAddress=/10.1XXXXX:48662}
org.graylog.plugins.cef.parser.ParserException: This message was not recognized as CEF and could not be parsed.
at org.graylog.plugins.cef.parser.SyslogCEFParser.parse(SyslogCEFParser.java:51) ~[?:?]
at org.graylog.plugins.cef.codec.CEFCodec.decode(CEFCodec.java:59) ~[?:?]
at org.graylog2.shared.buffers.processors.DecodingProcessor.processMessage(DecodingProcessor.java:150) ~[graylog.jar:?]
at org.graylog2.shared.buffers.processors.DecodingProcessor.onEvent(DecodingProcessor.java:91) [graylog.jar:?]
at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.onEvent(ProcessBufferProcessor.java:74) [graylog.jar:?]
at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.onEvent(ProcessBufferProcessor.java:42) [graylog.jar:?]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_151]
First, please format your post for readability:
https://help.github.com/articles/creating-and-highlighting-code-blocks/
Second, which client is generating these messages? Please provide the complete product name and the version you’re using.
And last but not least, please capture some of the messages sent by this client on the wire via Wireshark or tcpdump and create a bug report at https://github.com/Graylog2/graylog2-server/issues.
