Winlogbeat to Graylog
I am trying to use Winlogbeat to send it to my Graylog.
When I edit the configuration on my winlogbeat.yml and do a restart on the service, it show me the following error:
The winlogbeat service terminated unexpectedly. It has done this 3 time(s).
The following will be my winlogbeat.yml configuration:
###################### Winlogbeat Configuration Example ########################
# This file is an example configuration file highlighting only the most common
# options. The winlogbeat.reference.yml file from the same directory contains
# all the supported options with more comments. You can use it as a reference.
# You can find the full configuration reference here:
# https://www.elastic.co/guide/en/beats/winlogbeat/index.html
# ======================== Winlogbeat specific options =========================
# event_logs specifies a list of event logs to monitor as well as any
# accompanying options. The YAML data type of event_logs is a list of
# dictionaries.
# The supported keys are name, id, xml_query, tags, fields, fields_under_root,
# forwarded, ignore_older, level, event_id, provider, and include_xml.
# The xml_query key requires an id and must not be used with the name,
# ignore_older, level, event_id, or provider keys. Please visit the
# documentation for the complete details of each option.
# https://go.es.io/WinlogbeatConfig
winlogbeat.event_logs:
  - name: Application
    ignore_older: 72h
  - name: System
  - name: Security
  - name: Microsoft-Windows-Sysmon/Operational
  - name: Windows PowerShell
    event_id: 400, 403, 600, 800
  - name: Microsoft-Windows-PowerShell/Operational
    event_id: 4103, 4104, 4105, 4106
  - name: ForwardedEvents
    tags: [forwarded]
# ====================== Elasticsearch template settings =======================
setup.template.settings:
  index.number_of_shards: 1
  #index.codec: best_compression
  #_source.enabled: false
# ================================== General ===================================
# The name of the shipper that publishes the network data. It can be used to group
# all the transactions sent by a single shipper in the web interface.
#name:
# The tags of the shipper are included in their field with each
# transaction published.
#tags: ["service-X", "web-tier"]
# Optional fields that you can specify to add additional information to the
# output.
#fields:
#  env: staging
# ================================= Dashboards =================================
# These settings control loading the sample dashboards to the Kibana index. Loading
# the dashboards is disabled by default and can be enabled either by setting the
# options here or by using the `setup` command.
setup.dashboards.enabled: true
# The URL from where to download the dashboard archive. By default, this URL
# has a value that is computed based on the Beat name and version. For released
# versions, this URL points to the dashboard archive on the artifacts.elastic.co
# website.
#setup.dashboards.url:
# =================================== Kibana ===================================
# Starting with Beats version 6.0.0, the dashboards are loaded via the Kibana API.
# This requires a Kibana endpoint configuration.
#setup.kibana:
  # Kibana Host
  # Scheme and port can be left out and will be set to the default (http and 5601)
  # In case you specify and additional path, the scheme is required: http://localhost:5601/path
  # IPv6 addresses should always be defined as: https://[2001:db8::1]:5601
  #host: "localhost:5601"
  # Kibana Space ID
  # ID of the Kibana Space into which the dashboards should be loaded. By default,
  # the Default Space will be used.
  #space.id:
# =============================== Elastic Cloud ================================
# These settings simplify using Winlogbeat with the Elastic Cloud (https://cloud.elastic.co/).
# The cloud.id setting overwrites the `output.elasticsearch.hosts` and
# `setup.kibana.host` options.
# You can find the `cloud.id` in the Elastic Cloud web UI.
#cloud.id:
# The cloud.auth setting overwrites the `output.elasticsearch.username` and
# `output.elasticsearch.password` settings. The format is `<user>:<pass>`.
#cloud.auth:
# ================================== Outputs ===================================
# Configure what output to use when sending the data collected by the beat.
# ---------------------------- Elasticsearch Output ----------------------------
#output.elasticsearch:
  # Array of hosts to connect to.
  #hosts: ["localhost:9200"]
  # Protocol - either `http` (default) or `https`.
  #protocol: "https"
  # Authentication credentials - either API key or username/password.
  #api_key: "id:api_key"
  #username: "elastic"
  #password: "changeme"
  # Pipeline to route events to security, sysmon, or powershell pipelines.
  #pipeline: "winlogbeat-%{[agent.version]}-routing"
# ------------------------------ Logstash Output -------------------------------
output.logstash:
  # The Logstash hosts
  hosts: ["192.168.1.218:25044"]
  # Optional SSL. By default is off.
  # List of root certificates for HTTPS server verifications
  #ssl.certificate_authorities: ["/etc/pki/root/ca.pem"]
  # Certificate for SSL client authentication
  #ssl.certificate: "/etc/pki/client/cert.pem"
  # Client Certificate Key
  #ssl.key: "/etc/pki/client/cert.key"
# ================================= Processors =================================
processors:
  - add_host_metadata:
      when.not.contains.tags: forwarded
  - add_cloud_metadata: ~
# ================================== Logging ===================================
# Sets log level. The default log level is info.
# Available log levels are: error, warning, info, debug
#logging.level: debug
# At debug level, you can selectively enable logging only for some components.
# To enable all selectors, use ["*"]. Examples of other selectors are "beat",
# "publisher", "service".
#logging.selectors: ["*"]
# ============================= X-Pack Monitoring ==============================
# Winlogbeat can export internal metrics to a central Elasticsearch monitoring
# cluster.  This requires xpack monitoring to be enabled in Elasticsearch.  The
# reporting is disabled by default.
# Set to true to enable the monitoring reporter.
#monitoring.enabled: false
# Sets the UUID of the Elasticsearch cluster under which monitoring data for this
# Winlogbeat instance will appear in the Stack Monitoring UI. If output.elasticsearch
# is enabled, the UUID is derived from the Elasticsearch cluster referenced by output.elasticsearch.
#monitoring.cluster_uuid:
# Uncomment to send the metrics to Elasticsearch. Most settings from the
# Elasticsearch outputs are accepted here as well.
# Note that the settings should point to your Elasticsearch *monitoring* cluster.
# Any setting that is not set is automatically inherited from the Elasticsearch
# output configuration, so if you have the Elasticsearch output configured such
# that it is pointing to your Elasticsearch monitoring cluster, you can simply
# uncomment the following line.
#monitoring.elasticsearch:
# ============================== Instrumentation ===============================
# Instrumentation support for the winlogbeat.
#instrumentation:
    # Set to true to enable instrumentation of winlogbeat.
    #enabled: false
    # Environment in which winlogbeat is running on (eg: staging, production, etc.)
    #environment: ""
    # APM Server hosts to report instrumentation results to.
    #hosts:
    #  - http://localhost:8200
    # API Key for the APM Server(s).
    # If api_key is set then secret_token will be ignored.
    #api_key:
    # Secret token for the APM Server(s).
    #secret_token:
# ================================= Migration ==================================
# This allows to enable 6.7 migration aliases
#migration.6_to_7.enabled: true
May I know what is the issue?
I do not know Winlogbeat but first guess is to comment (#)
Elasticsearch template settings, Dashboards and Processors as they have a different function to me then collecting and sending logs to as I read it your graylog server that listens on port 25044 @ 192.168.1.218
Hi ,
I have try commenting out. but it still failed.
When ever when I started my winlogbeat on my computer managements > service, it will auto stop the service.
When I check my event view log, I dont see any error. So not sure what is the issue .
→ this errors can come from many causes (bad conf, bad Winlogbeat version, etc)
If you are using Graylog with Opensearch, I recommand you the Winlogbeat 7.12.1.0 OSS.
Here’s my Winlogbeat Sidecar conf for Graylog, it will send all event ID related to security. You can remove the one you do not want.
# Needed for Graylog
fields_under_root: true
output.logstash:
   hosts: ["graylog.lab.lan:5044"]
path.data: C:\Program Files\Graylog\sidecar\cache\winlogbeat\data
path.logs: C:\Program Files\Graylog\sidecar\logs
path.module: C:\Program Files\Graylog\sidecar\module
#FileSystem Monitor
   - name: Security
     event_id: 4656, 4663, 4670, 4907, 5140, 5142-5145
     ignore_older: 24h
     tags: [filesystem]
     processors:
       - script:
          lang: javascript
          file: C:\Program Files\Graylog\sidecar\module\security\config\winlogbeat-security.js
       - drop_event.when.not.or:
           - equals.winlog.event_data.ObjectType: "File"
       - drop_event.when.or:
           - regexp.winlog.event_data.winlog_task: 'Authorization Policy Change'
           - regexp.winlog.event_data.winlog_task: 'Audit Policy Change'
           - equals.winlog.event_data.winlog_task: "Registry"
           - equals.winlog.event_data.winlog_task: "Kernel Object"
           - equals.winlog.event_data.SubjectUserSid: 'S-1-5-18'
           - equals.winlog.event_data.SubjectUserSid: 'S-1-5-19'
           #cant see the diff between human/computer action opening a folder, too many logs
           - regexp.winlog.event_data.AccessList: '^%%4416.*'
           # dont need to know who read which permission
           - regexp.winlog.event_data.AccessList: '^%%1538.*'
           - regexp.winlog.event_data.AccessList: '^%%1539.*'
           - regexp.winlog.event_data.AccessList: '^%%1542.*'
           #we dont need to monitor synchronize status event
           - regexp.winlog.event_data.AccessList: '^%%1541.*'
           #we do not need to know who read/write extended attribute
           - regexp.winlog.event_data.AccessList: '^%%4419.*'
           - regexp.winlog.event_data.AccessList: '^%%4420.*'
           #computers always executing dll which gives too many logs
           - regexp.winlog.event_data.AccessList: '^%%4421.*'
           #too many logs for ReadAttributes event, on everyaction, it reads attribute
           - regexp.winlog.event_data.AccessList: '^%%4423.*'
           - regexp.winlog.event_data.AccessList: '^%%4424.*'
           #dont need to know some activites automated by the system using user permission
           - regexp.winlog.event_data.ObjectName: '^(?i)C\:\\Users\\[a-zA-Z0-9._~-]+\\AppData\\Local\\Microsoft\\Windows.*'
           - regexp.winlog.event_data.ObjectName: '^(?i)C\:\\Users\\[a-zA-Z0-9._~-]+\\AppData\\Local\\Microsoft\\PenWorkspace.*'
           - regexp.winlog.event_data.ObjectName: '^(?i)C\:\\Users\\[a-zA-Z0-9._~-]+\\AppData\\Local\\Microsoft\\CLR_v4.0.*'
           - regexp.winlog.event_data.ObjectName: '^(?i)C\:\\Users\\[a-zA-Z0-9._~-]+\\AppData\\Local\\Microsoft\\Internet Explorer\\CacheStorage.*'
           - regexp.winlog.event_data.ObjectName: '^(?i)C\:\\Users\\[a-zA-Z0-9._~-]+\\AppData\\Local\\Microsoft\\Windows\\Recent\\AutomaticDestinations.*'
           - regexp.winlog.event_data.ObjectName: '^(?i)C\:\\Users\\[a-zA-Z0-9._~-]+\\AppData\\Local\\Packages.*'
           - regexp.winlog.event_data.ObjectName: '^(?i)C\:\\Users\\[a-zA-Z0-9._~-]+\\AppData\\Local\\Google\\Chrome\\User Data.*'
           - regexp.winlog.event_data.ObjectName: '^(?i)C\:\\Users\\[a-zA-Z0-9._~-]+\\AppData\\Local\\Google\\Chrome\\Application\\SetupMetrics.*'
           - regexp.winlog.event_data.ObjectName: '^(?i)C\:\\Users\\[a-zA-Z0-9._~-]+\\AppData\\Local\\BraveSoftware\\Brave-Browser\\User Data.*'
           - regexp.winlog.event_data.ObjectName: '^(?i)C\:\\Users\\[a-zA-Z0-9._~-]+\\AppData\\Local\\Microsoft\\Edge\\User Data.*'
           - regexp.winlog.event_data.ObjectName: '^(?i)C\:\\Users\\[a-zA-Z0-9._~-]+\\AppData\\Local\\Mozilla\\Firefox\\Profiles\\[a-zA-Z0-9._~-]+\\cache2.*'
           - regexp.winlog.event_data.ObjectName: '^(?i)C\:\\Users\\[a-zA-Z0-9._~-]+\\AppData\\Local\\Temp.*'
           - regexp.winlog.event_data.ObjectName: '^(?i)C\:\\Users\\[a-zA-Z0-9._~-]+\\AppData\\Local\\D3DSCache.*'
           - regexp.winlog.event_data.ObjectName: '^(?i)C\:\\Windows\\ServiceProfiles\\NetworkService\\AppData\\Local\\Microsoft\\Windows\\DeliveryOptimization.*'
           - regexp.winlog.event_data.ObjectName: '^(?i)C\:\\ProgramData\\NVIDIA Corporation\\Drs.*'
           - regexp.winlog.event_data.ObjectName: '^(?i)C\:\\ProgramData\\USOShared\\Logs.*'
           - regexp.winlog.event_data.ObjectName: '^(?i)C\:\\Windows\\Logs.*'
           - regexp.winlog.event_data.ObjectName: '^(?i)C\:\\Windows\\System32\\LogFiles.*'
           - regexp.winlog.event_data.ObjectName: '^(?i)C\:\\Users\\[a-zA-Z0-9._~-]+\\AppData\\Local\\Microsoft\\Token\\Cache.*'
           - regexp.winlog.event_data.ObjectName: '^(?i)C\:\\Users\\[a-zA-Z0-9._~-]+\\AppData\\Roaming\\Microsoft.*'
           - regexp.winlog.event_data.ObjectName: '^(?i)C\:\\Users\\[a-zA-Z0-9._~-]+\\AppData\\LocalLow\\Microsoft\\CryptnetUrlCache.*'
           #dont need to know recycle bin activites, we already have the Delete event (%%1537)
           - regexp.winlog.event_data.ObjectName: '^(?i)C\:\\\$Recycle.Bin.*'
##### ******* Windows OS ******** #######
   - name: Security
     event_id: 4608, 4610, 4611, 4614, 4622, 4697, 4719, 4817, 4826, 4902, 4904, 4905, 4906, 4908, 4912
     ignore_older: 48h
     tags: [windowsos]
     processors:
      - script:
          lang: javascript
      - drop_event.when:
           and:
   - name: System
     event_id: 12, 13, 1074
     ignore_older: 24h
     tags: [windowsos]
     provider:
       - Microsoft-Windows-Kernel-General
       - USER32
   - name: System
     event_id: 16962, 16965, 16968, 16969, 41, 1001, 6008, 4621
     ignore_older: 24h
     tags: [windowsos]
   - name: Microsoft-Windows-SMBServer/Audit
     event_id: 3000
     ignore_older: 24h
     tags: [windowsos]
     provider:
       - Microsoft-Windows-SMBServer
##### ******* Windows USB ******** #######
   - name: Microsoft-Windows-DriverFrameworks-UserMode/Operational
     level: 'critical, error'
     event_id: 2003, 2102
     ignore_older: 24h
     tags: [windowsusb]
   - name: Microsoft-Windows-Kernel-PnP/Configuration
     tags: [windowsusb]
     processors:
       - drop_event.when.not:
           and:
             - equals.winlog.event_data.DriverName: "&quot;usbstor.inf&quot;"
     event_id: 400, 410
     ignore_older: 24h
     tags: [windowsusb]
     level: information
     provider:
       - Microsoft-Windows-Kernel-PnP
   - name: Security
     event_id: 6416, 6419-6424
     ignore_older: 24h
     tags: [windowsusb]
     processors:
      - script:
          lang: javascript
           - regexp.winlog.event_data.DeviceDescription: '^Microsoft Print to PDF.*'
           - regexp.winlog.event_data.DeviceDescription: '^Microsoft XPS Document Writer.*'
           - regexp.winlog.event_data.DeviceDescription: '^Generic Non-PnP Monitor.*'
##### ******* Windows Registry ******** #######
   - name: Security
     event_id: 4657
     ignore_older: 24h
     tags: [windowsregistry]
     processors:
       - script:
          lang: javascript
           - equals.winlog.event_data.OperationType: '%%1904'
           - equals.winlog.event_data.OperationType: '%%1905'
           - equals.winlog.event_data.OperationType: '%%1906'
           - regexp.winlog.event_data.ObjectName: '(?i)^\\REGISTRY\\MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Group Policy\\Scripts\\Startup.*'
           - regexp.winlog.event_data.ObjectName: '(?i)^\\REGISTRY\\MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Group Policy\\Scripts\\Shutdown.*'
           - regexp.winlog.event_data.ObjectName: '(?i)^\\REGISTRY\\MACHINE\\SYSTEM\\CurrentControlSet\\Control\\SafeBoot\\AlternateShell.*'
           - regexp.winlog.event_data.ObjectName: '(?i)^\\REGISTRY\\MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Run.*'
           - regexp.winlog.event_data.ObjectName: '(?i)^\\REGISTRY\\MACHINE\\SOFTWARE\\Wow6432Node\\Microsoft\\Windows\\CurrentVersion\\Run.*'
           - regexp.winlog.event_data.ObjectName: '(?i)^\\REGISTRY\\USER\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Run.*'
           - regexp.winlog.event_data.ObjectName: '(?i)^\\REGISTRY\\USER\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\RunOnce.*'
           - regexp.winlog.event_data.ObjectName: '(?i)^\\REGISTRY\\MACHINE\\SOFTWARE\\Microsoft\\Active Setup\\Installed Components.*'
           - regexp.winlog.event_data.ObjectName: '(?i)^\\REGISTRY\\MACHINE\\SOFTWARE\\Wow6432Node\\Microsoft\\Active Setup\\Installed Components.*'
           - regexp.winlog.event_data.ObjectName: '(?i)^\\REGISTRY\\MACHINE\\SYSTEM\\CurrentControlSet\\Services.*'
           - regexp.winlog.event_data.ObjectName: '(?i)^\\REGISTRY\\MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Explorer\\SharedTaskScheduler.*'
           - regexp.winlog.event_data.ObjectName: '(?i)^\\REGISTRY\\MACHINE\\SOFTWARE\\Wow6432Node\\Microsoft\\Windows\\CurrentVersion\\Explorer\\SharedTaskScheduler.*'
           - regexp.winlog.event_data.ObjectName: '(?i)^\\REGISTRY\\MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Explorer\\ShellServiceObjects.*'
           - regexp.winlog.event_data.ObjectName: '(?i)^\\REGISTRY\\MACHINE\\SOFTWARE\\Wow6432Node\\Microsoft\\Windows\\CurrentVersion\\Explorer\\ShellServiceObjects.*'
           - regexp.winlog.event_data.ObjectName: '(?i)^\\REGISTRY\\MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\ShellServiceObjectDelayLoad.*'
           - regexp.winlog.event_data.ObjectName: '(?i)^\\REGISTRY\\MACHINE\\SOFTWARE\\Wow6432Node\\Microsoft\\Windows\\CurrentVersion\\ShellServiceObjectDelayLoad.*'
           - regexp.winlog.event_data.ObjectName: '(?i)^\\REGISTRY\\MACHINE\\SOFTWARE\\Classes\\Drive\\ShellEx\\ContextMenuHandlers.*'
           - regexp.winlog.event_data.ObjectName: '(?i)^\\REGISTRY\\MACHINE\\SOFTWARE\\Classes\\Directory\\ShellEx\\ContextMenuHandlers.*'
           - regexp.winlog.event_data.ObjectName: '(?i)^\\REGISTRY\\MACHINE\\SOFTWARE\\Classes\\Directory\\ShellEx\\DragDropHandlers.*'
           - regexp.winlog.event_data.ObjectName: '(?i)^\\REGISTRY\\MACHINE\\SOFTWARE\\Classes\\Directory\\ShellEx\\CopyHookHandlers.*'
           - regexp.winlog.event_data.ObjectName: '(?i)^\\REGISTRY\\MACHINE\\SOFTWARE\\Classes\\Directory\\Background\\ShellEx\\ContextMenuHandlers.*'
           - regexp.winlog.event_data.ObjectName: '(?i)^\\REGISTRY\\MACHINE\\SOFTWARE\\Classes\\Folder\\ShellEx\\ContextMenuHandlers.*'
           - regexp.winlog.event_data.ObjectName: '(?i)^\\REGISTRY\\MACHINE\\SOFTWARE\\Classes\\Folder\\ShellEx\\DragDropHandlers.*'
           - regexp.winlog.event_data.ObjectName: '(?i)^\\REGISTRY\\MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Explorer\\ShellIconOverlayIdentifiers.*'
           - regexp.winlog.event_data.ObjectName: '(?i)^\\REGISTRY\\MACHINE\\SOFTWARE\\Wow6432Node\\Microsoft\\Windows\\CurrentVersion\\Explorer\\ShellIconOverlayIdentifiers.*'
           - regexp.winlog.event_data.ObjectName: '(?i)^\\REGISTRY\\MACHINE\\SOFTWARE\\Microsoft\\Windows NT\\CurrentVersion\\WinLogon\\GPExtensions.*'
##### ******* Windows Firewall ******** #######
   - name: Microsoft-Windows-Windows Firewall With Advanced Security/Firewall
     event_id: 2002, 2004, 2005, 2006, 2009, 2033, 2099, 2097, 2010
     ignore_older: 24h
     tags: [windowsfirewall]
     level: err, info
     provider:
       - Microsoft-Windows-Windows Firewall With Advanced Security
   - name: Security
     event_id: 4944-4954, 4956-4958, 5024, 5025, 5037, 5027-5030, 5032-5035, 5031, 5150, 5151, 5154-5157, 5159
     ignore_older: 24h
     processors:
      - script:
          lang: javascript
          - regexp.winlog.event_data.DestAddress: '239.255.255.250'
          - regexp.winlog.event_data.DestAddress: '((([0-9A-Fa-f]{1,4}:){7}([0-9A-Fa-f]{1,4}|:))|(([0-9A-Fa-f]{1,4}:){6}(:[0-9A-Fa-f]{1,4}|((25[0-5]|2[0-4]\d|1\d\d|[1-9]?\d)(\.(25[0-5]|2[0-4]\d|1\d\d|[1-9]?\d)){3})|:))|(([0-9A-Fa-f]{1,4}:){5}(((:[0-9A-Fa-f]{1,4}){1,2})|:((25[0-5]|2[0-4]\d|1\d\d|[1-9]?\d)(\.(25[0-5]|2[0-4]\d|1\d\d|[1-9]?\d)){3})|:))|(([0-9A-Fa-f]{1,4}:){4}(((:[0-9A-Fa-f]{1,4}){1,3})|((:[0-9A-Fa-f]{1,4})?:((25[0-5]|2[0-4]\d|1\d\d|[1-9]?\d)(\.(25[0-5]|2[0-4]\d|1\d\d|[1-9]?\d)){3}))|:))|(([0-9A-Fa-f]{1,4}:){3}(((:[0-9A-Fa-f]{1,4}){1,4})|((:[0-9A-Fa-f]{1,4}){0,2}:((25[0-5]|2[0-4]\d|1\d\d|[1-9]?\d)(\.(25[0-5]|2[0-4]\d|1\d\d|[1-9]?\d)){3}))|:))|(([0-9A-Fa-f]{1,4}:){2}(((:[0-9A-Fa-f]{1,4}){1,5})|((:[0-9A-Fa-f]{1,4}){0,3}:((25[0-5]|2[0-4]\d|1\d\d|[1-9]?\d)(\.(25[0-5]|2[0-4]\d|1\d\d|[1-9]?\d)){3}))|:))|(([0-9A-Fa-f]{1,4}:){1}(((:[0-9A-Fa-f]{1,4}){1,6})|((:[0-9A-Fa-f]{1,4}){0,4}:((25[0-5]|2[0-4]\d|1\d\d|[1-9]?\d)(\.(25[0-5]|2[0-4]\d|1\d\d|[1-9]?\d)){3}))|:))|(:(((:[0-9A-Fa-f]{1,4}){1,7})|((:[0-9A-Fa-f]{1,4}){0,5}:((25[0-5]|2[0-4]\d|1\d\d|[1-9]?\d)(\.(25[0-5]|2[0-4]\d|1\d\d|[1-9]?\d)){3}))|:)))(%.+)?'
          - regexp.winlog.event_data.Application: 'dns.exe'
##### ******* Windows Service ******** #######
   - name: System
     event_id: 7022-7024, 7026, 7031, 7032, 7034, 7040, 7045
     ignore_older: 24h
     tags: [windowsservice]
     level: err, info, crit, warn
     provider:
       - Service Control Manager
     processors:
           - regexp.winlog.event_data.param1: '^Programme d’installation pour les modules Windows.*'
           - regexp.winlog.event_data.param1: '^Service de transfert intelligent en arrière-plan.*'
##### ******* Windows EventLog ******** #######
   - name: System
     event_id: 104
     ignore_older: 24h
     tags: [windowseventlog]
     level: info
     provider:
       - Microsoft-Windows-Eventlog
   - name: Security
     event_id: 1100, 1104, 1105, 1108
     ignore_older: 24h
     processors:
      - script:
          lang: javascript
   - name: Security
     event_id: 1102
     ignore_older: 24h
     level: info
     provider:
     processors:
      - script:
          lang: javascript
##### ******* Windows PowerShell ******** #######
     ignore_older: 48h
     tags: [powershell-legacy]
     processors:
      - script:
          lang: javascript
          file: C:\Program Files\Graylog\sidecar\module\powershell\config\winlogbeat-powershell.js
     event_id: 4103, 4105, 4106
     ignore_older: 48h
     tags: [powershell]
     processors:
      - script:
          lang: javascript
          - equals.winlog.event_id: 4104
          - equals.winlog.event_id: 4100
          - equals.winlog.event_id: 32784
##### ******* Windows Privilege ******** #######
   - name: Security
     event_id: 4673, 4674, 4985
     ignore_older: 24h
     tags: [windowsprivilege]
     processors:
      - script:
          lang: javascript
##### ******* Windows Process ******** #######
   - name: Security
     event_id: 4688, 4689
     ignore_older: 24h
     tags: [windowsprocess]
     processors:
      - script:
          lang: javascript
##### ******* Windows Task ******** #######
   - name: Microsoft-Windows-TaskScheduler/Operational
     event_id: 106, 129, 141, 142, 200, 201
     ignore_older: 24h
     tags: [windowstask]
     provider:
       - Microsoft-Windows-TaskScheduler
   - name: Security
     event_id: 4698-4702
     ignore_older: 24h
     tags: [windowstask]
     processors:
      - script:
          lang: javascript
##### ******* DNS Client ******** #######
   - name: Microsoft-Windows-DNS-Client/Operational
     event_id: 3006, 3008, 3010, 3018
     ignore_older: 24h
     tags: [windowsdnsclient]
     processors:
       - drop_event.when:
           or:
            - equals.winlog.event_data.QueryOptions: '140737488355328'
            - equals.winlog.event_data.QueryResults: ''
##### ******* Windows RDP ******** #######
   - name: Microsoft-Windows-TerminalServices-RDPClient/Operational
     ignore_older: 24h
     tags: [windowsrdp]
     level: crit, error, info, warn
   - name: Microsoft-Windows-TerminalServices-LocalSessionManager/Operational
     ignore_older: 24h
     tags: [windowsrdp]
##### ******* Account Lockout & Auth ******** #######
   - name: Security
     event_id: 4624-4627, 4634, 4647, 4649, 4672, 4675, 4740, 4774-4779, 4800-4803, 4964, 5378
     level: info
     ignore_older: 24h
     tags: [auth]
     provider:
       - Microsoft-Windows-Security-Auditing
     processors:
       - script:
          lang: javascript
       - drop_event.when:
           or:
             - equals.winlog.event_data.TargetUserSid: 'S-1-5-18'
             - regexp.winlog.event_data.TargetUserName: '.*\$'
##### ******* Windows Defender ******** #######
   - name: Microsoft-Windows-Windows Defender/Operational
     event_id: 1006-1009, 1116-1119
     ignore_older: 24h
     tags: [windowsdefender]
And on you Windows Host, check the sidecar file:
  • C:\Program Files\Graylog\sidecar\sidecar.yml
server_url: "https://graylog.lab.lan/api"
server_api_token: "your_token_api"
node_id: "file:C:\\Program Files\\Graylog\\sidecar\\node-id"
node_name: ""
update_interval: 10
tls_skip_verify: true
send_status: true
tags:
  - winlogbeat
collector_binaries_accesslist:
  - "C:\\Program Files\\Graylog\\sidecar\\winlogbeat.exe"
