Graylog INPUT Beat
Hi Guys
I use Graylog Enterprise version 3.1
I have installed the tools WinlogBeat 7.7 , Packetbeat7.7 , MetricBeat7.7 on Windows Server 2008 (ONLY web server IIS) without any problems.
winlogbeat test config = OK AND Winlogbeat test output = OK
Packetbeat test config = OK AND Packetbeat tes t output = OK
MetricBeat test config = OK AND Metricbeat test output = OK
But unfortunately I don’t see any message in the Graylog
ubuntu@graylog-preview:~$ sudo tail -f /var/log/graylog-server/server.log
2020-05-23T12:08:17.583Z ERROR [AbstractTcpTransport] Error in Input [Beats/5ec90d033fddbe058a2cf026] (channel [id: 0x4155611e, L:/172.20.4.103:5061 ! R:/172.20.4.91:52187]) (cause io.netty.channel.unix.Errors$NativeIoException: syscall:read(…) failed: Connection reset by peer)
2020-05-23T12:08:17.583Z ERROR [AbstractTcpTransport] Error in Input [Beats/5ec90d033fddbe058a2cf026] (channel [id: 0xaf052f24, L:/172.20.4.103:5061 ! R:/172.20.4.91:52188]) (cause io.netty.channel.unix.Errors$NativeIoException: syscall:read(…) failed: Connection reset by peer)
Of course, for security reasons, the Graylog server has nothing to do with the Internet
please HELP me
  1. Recommended way to collect beats on Windows is to use sidecar. Do you use it?
    https://docs.graylog.org/en/3.3/pages/sidecar.html
  2. Didn’t you setup TLS for Beans input? If yes, try to turn it off and test.
Hi
Thank you for your useful and valuable guidence
sidecar for the Winlogbeat is OK and it Receive my Messages
But the main issue is how i can config the Sidecar for the PACKETBEAT?
I try a lot to find a way to do it but I didn’t success
I didn’t yet activate TLS
he @bahram
you need to configure the collector. I would clone the filebeat collector, and adjust the settings and the default configuration (and the binaries) to match filebeat.
BUT, that is not needed to have sidecar controlling packetbeat. The beat is not able to speak with the input - what input did you create in Graylog? Does the output configuration match the settings of the input?
Hi jan
tanks a lot for replay
Jan , please explain more about this sentence .
/I would clone the filebeat collector, and adjust the settings and the default configuration (and the binaries) to match filebeat./
thank you
**this is file Packetbeat Configuration on windows server 2016 **
#################### Packetbeat Configuration Example #########################
# This file is an example configuration file highlighting only the most common
# options. The packetbeat.reference.yml file from the same directory contains all the
# supported options with more comments. You can use it as a reference.
# You can find the full configuration reference here:
# https://www.elastic.co/guide/en/beats/packetbeat/index.html
# =============================== Network device ===============================
# Select the network interface to sniff the data. On Linux, you can use the
# “any” keyword to sniff on all connected interfaces.
packetbeat.interfaces.device: 0
# =================================== Flows ====================================
# Set enabled: false or comment out all options to disable flows reporting.
packetbeat.flows:
** # Set network flow timeout. Flow is killed if no packet is received before being**
** # timed out.**
** timeout: 30s**
** # Configure reporting period. If set to -1, only killed flows will be reported**
** period: 10s**
# =========================== Transaction protocols ============================
packetbeat.protocols:
- type: icmp
** # Enable ICMPv4 and ICMPv6 monitoring. Default: false**
** enabled: true**
- type: amqp
** # Configure the ports where to listen for AMQP traffic. You can disable**
** # the AMQP protocol by commenting out the list of ports.**
** ports: [5672]**
- type: cassandra
** #Cassandra port for traffic monitoring.**
** ports: [9042]**
- type: dhcpv4
** # Configure the DHCP for IPv4 ports.**
** ports: [67, 68]**
- type: dns
** # Configure the ports where to listen for DNS traffic. You can disable**
** # the DNS protocol by commenting out the list of ports.**
** ports: [53]**
- type: http
** # Configure the ports where to listen for HTTP traffic. You can disable**
** # the HTTP protocol by commenting out the list of ports.**
** ports: [80, 8080, 8000, 5000, 8002]**
- type: memcache
** # Configure the ports where to listen for memcache traffic. You can disable**
** # the Memcache protocol by commenting out the list of ports.**
** ports: [11211]**
- type: mysql
** # Configure the ports where to listen for MySQL traffic. You can disable**
** # the MySQL protocol by commenting out the list of ports.**
** ports: [3306,3307]**
- type: pgsql
** # Configure the ports where to listen for Pgsql traffic. You can disable**
** # the Pgsql protocol by commenting out the list of ports.**
** ports: [5432]**
- type: redis
** # Configure the ports where to listen for Redis traffic. You can disable**
** # the Redis protocol by commenting out the list of ports.**
** ports: [6379]**
- type: thrift
** # Configure the ports where to listen for Thrift-RPC traffic. You can disable**
** # the Thrift-RPC protocol by commenting out the list of ports.**
** ports: [9090]**
- type: mongodb
** # Configure the ports where to listen for MongoDB traffic. You can disable**
** # the MongoDB protocol by commenting out the list of ports.**
** ports: [27017]**
- type: nfs
** # Configure the ports where to listen for NFS traffic. You can disable**
** # the NFS protocol by commenting out the list of ports.**
** ports: [2049]**
- type: tls
** # Configure the ports where to listen for TLS traffic. You can disable**
** # the TLS protocol by commenting out the list of ports.**
** ports:**
** - 443 # HTTPS**
** - 993 # IMAPS**
** - 995 # POP3S**
** - 5223 # XMPP over SSL**
** - 8443**
** - 8883 # Secure MQTT**
** - 9243 # Elasticsearch**
# ======================= Elasticsearch template setting =======================
setup.template.settings:
** index.number_of_shards: 1**
** #index.codec: best_compression**
** #_source.enabled: false**
# ================================== General ===================================
# The name of the shipper that publishes the network data. It can be used to group
# all the transactions sent by a single shipper in the web interface.
#name:
# The tags of the shipper are included in their own field with each
# transaction published.
#tags: [“service-X”, “web-tier”]
# Optional fields that you can specify to add additional information to the
# output.
#fields:
# env: staging
# ================================= Dashboards =================================
# These settings control loading the sample dashboards to the Kibana index. Loading
# the dashboards is disabled by default and can be enabled either by setting the
# options here or by using the setup command.
setup.dashboards.enabled: true
# The URL from where to download the dashboards archive. By default this URL
# has a value which is computed based on the Beat name and version. For released
# versions, this URL points to the dashboard archive on the artifacts.elastic.co
# website.
#setup.dashboards.url:
# =================================== Kibana ===================================
# Starting with Beats version 6.0.0, the dashboards are loaded via the Kibana API.
# This requires a Kibana endpoint configuration.
setup.kibana:
** # Kibana Host**
** # Scheme and port can be left out and will be set to the default (http and 5601)**
** # In case you specify and additional path, the scheme is required: http://localhost:5601/path**
** # IPv6 addresses should always be defined as: https://[2001:db8::1]:5601**
** #host: “localhost:5601”**
** # Kibana Space ID**
** # ID of the Kibana Space into which the dashboards should be loaded. By default,**
** # the Default Space will be used.**
** #space.id:**
# =============================== Elastic Cloud ================================
# These settings simplify using Packetbeat with the Elastic Cloud (https://cloud.elastic.co/).
# The cloud.id setting overwrites the output.elasticsearch.hosts and
# setup.kibana.host options.
# You can find the cloud.id in the Elastic Cloud web UI.
#cloud.id:
# The cloud.auth setting overwrites the output.elasticsearch.username and
# output.elasticsearch.password settings. The format is <user>:<pass>.
#cloud.auth:
# ================================== Outputs ===================================
# Configure what output to use when sending the data collected by the beat.
# ---------------------------- Elasticsearch Output ----------------------------
#output.elasticsearch:
** # Array of hosts to connect to.**
** hosts: [“192.168.19.128:9200”]**
** # Protocol - either http (default) or https.**
** #protocol: “https”**
** # Authentication credentials - either API key or username/password.**
** #api_key: “id:api_key”**
** #username: “elastic”**
** #password: “changeme”**
# ------------------------------ Logstash Output -------------------------------
output.logstash:
** # The Logstash hosts**
** hosts: [“192.168.19.128:5044”]**
** # Optional SSL. By default is off.**
** # List of root certificates for HTTPS server verifications**
** #ssl.certificate_authorities: ["/etc/pki/root/ca.pem"]**
** # Certificate for SSL client authentication**
** #ssl.certificate: “/etc/pki/client/cert.pem”**
** # Client Certificate Key**
** #ssl.key: “/etc/pki/client/cert.key”**
# ================================= Processors =================================
# Configure processors to enhance or manipulate events generated by the beat.
processors:
** - add_host_metadata: ~**
** - add_cloud_metadata: ~**
** - add_docker_metadata: ~**
# ================================== Logging ===================================
# Sets log level. The default log level is info.
# Available log levels are: error, warning, info, debug
logging.level: debug
# At debug level, you can selectively enable logging only for some components.
# To enable all selectors use ["*"]. Examples of other selectors are “beat”,
# “publish”, “service”.
#logging.selectors: ["*"]
# ============================= X-Pack Monitoring ==============================
# Packetbeat can export internal metrics to a central Elasticsearch monitoring
# cluster. This requires xpack monitoring to be enabled in Elasticsearch. The
# reporting is disabled by default.
# Set to true to enable the monitoring reporter.
#monitoring.enabled: false
# Sets the UUID of the Elasticsearch cluster under which monitoring data for this
# Packetbeat instance will appear in the Stack Monitoring UI. If output.elasticsearch
# is enabled, the UUID is derived from the Elasticsearch cluster referenced by output.elasticsearch.
#monitoring.cluster_uuid:
# Uncomment to send the metrics to Elasticsearch. Most settings from the
# Elasticsearch output are accepted here as well.
# Note that the settings should point to your Elasticsearch monitoring cluster.
# Any setting that is not set is automatically inherited from the Elasticsearch
# output configuration, so if you have the Elasticsearch output configured such
# that it is pointing to your Elasticsearch monitoring cluster, you can simply
# uncomment the following line.
#monitoring.elasticsearch:
# ================================= Migration ==================================
# This allows to enable 6.7 migration aliases
#migration.6_to_7.enabled: true
and sidecar.yml file config :slightly_smiling_face:
# The URL to the Graylog server API.
# Default: "http://127.0.0.1:9000/api/"
server_url: "http://192.168.19.128:9000/api"
# The API token to use to authenticate against the Graylog server API.
# Default: none
server_api_token: "xxxxxxxxxxxxxxx"
# The node ID of the sidecar. This can be a path to a file or an ID string.
# If set to a file and the file doesn’t exist, the sidecar will generate an
# unique ID and writes it to the configured path.
# Example file path: "file:C:\Program Files\Graylog\sidecar\node-id"
# Example ID string: "6033137e-d56b-47fc-9762-cd699c11a5a9"
# ATTENTION: Every sidecar instance needs a unique ID!
# Default: "file:C:\Program Files\Graylog\sidecar\node-id"
node_id: "file:C:\Program Files\Graylog\sidecar\node-id"
# The node name of the sidecar. If this is empty, the sidecar will use the
# hostname of the host it is running on.
# Default: ""
node_name: "webostan"
# The update interval in secods. This configures how often the sidecar will
# contact the Graylog server for keep-alive and configuration update requests.
# Default: 10
update_interval: 10
# This configures if the sidecar should skip the verification of TLS connections.
# Default: false
tls_skip_verify: false
# This enables/disables the transmission of detailed sidecar information like
# collector statues, metrics and log file lists. It can be disabled to reduce
# load on the Graylog server if needed. (disables some features in the server UI)
# Default: true
send_status: true
# A list of directories to scan for log files. The sidecar will scan each
# directory for log files and submits them to the server on each update.
# Example:
# list_log_files:
# - "/var/log/nginx"
# - "/opt/app/logs"
# Default: empty list
#list_log_files: []
# Directory where the sidecar stores internal data.
#cache_path: "C:\Program Files\Graylog\sidecar\cache"
# Directory where the sidecar stores logs for collectors and the sidecar itself.
#log_path: "C:\Program Files\Graylog\sidecar\logs"
# The maximum size of the log file before it gets rotated.
log_rotate_max_file_size: "10MiB"
# The maximum number of old log files to retain.
log_rotate_keep_files: 10
# Directory where the sidecar generates configurations for collectors.
#collector_configuration_directory: "C:\Program Files\Graylog\sidecar\generated"
# A list of binaries which are allowed to be executed by the Sidecar. An empty list disables the whitelist feature.
# Wildcards can be used, for a full pattern description see https://golang.org/pkg/path/filepath/#Match
# Example:
# collector_binaries_whitelist:
# "C:\Program Files\Graylog\sidecar\winlogbeat.exe"
# "C:\Program Files\Filebeat\filebeat.exe"
# "C:\Program Files\nxlog\nxlog.exe"
# Example disable whitelisting:
# collector_binaries_whitelist: "c:\Program Files\nxlog\nxlog.exe"
Default:
Collector_binaries_whitelist:
# - "c:\Program Files\nxlog\nxlog.exe"
# - "C:\Program Files\Graylog\sidecar\filebeat.exe"
** - “C:\Program Files\Graylog\sidecar\winlogbeat.exe”**
# - "C:\Program Files\Filebeat\filebeat.exe"
** - “C:\Program Files\Packetbeat\packetbeat.exe”**
** - “C:\Program Files\Metricbeat\metricbeat.exe”**
# - "C:\Program Files\Heartbeat\heartbeat.exe"
# - "C:\Program Files\Auditbeat\auditbeat.exe"
# - "C:\Program Files\nxlog\nxlog.exe"
I created input “beat” on port 5044 in graylog server for Packetbeat.
but how to checking output configuration match the settings of the input?
Help me please
on system > sidecar > configuration
you need to create a log collector for packetbeat and adjust the settings. After that you can pick that collector for the configuration and assign it to a host.
Hi jan
Tanks a lot for replay
I create log collector for packetbeat , As shown in the image below
packetbeat File config
Needed for Graylog
fields_under_root: true
path:
data: C:\Program Files\Graylog\sidecar\cache\packetbeat\data
tags:
  • windows
packetbeat.interfaces:
device: 0
http:
ports: ports: [80]
output:
logstash:
hosts: [“192.168.0.57:5044”]
graylog:~$ sudo tail -f /var/log/graylog-server/server.log
2020-07-16T12:28:35.191Z ERROR [AbstractTcpTransport] Error in Input [Beats/5f102d2e77c19d0140017d06] (channel [id: 0xe7f3b10c, L:/192.168.0.57:5044 ! R:/192.168.0.3:51473]) (cause io.netty.channel.unix.Errors$NativeIoException: syscall:read(…) failed: Connection reset by peer)
2020-07-16T12:28:35.191Z ERROR [AbstractTcpTransport] Error in Input [Beats/5f102d2e77c19d0140017d06] (channel [id: 0x24208837, L:/192.168.0.57:5044 ! R:/192.168.0.3:51472]) (cause io.netty.channel.unix.Errors$NativeIoException: syscall:read(…) failed: Connection reset by peer) :pensive:
sidecar ===> log
time=“2020-07-16T15:58:07+04:30” level=info msg="[Packetbeat] Configuration change detected, rewriting configuration file."
time=“2020-07-16T15:58:07+04:30” level=error msg="[Packetbeat] Couldn’t execute collector C:\Program Files\packetbeat\packetbeat.exe, binary path is not included in collector_binaries_whitelist' config option." time="2020-07-16T15:58:17+04:30" level=info msg="[Packetbeat] Got remote start command" time="2020-07-16T15:58:17+04:30" level=error msg="[Packetbeat] Couldn't execute collector C:\\Program Files\\packetbeat\\packetbeat.exe, binary path is not included in collector_binaries_whitelist’ config option."
time=“2020-07-16T15:58:17+04:30” level=error msg="[Packetbeat] Couldn’t execute collector C:\Program Files\packetbeat\packetbeat.exe, binary path is not included in collector_binaries_whitelist' config option." time="2020-07-16T16:13:00+04:30" level=info msg="[Packetbeat] Got remote start command" time="2020-07-16T16:13:00+04:30" level=error msg="[Packetbeat] Couldn't execute collector C:\\Program Files\\packetbeat\\packetbeat.exe, binary path is not included in collector_binaries_whitelist’ config option."
time=“2020-07-16T16:13:00+04:30” level=error msg="[Packetbeat] Couldn’t execute collector C:\Program Files\packetbeat\packetbeat.exe, binary path is not included in collector_binaries_whitelist' config option." time="2020-07-16T16:13:08+04:30" level=info msg="Stopping signal distributor" time="2020-07-16T16:13:08+04:30" level=info msg="[Packetbeat] Stopping" time="2020-07-16T16:13:08+04:30" level=error msg="[Packetbeat] Could not access service graylog-collector-Packetbeat: The specified service does not exist as an installed service." time="2020-07-16T16:13:09+04:30" level=info msg="Starting signal distributor" time="2020-07-16T16:13:19+04:30" level=info msg="Adding process runner for: Packetbeat" time="2020-07-16T16:13:19+04:30" level=info msg="[Packetbeat] Configuration change detected, rewriting configuration file." time="2020-07-16T16:13:19+04:30" level=error msg="[Packetbeat] Couldn't execute collector C:\\Program Files\\packetbeat\\packetbeat.exe, binary path is not included in collector_binaries_whitelist’ config option."
time=“2020-07-16T16:14:40+04:30” level=info msg=“Stopping signal distributor”
time=“2020-07-16T16:14:40+04:30” level=info msg="[Packetbeat] Stopping"
time=“2020-07-16T16:14:40+04:30” level=error msg="[Packetbeat] Could not access service graylog-collector-Packetbeat: The specified service does not exist as an installed service."
time=“2020-07-16T16:14:58+04:30” level=info msg=“Starting signal distributor”
time=“2020-07-16T16:15:08+04:30” level=info msg=“Adding process runner for: Packetbeat”
time=“2020-07-16T16:15:08+04:30” level=info msg="[Packetbeat] Configuration change detected, rewriting configuration file."
time=“2020-07-16T16:15:08+04:30” level=error msg="[Packetbeat] Couldn’t execute collector C:\Program Files\packetbeat\packetbeat.exe, binary path is not included in collector_binaries_whitelist' config option." time="2020-07-16T16:37:02+04:30" level=info msg="[Packetbeat] Configuration change detected, rewriting configuration file." time="2020-07-16T16:37:02+04:30" level=error msg="[Packetbeat] Couldn't execute collector C:\\Program Files\\packetbeat\\packetbeat.exe, binary path is not included in collector_binaries_whitelist’ config option."
time=“2020-07-16T16:37:22+04:30” level=info msg=“Removing process runner: Packetbeat”
time=“2020-07-16T16:37:22+04:30” level=info msg=“No configurations assigned to this instance. Skipping configuration request.”
time=“2020-07-16T16:38:03+04:30” level=info msg=“Adding process runner for: Packetbeat”
time=“2020-07-16T16:38:03+04:30” level=info msg="[Packetbeat] Configuration change detected, rewriting configuration file."
time=“2020-07-16T16:38:03+04:30” level=error msg="[Packetbeat] Couldn’t execute collector C:\Program Files\packetbeat\packetbeat.exe, binary path is not included in collector_binaries_whitelist' config option." time="2020-07-16T16:38:13+04:30" level=info msg="[Packetbeat] Got remote start command" time="2020-07-16T16:38:13+04:30" level=error msg="[Packetbeat] Couldn't execute collector C:\\Program Files\\packetbeat\\packetbeat.exe, binary path is not included in collector_binaries_whitelist’ config option."
time=“2020-07-16T16:38:13+04:30” level=error msg="[Packetbeat] Couldn’t execute collector C:\Program Files\packetbeat\packetbeat.exe, binary path is not included in collector_binaries_whitelist' config option." time="2020-07-16T16:47:28+04:30" level=info msg="Stopping signal distributor" time="2020-07-16T16:47:28+04:30" level=info msg="[Packetbeat] Stopping" time="2020-07-16T16:47:28+04:30" level=error msg="[Packetbeat] Could not access service graylog-collector-Packetbeat: The specified service does not exist as an installed service." time="2020-07-16T16:48:02+04:30" level=info msg="Starting signal distributor" time="2020-07-16T16:48:12+04:30" level=info msg="Adding process runner for: Packetbeat" time="2020-07-16T16:48:12+04:30" level=info msg="[Packetbeat] Configuration change detected, rewriting configuration file." time="2020-07-16T16:48:12+04:30" level=error msg="[Packetbeat] Couldn't execute collector C:\\Program Files\\packetbeat\\packetbeat.exe, binary path is not included in collector_binaries_whitelist’ config option."
time=“2020-07-16T16:48:42+04:30” level=info msg=“Removing process runner: Packetbeat”
time=“2020-07-16T16:48:42+04:30” level=info msg=“No configurations assigned to this instance. Skipping configuration request.”
time=“2020-07-16T16:48:52+04:30” level=info msg=“Adding process runner for: Packetbeat”
time=“2020-07-16T16:48:52+04:30” level=info msg="[Packetbeat] Configuration change detected, rewriting configuration file."
time=“2020-07-16T16:48:52+04:30” level=error msg="[Packetbeat] Couldn’t execute collector C:\Program Files\packetbeat\packetbeat.exe, binary path is not included in `collector_binaries_whitelist’ config option."
you should really READ the log messages:
Configure the whitelist in the sidecar configuration on the host where you want to collect the data from and it will work.
**OK **
**jan, Tanks a lot **
problem solved :grinning:
**config Sidecar.yml **
server_url: "http://192.168.x.x:9000/api"
# Default: none
server_api_token: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
# Default: ""
node_name: "WEB"
# Default: 10
update_interval: 10
# Default: false
# Default: true
send_status: true
list_log_files:
collector_id: file:C:\Program Files\Graylog\sidecar\collector-id
cache_path: C:\Program Files\Graylog\sidecar\cache
log_path: C:\Program Files\Graylog\sidecar\logs
log_rotation_time: 86400
log_max_age: 604800
tags: [windows]
collector_binaries_whitelist: []
backends:
** - name: packetbeat**
** enabled: true**
** binary_path: C:\Program Files (x86)\packetbeat\packetbeat.exe**
** configuration_path: C:\Program Files\Graylog\sidecar\packetbeat.yml**
** - name: nxlog**
** enabled: false**
** binary_path: C:\Program Files (x86)\nxlog\nxlog.exe**
** configuration_path: C:\Program Files\Graylog\sidecar\generated\nxlog.conf**
** - name: winlogbeat**
** enabled: false**
** binary_path: C:\Program Files\Graylog\sidecar\winlogbeat.exe**
** configuration_path: C:\Program Files\Graylog\sidecar\generated\winlogbeat.yml**
** - name: filebeat**
** enabled: false**
** binary_path: C:\Program Files\Graylog\sidecar\filebeat.exe**
** configuration_path: C:\Program Files\Graylog\sidecar\generated\filebeat.yml**
** - name: auditbeat**
** enabled: false**
** binary_path: C:\Program Files\Graylog\sidecar\auditbeat.exe**
** configuration_path: C:\Program Files\Graylog\sidecar\generated\auditbeat.yml**
