Wildcard Search Issue
Hi !
Based on Wildcard search question i have tried to figure out the exact problem what we have with wildcardsearches on fields.
I will try to explain the behaviour.
Environment: Graylog 2.1.3
We send via gelf two messages with a field called application with the values “jto” and “JCR”.
If we search now
application:jto → Result
application:jT* → Result !
As i understand, the field will not be analyzed so the value should be stored as it comes and therefore jT* should bring no results.
Is it true that graylog will lower the search value if you put a * on the end of the value ?
If i perform following search direct via ElasticSearch i get no results.
“query”: {
“bool”: {
“must”: [
“wildcard”: {
“application”: “jT*”
“must_not”: ,
“should”:
“from”: 0,
“size”: 10,
“sort”: ,
“aggs”: { }
The second search:
application:JCR → Result
application:JC* → No Result
Also here it looks like that graylog will lower the value and therefore the search will get no results.
If i perform following search direct via ElasticSearch i get results.
“query”: {
“bool”: {
“must”: [
“wildcard”: {
“application”: “JC*”
“must_not”: ,
“should”:
“from”: 0,
“size”: 10,
“sort”: ,
“aggs”: { }
but if i try this search i get No Results
“query”: {
“bool”: {
“must”: [
“wildcard”: {
“application”: “jc*”
“must_not”: ,
“should”:
“from”: 0,
“size”: 10,
“sort”: ,
“aggs”: { }
Can somebody give some feedback please to my assumption.
Claus
Claus,
I think I just experienced the same issue on our environment (2.2.2).
My example is much the same - we have a field that contains a space separated list of usernames. I wanted to build dashboards showing record counts for each user.
If the username is lowercase, the search for myfield:username works exactly as expected.
If the username has an uppercase letter, the search for myfield:UserName returns no records.
I converted the data for “myfield” to lowercase as it comes in to graylog so the searches work as expected, but was excited to see it was identified as a potential issue.
Dustin
Hi Graylog Team !
Is it possible to get a feedback to my question please ??
thanks
claus
Note that leading wildcards are disabled to avoid excessive memory consumption! You can enable them in your Graylog configuration file:
Hi !
My Question has nothing to do with leading wildarcds :wink:
greets
claus
Experiencing the rather pernicious Uppercase search issue on 2.4.3 as well. While I understand the underlying cause might be rooted to Elastic / Lucene - it nevertheless affects the usability of Graylog to a fairly high degree.
Uppercase happens…
