Wich log forwarder for syslog listening and output compression for a low bandwich? [resolved logstash and GELF output]
Hi eveyrone,
need advise for chosing a log forwarder who can listening syslog and have an output who can compress and forward to graylog.
Logstah have a syslog input and GELF output but no information about compression :slightly_smiling_face:
https://www.elastic.co/guide/en/logstash/current/plugins-outputs-gelf.html
SSL support is not an obligation.
Thanks :wink:
here is some information about GELF, all information what you need.
http://docs.graylog.org/en/2.5/pages/gelf.html
I wouldn’t use UDP only for compression.
Maybe beats output?
https://www.elastic.co/guide/en/beats/filebeat/current/logstash-output.html
Thanks @macko003.
i have choose a different solution, using logstash with GELF Output and it’s works well.
There is an exemple for the community of a logstash configuration file for listening syslog and compress it with GELF thought UDP :
input {
  udp {
    port => 514
    type => "syslog"
filter {
  if [type] == "syslog" {
    grok {
      match => { "message" => "%{SYSLOGTIMESTAMP:syslog_timestamp} %{SYSLOGHOST:syslog_hostname} %{DATA:syslog_program}(?:\[%{POSINT:syslog_pid}\])?: %{GREEDYDATA:syslog_message}" }
      add_field => [ "received_at", "%{@timestamp}" ]
      add_field => [ "received_from", "%{host}" ]
    date {
      match => [ "syslog_timestamp", "MMM  d HH:mm:ss", "MMM dd HH:mm:ss" ]
output {
gelf {
        host => "GRAYLOG IP"
        port => 514
just need to install the GELF output plugin for logstash by :
logstash-plugin install logstash-output-gelf
ok, but you wrote
Based on the docs, GELF over TCP doesn’t support compression.
The Graylog Extended Log Format (GELF) is a log format that avoids the shortcomings of classic plain syslog:
        Limited to length of 1024 bytes – Not much space for payloads like backtraces
        No data types in structured syslog. You don’t know what is a number and what is a string.
        The RFCs are strict enough but there are so many syslog dialects out there that you cannot possibly parse all of them.
        No compression
Yes you right,
but by default UDP is using on logstash GELF output :wink: .
https://www.elastic.co/guide/en/logstash/current/plugins-outputs-gelf.html#plugins-outputs-gelf-protocol
