GELF input truncate message to 1064 bytes
Hello !
I’m trying to transfer logs from syslog-ng to graylog via tcp.
First, I used syslog-ng’s “syslog” output to transfer logs to graylog. However, my logs were cut to 1064 bytes. Reading the documentation, I found out that the GELF input is supposed to solve this problem.
https://go2docs.graylog.org/5-0/getting_in_log_data/gelf.html
I now use syslog-ng’s graylog2 output to transfer my logs and GELF tcp input on graylog.
Except that my logs are still cut off at 1064 bytes …
I try to use the template(“$(gelf-format)”) on syslog-ng but that doesn’t seem to solve the problem.
Am I missing something ?
Thank you
Hi @mobarzik
If you are sending logs with GELF, then this could help on the sensig side in your config:
<Extension gelf>
    Module xm_gelf
 ShortMessageLength 65536
</Extension>
sc6
Hi @Arie
Thanks for your reply !
I’m not sure where I’m supposed to put the configuration you gave me.
<Extension gelf>
    Module xm_gelf
</Extension>
Can you give me more details ?
@mobarzik
should look something like this
root # vi /etc/nxlog.conf
<Extension gelf>
    Module xm_gelf
</Extension>
<Input in>
    Module       im_file
    FILE         "/var/log/messages"
    SavePos       TRUE
    ReadFromLast  TRUE
    PollInterval  1
 </Input>
<Output out>
    Module      om_udp
    Host        graylog.domain.com
    Port        5044
    OutputType  GELF_UDP
    #Exec $raw_event = $raw_event;
</Output>
<Route>
    Path        in => out
</Route>
Hi @gsmith,
I don’t have nxlog installed on my server.
I really think it’s a Graylog issue. When I configure syslog-ng to write the logs it receives to a file, I get the whole line, untruncated. Once in Graylog, this line is truncated to 1064 bytes.
Furthermore, on another infrastructure I maintain, with the exact same syslog-ng configuration, graylog does not truncate messages with syslog udp input. I’ve compared all the configuration files (syslog-ng and graylog), and they’re the same.
in addition, I did a little of tcpdump -A to see the data received at each step (syslog-ng in port, graylog in port). I can confirm that syslog-ng sends non-truncated messages to graylog.
I must admit I’m a bit confused…
Hi @mobarzik
At first you realy need a syslog input for this, where as a GELF input is for
a specific message format.
Than you could look at the settings for this port and check if max message size is set
max_message_size: 2097152
After that there could be a system limitation that could shorten your message to 1064 bytes,
this should normally be 4k.
https://www.google.com/search?client=firefox-b-d&q=linux+set+tcp+receive+buffer+size
Good luck,
Arie
