cdeng
(Charles Deng)
1
For giving the port access permission to nginx for proxying gelf by the following commands:
semanage port -a -t <port_type> -p udp 12201
semanage port -a -t <port_type> -p tcp 12202
which <port_type> should be used for gelf over udp and gelf over tcp ?
jochen
(Jochen)
2
You can check the available SELinux port types with the following commands:
# semanage port -l
See also:
cdeng
(Charles Deng)
3
do you mean use any of udp port types exists for udp and any of tcp port types exists for tcp should be ok ?
jochen
(Jochen)
4
No, please read the referenced blog post.
cdeng
(Charles Deng)
5
I have no idea how it help me… when i try to added a permissive domain and failed. maybe i need a fully go through semange to see how it works.
system
(system)
Closed
6
