I installed clean (new, not upgraded) Graylog 4.0.8 and forwarded some logs. Everything is fine until here But I Created a dashboard and save after reopen dashboard = loading…
How can I solve this problem. I try chrome and firefox and same problem on both.
Sorry your having a difficult time but we dont get paid to help out other Grayloger’s. Most of us have day/night jobs.
I’m assuming you created a dashbaord and now it stuck on loading. Might be a configuration issue or permission issue.
I would have liked to help you out but the lack of infornation in about your environment or configurations you made would have helped. It would have been great ifyou could share what has been tried. That way we are not repeating troubleshooting tip.
Sorry for the delay, I was away for week. I need to ask some more questions, I not sure exactly what could be the issue.
I know you said it a fresh install, but do you have all plugins the same version? Just checking.
How did you install Graylog, was it an OVA, Docker, or package (YUM, Deb, etc…)?
Are you using a reverse proxy (i.e., Nginx, Apache)?
Do you have firewall enabled? If so, are all the correct port allowed.
Is Selinux enabled or something similar? If so, have you tried to disable it or put it in passive mode?
What kind of resources do you have in CPU, Memory, and Volume? When the dashboard is stuck on loading have you tried to use TOP maybe it might be a resource issue.
How about permission on Graylog Directory? Maybe double check
chown graylog:graylog -R /etc/graylog/
Do you see anything in Elasticsearch, MongoDb, and Graylog Logs that may pertain to this issue?
http_enable_gzip, have you tries to comment this line out and restart graylog service? elasticsearch_hosts = I don’t see this setting in your configuration file.
We installed graylog with package on ubuntu.
No,we don’t use reverse proxy.
Firewall disable on ubuntu.
SeLinux is Disable.
No resource problem. CPU,MEM,Disk etc.
“chown graylog:graylog -R /etc/graylog/” I gave authorization again, no change.
“elasticsearch_host” When comment is left, it defaults to localhost.
I change it.
“http_enable_gzip = true” I made a comment.
Elasticsearch, MongoDb, and Graylog; There are some errors in the logs, but I don’t know if it’s normal. where are the important logs, if you direct me I can share the logs. Because the problem persists.
Just out of curiousity, when you made changes to the files, did you restart your service?
This is one of my Lab Graylog servers config file. I have 12 cores so my config file was adjusted.
Everything is the same except the IP address. I am using internal IP 192.168.1.17. Elasticsearch “elasticsearch_hosts” default localhost and “network.host:” in default setting.
How many CPU’s are you using for your server?
When the dashboard is loading what do to see when monitoring your system using TOP or something similar?
Have you tried a different browser like firefox or Internet explorer?
