I wanted to copy a message from one stream to another hence creating a below pipeline however this is not giving me error while creating rule and giving me a cross . I think the rule is perfectly fine however its not accepting the rule.
rule "route dns messages to network"
has_field ("action")
let dnsfw = clone_message();
route_to_stream (id: “6211ef931aa74820e4dee1a0”, message: "dnsfw", remove_from_default: "false");
If you hover your mouse over the red X it will give you a hint about what it doesn’t like. You can post that here to if the next point doesn’t solve it…
Next point: You have the wrong quotes around the id: portion It looks like this:
when it should be this:
Which happens to me all-the-time when I am copying and pasting something…
