Welcome page-IOException encountered while reading from a byte array input stream
After upgrading from 5.1.8 to 5.2.1, the Welcome page no longer lists Last Opened or Favorite Items, and displays these errors at the bottom:
Loading favorite items failed with status: FetchError: There was an error fetching a resource: Internal Server Error. Additional information: IOException encountered while reading from a byte array input stream
Loading last opened items failed with status: FetchError: There was an error fetching a resource: Internal Server Error. Additional information: IOException encountered while reading from a byte array input stream
  • OS Information: Ubuntu 20.04.6 LTS
  • Package Version: 5.2.1
    server.log:
2023-11-30T19:10:24.039Z ERROR [AnyExceptionClassMapper] Unhandled exception in REST resource
java.lang.RuntimeException: IOException encountered while reading from a byte array input stream
        at org.mongojack.internal.stream.JacksonDBDecoder.decode(JacksonDBDecoder.java:67) ~[graylog.jar:?]
        at com.mongodb.DBDecoderAdapter.decode(DBDecoderAdapter.java:49) ~[graylog.jar:?]
        at com.mongodb.DBDecoderAdapter.decode(DBDecoderAdapter.java:29) ~[graylog.jar:?]
        at com.mongodb.internal.operation.CommandResultArrayCodec.decode(CommandResultArrayCodec.java:52) ~[graylog.jar:?]
        at com.mongodb.internal.operation.CommandResultDocumentCodec.readValue(CommandResultDocumentCodec.java:60) ~[graylog.jar:?]
        at org.bson.codecs.BsonDocumentCodec.decode(BsonDocumentCodec.java:87) ~[graylog.jar:?]
        at org.bson.codecs.BsonDocumentCodec.decode(BsonDocumentCodec.java:42) ~[graylog.jar:?]
        at org.bson.internal.LazyCodec.decode(LazyCodec.java:53) ~[graylog.jar:?]
        at org.bson.codecs.BsonDocumentCodec.readValue(BsonDocumentCodec.java:104) ~[graylog.jar:?]
        at com.mongodb.internal.operation.CommandResultDocumentCodec.readValue(CommandResultDocumentCodec.java:63) ~[graylog.jar:?]
        at com.mongodb.internal.connection.ReplyMessage.<init>(ReplyMessage.java:50) ~[graylog.jar:?]
        at com.mongodb.internal.connection.InternalStreamConnection.getCommandResult(InternalStreamConnection.java:538) ~[graylog.jar:?]
        at com.mongodb.internal.connection.InternalStreamConnection.receiveCommandMessageResponse(InternalStreamConnection.java:423) ~[graylog.jar:?]
        at com.mongodb.internal.connection.InternalStreamConnection.sendAndReceive(InternalStreamConnection.java:340) ~[graylog.jar:?]
        at com.mongodb.internal.connection.UsageTrackingInternalConnection.sendAndReceive(UsageTrackingInternalConnection.java:116) ~[graylog.jar:?]
        at com.mongodb.internal.connection.DefaultConnectionPool$PooledConnection.sendAndReceive(DefaultConnectionPool.java:643) ~[graylog.jar:?]
        at com.mongodb.internal.connection.CommandProtocolImpl.execute(CommandProtocolImpl.java:71) ~[graylog.jar:?]
        at com.mongodb.internal.connection.DefaultServer$DefaultServerProtocolExecutor.execute(DefaultServer.java:206) ~[graylog.jar:?]
        at com.mongodb.internal.connection.DefaultServerConnection.executeProtocol(DefaultServerConnection.java:119) ~[graylog.jar:?]
        at com.mongodb.internal.connection.DefaultServerConnection.command(DefaultServerConnection.java:85) ~[graylog.jar:?]
        at com.mongodb.internal.connection.DefaultServerConnection.command(DefaultServerConnection.java:75) ~[graylog.jar:?]
        at com.mongodb.internal.connection.DefaultServer$OperationCountTrackingConnection.command(DefaultServer.java:293) ~[graylog.jar:?]
        at com.mongodb.internal.operation.CommandOperationHelper.createReadCommandAndExecute(CommandOperationHelper.java:233) ~[graylog.jar:?]
        at com.mongodb.internal.operation.FindOperation.lambda$execute$1(FindOperation.java:332) ~[graylog.jar:?]
        at com.mongodb.internal.operation.OperationHelper.lambda$withSourceAndConnection$0(OperationHelper.java:356) ~[graylog.jar:?]
        at com.mongodb.internal.operation.OperationHelper.withSuppliedResource(OperationHelper.java:381) ~[graylog.jar:?]
        at com.mongodb.internal.operation.OperationHelper.lambda$withSourceAndConnection$1(OperationHelper.java:355) ~[graylog.jar:?]
        at com.mongodb.internal.operation.OperationHelper.withSourceAndConnection(OperationHelper.java:354) ~[graylog.jar:?]
        at com.mongodb.internal.operation.FindOperation.lambda$execute$2(FindOperation.java:329) ~[graylog.jar:?]
        at com.mongodb.internal.async.function.RetryingSyncSupplier.get(RetryingSyncSupplier.java:67) ~[graylog.jar:?]
        at com.mongodb.internal.operation.FindOperation.execute(FindOperation.java:340) ~[graylog.jar:?]
        at com.mongodb.internal.operation.FindOperation.execute(FindOperation.java:79) ~[graylog.jar:?]
        at com.mongodb.client.internal.MongoClientDelegate$DelegateOperationExecutor.execute(MongoClientDelegate.java:191) ~[graylog.jar:?]
        at com.mongodb.client.internal.MongoClientDelegate$DelegateOperationExecutor.execute(MongoClientDelegate.java:168) ~[graylog.jar:?]
        at com.mongodb.DBCursor.initializeCursor(DBCursor.java:810) ~[graylog.jar:?]
        at com.mongodb.DBCursor.hasNext(DBCursor.java:163) ~[graylog.jar:?]
        at org.mongojack.DBCursor.hasNext(DBCursor.java:255) ~[graylog.jar:?]
        at java.util.Iterator.forEachRemaining(Unknown Source) ~[?:?]
        at java.util.Spliterators$IteratorSpliterator.forEachRemaining(Unknown Source) ~[?:?]
        at java.util.stream.AbstractPipeline.copyInto(Unknown Source) ~[?:?]
        at java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source) ~[?:?]
        at java.util.stream.ReduceOps$ReduceOp.evaluateSequential(Unknown Source) ~[?:?]
        at java.util.stream.AbstractPipeline.evaluate(Unknown Source) ~[?:?]
        at java.util.stream.ReferencePipeline.collect(Unknown Source) ~[?:?]
        at org.graylog.events.contentpack.facade.EventDefinitionFacade.listEntityExcerpts(EventDefinitionFacade.java:177) ~[graylog.jar:?]
        at org.graylog2.contentpacks.ContentPackService.lambda$listAllEntityExcerpts$3(ContentPackService.java:331) ~[graylog.jar:?]
        at com.google.common.collect.ImmutableList.forEach(ImmutableList.java:422) ~[graylog.jar:?]
        at org.graylog2.contentpacks.ContentPackService.listAllEntityExcerpts(ContentPackService.java:331) ~[graylog.jar:?]
        at org.graylog2.contentpacks.ContentPackService.getEntityExcerpts(ContentPackService.java:336) ~[graylog.jar:?]
        at com.google.common.base.Suppliers$ExpiringMemoizingSupplier.get(Suppliers.java:261) ~[graylog.jar:?]
        at org.graylog2.lookup.Catalog.getEntry(Catalog.java:50) ~[graylog.jar:?]
        at org.graylog.plugins.views.startpage.title.StartPageItemTitleRetriever.retrieveTitle(StartPageItemTitleRetriever.java:62) ~[graylog.jar:?]
        at org.graylog.plugins.views.favorites.FavoritesService.lambda$findFavoritesFor$2(FavoritesService.java:69) ~[graylog.jar:?]
        at java.util.stream.ReferencePipeline$3$1.accept(Unknown Source) ~[?:?]
        at java.util.stream.ReferencePipeline$2$1.accept(Unknown Source) ~[?:?]
        at java.util.ArrayList$ArrayListSpliterator.forEachRemaining(Unknown Source) ~[?:?]
        at java.util.stream.AbstractPipeline.evaluateToArrayNode(Unknown Source) ~[?:?]
        at java.util.stream.ReferencePipeline.toArray(Unknown Source) ~[?:?]
        at java.util.stream.ReferencePipeline.toList(Unknown Source) ~[?:?]
        at org.graylog.plugins.views.favorites.FavoritesService.findFavoritesFor(FavoritesService.java:73) ~[graylog.jar:?]
        at org.graylog.plugins.views.favorites.FavoritesResource.getFavoriteItems(FavoritesResource.java:64) ~[graylog.jar:?]
        at jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
        at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) ~[?:?]
        at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) ~[?:?]
        at java.lang.reflect.Method.invoke(Unknown Source) ~[?:?]
        at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory.lambda$static$0(ResourceMethodInvocationHandlerFactory.java:52) ~[graylog.jar:?]
        at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:134) ~[graylog.jar:?]
        at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:177) ~[graylog.jar:?]
        at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$TypeOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:219) ~[graylog.jar:?]
        at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:81) ~[graylog.jar:?]
        at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:478) ~[graylog.jar:?]
        at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:400) ~[graylog.jar:?]
        at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:81) ~[graylog.jar:?]
        at org.glassfish.jersey.server.ServerRuntime$1.run(ServerRuntime.java:255) [graylog.jar:?]
        at org.glassfish.jersey.internal.Errors$1.call(Errors.java:248) [graylog.jar:?]
        at org.glassfish.jersey.internal.Errors$1.call(Errors.java:244) [graylog.jar:?]
        at org.glassfish.jersey.internal.Errors.process(Errors.java:292) [graylog.jar:?]
        at org.glassfish.jersey.internal.Errors.process(Errors.java:274) [graylog.jar:?]
        at org.glassfish.jersey.internal.Errors.process(Errors.java:244) [graylog.jar:?]
        at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:265) [graylog.jar:?]
        at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:234) [graylog.jar:?]
        at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:684) [graylog.jar:?]
        at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.service(GrizzlyHttpContainer.java:356) [graylog.jar:?]
        at org.glassfish.grizzly.http.server.HttpHandler$1.run(HttpHandler.java:200) [graylog.jar:?]
        at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:180) [graylog.jar:?]
        at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [?:?]
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [?:?]
        at java.lang.Thread.run(Unknown Source) [?:?]
Caused by: com.fasterxml.jackson.databind.JsonMappingException: Null field
 at [Source: de.undercouch.bson4jackson.io.LittleEndianInputStream@7731d550; pos: 390] (through reference chain: org.graylog.events.processor.$AutoValue_EventDefinitionDto$Builder["config"]->org.graylog.events.processor.aggregation.AutoValue_AggregationEventProcessorConfig$Builder["series"]->java.util.ArrayList[0]->org.graylog.plugins.views.search.searchtypes.pivot.series.AutoValue_Cardinality$Builder["field"])
        at com.fasterxml.jackson.databind.JsonMappingException.from(JsonMappingException.java:276) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.SettableBeanProperty._throwAsIOE(SettableBeanProperty.java:630) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.SettableBeanProperty._throwAsIOE(SettableBeanProperty.java:618) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.impl.MethodProperty.deserializeSetAndReturn(MethodProperty.java:173) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.BuilderBasedDeserializer.deserializeFromObject(BuilderBasedDeserializer.java:338) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.BuilderBasedDeserializer.deserialize(BuilderBasedDeserializer.java:240) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.jsontype.impl.AsPropertyTypeDeserializer._deserializeTypedForId(AsPropertyTypeDeserializer.java:170) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.jsontype.impl.AsPropertyTypeDeserializer.deserializeTypedFromObject(AsPropertyTypeDeserializer.java:136) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.AbstractDeserializer.deserializeWithType(AbstractDeserializer.java:263) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.std.CollectionDeserializer._deserializeFromArray(CollectionDeserializer.java:361) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.std.CollectionDeserializer.deserialize(CollectionDeserializer.java:244) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.std.CollectionDeserializer.deserialize(CollectionDeserializer.java:28) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.impl.MethodProperty.deserializeSetAndReturn(MethodProperty.java:158) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.impl.MethodProperty.deserializeSetAndReturn(MethodProperty.java:167) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.BuilderBasedDeserializer.vanillaDeserialize(BuilderBasedDeserializer.java:293) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.BuilderBasedDeserializer.deserialize(BuilderBasedDeserializer.java:217) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.DefaultDeserializationContext.readRootValue(DefaultDeserializationContext.java:323) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.ObjectMapper._readValue(ObjectMapper.java:4801) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.ObjectMapper.readValue(ObjectMapper.java:3043) ~[graylog.jar:?]
        at org.mongojack.internal.stream.JacksonDBDecoder.decode(JacksonDBDecoder.java:80) ~[graylog.jar:?]
        at org.mongojack.internal.stream.JacksonDBDecoder.decode(JacksonDBDecoder.java:64) ~[graylog.jar:?]
        ... 94 more
Caused by: java.lang.NullPointerException: Null field
        at org.graylog.plugins.views.search.searchtypes.pivot.series.AutoValue_Cardinality$Builder.field(AutoValue_Cardinality.java:118) ~[graylog.jar:?]
        at jdk.internal.reflect.GeneratedMethodAccessor390.invoke(Unknown Source) ~[?:?]
        at com.fasterxml.jackson.databind.deser.impl.MethodProperty.deserializeSetAndReturn(MethodProperty.java:170) ~[graylog.jar:?]
        ... 94 more
server.log continued:
2023-11-30T19:10:24.074Z ERROR [AnyExceptionClassMapper] Unhandled exception in REST resource
        at org.graylog.plugins.views.startpage.StartPageService.lambda$findLastOpenedFor$1(StartPageService.java:72) ~[graylog.jar:?]
        at java.util.ArrayList$ArrayListSpliterator.tryAdvance(Unknown Source) ~[?:?]
        at java.util.stream.ReferencePipeline.forEachWithCancel(Unknown Source) ~[?:?]
        at java.util.stream.AbstractPipeline.copyIntoWithCancel(Unknown Source) ~[?:?]
        at org.graylog.plugins.views.startpage.StartPageService.findLastOpenedFor(StartPageService.java:77) ~[graylog.jar:?]
        at org.graylog.plugins.views.startpage.StartPageResource.getLastOpened(StartPageResource.java:67) ~[graylog.jar:?]
 at [Source: de.undercouch.bson4jackson.io.LittleEndianInputStream@a9b1724; pos: 390] (through reference chain: org.graylog.events.processor.$AutoValue_EventDefinitionDto$Builder["config"]->org.graylog.events.processor.aggregation.AutoValue_AggregationEventProcessorConfig$Builder["series"]->java.util.ArrayList[0]->org.graylog.plugins.views.search.searchtypes.pivot.series.AutoValue_Cardinality$Builder["field"])
        ... 95 more
        ... 95 more
The start page is trying to list the last opened items for the current user.
In the course of this, it enumerates event definitions shared with that user; and is unable to load one of them.
That looks like a back-compat bug introduced in Enable `percentage`/`percentile` metrics for event definitions. by dennisoelkers · Pull Request #15863 · Graylog2/graylog2-server · GitHub
I filed an issue: Possible regression in 5.2 due to migration V20230629140000_RenameFieldTypeOfEventDefinitionSeries · Issue #17551 · Graylog2/graylog2-server · GitHub
As a workaround, you could try to identify the offending event definition and delete/recreate it.
Event definitions, wouldn’t have made that connection. Looks like you may be on to something. Hadn’t been under the Alerts tab yet.
Alerts & Events subtab doesn’t finish loading, gives:
Fetching event definitions failed with status: FetchError: There was an error fetching a resource: Internal Server Error. Additional information: IOException encountered while reading from a byte array input stream.
Event definitions subtab gives:
Loading Event Definitions failed with status: FetchError: There was an error fetching a resource: Internal Server Error. Additional information: IOException encountered while reading from a byte array input stream.
and page shows:
Loading component failed: Cannot destructure property 'elements' of 'u' as it is undefined.
server.log from Alerts & Events:
2023-12-01T16:43:31.495Z ERROR [AnyExceptionClassMapper] Unhandled exception in REST resource
        at java.util.stream.ReduceOps$5.evaluateSequential(Unknown Source) ~[?:?]
        at java.util.stream.ReferencePipeline.count(Unknown Source) ~[?:?]
        at org.graylog2.database.PaginatedDbService.findPaginatedWithQueryFilterAndSortWithGrandTotal(PaginatedDbService.java:200) ~[graylog.jar:?]
        at org.graylog2.database.PaginatedDbService.findPaginatedWithQueryFilterAndSort(PaginatedDbService.java:181) ~[graylog.jar:?]
        at org.graylog.events.processor.DBEventDefinitionService.searchPaginated(DBEventDefinitionService.java:65) ~[graylog.jar:?]
        at org.graylog.events.rest.EventDefinitionsResource.list(EventDefinitionsResource.java:222) ~[graylog.jar:?]
 at [Source: de.undercouch.bson4jackson.io.LittleEndianInputStream@2c80d297; pos: 390] (through reference chain: org.graylog.events.processor.$AutoValue_EventDefinitionDto$Builder["config"]->org.graylog.events.processor.aggregation.AutoValue_AggregationEventProcessorConfig$Builder["series"]->java.util.ArrayList[0]->org.graylog.plugins.views.search.searchtypes.pivot.series.AutoValue_Cardinality$Builder["field"])
        ... 79 more
        at jdk.internal.reflect.GeneratedMethodAccessor353.invoke(Unknown Source) ~[?:?]
        ... 79 more
server.log from Event Definitions:
2023-12-01T16:44:22.970Z ERROR [AnyExceptionClassMapper] Unhandled exception in REST resource
        at org.graylog.events.rest.EventDefinitionsResource.getPage(EventDefinitionsResource.java:189) ~[graylog.jar:?]
        at jdk.internal.reflect.GeneratedMethodAccessor391.invoke(Unknown Source) ~[?:?]
 at [Source: de.undercouch.bson4jackson.io.LittleEndianInputStream@7a63b0f2; pos: 390] (through reference chain: org.graylog.events.processor.$AutoValue_EventDefinitionDto$Builder["config"]->org.graylog.events.processor.aggregation.AutoValue_AggregationEventProcessorConfig$Builder["series"]->java.util.ArrayList[0]->org.graylog.plugins.views.search.searchtypes.pivot.series.AutoValue_Cardinality$Builder["field"])
        ... 78 more
        ... 78 more
2023-12-01T16:44:23.999Z ERROR [AnyExceptionClassMapper] Unhandled exception in REST resource
 at [Source: de.undercouch.bson4jackson.io.LittleEndianInputStream@1119d011; pos: 390] (through reference chain: org.graylog.events.processor.$AutoValue_EventDefinitionDto$Builder["config"]->org.graylog.events.processor.aggregation.AutoValue_AggregationEventProcessorConfig$Builder["series"]->java.util.ArrayList[0]->org.graylog.plugins.views.search.searchtypes.pivot.series.AutoValue_Cardinality$Builder["field"])
        ... 78 more
Unfortunately nothing there to uniquely identify the offending event definition. But based on the stack trace it looks like it is an aggregation that uses the card() function. That might help narrow it down.
Sure enough. I reverted my snapshot and found an Event Definition that mistakenly had card() instead of count() in the condition. Performed the upgrade to 5.2.1 again and everything appears to be good. Thanks for pointing me in the right direction.
Thanks for reporting back - glad you solved it.
It’s still a bug that a definition with card() got broken. We will address that.
