IOEXception when checking alerts
Graylog version: Graylog 5.2.2+8eab621
I get a red field indicating an error when trying to check alerts.
Error in Browser:
Could not retrieve event definitions Fetching event definitions failed with status: FetchError: There was an error fetching a resource: Internal Server Error. Additional information: IOException encountered while reading from a byte array input stream
Corresponding stacktrace in Log:
2024-01-11T14:46:46.976+01:00 ERROR [AnyExceptionClassMapper] Unhandled exception in REST resource
java.lang.RuntimeException: IOException encountered while reading from a byte array input stream
        at org.mongojack.internal.stream.JacksonDBDecoder.decode(JacksonDBDecoder.java:67) ~[graylog.jar:?]
        at com.mongodb.DBDecoderAdapter.decode(DBDecoderAdapter.java:49) ~[graylog.jar:?]
        at com.mongodb.DBDecoderAdapter.decode(DBDecoderAdapter.java:29) ~[graylog.jar:?]
        at com.mongodb.internal.operation.CommandResultArrayCodec.decode(CommandResultArrayCodec.java:52) ~[graylog.jar:?]
        at com.mongodb.internal.operation.CommandResultDocumentCodec.readValue(CommandResultDocumentCodec.java:60) ~[graylog.jar:?]
        at org.bson.codecs.BsonDocumentCodec.decode(BsonDocumentCodec.java:87) ~[graylog.jar:?]
        at org.bson.codecs.BsonDocumentCodec.decode(BsonDocumentCodec.java:42) ~[graylog.jar:?]
        at org.bson.internal.LazyCodec.decode(LazyCodec.java:53) ~[graylog.jar:?]
        at org.bson.codecs.BsonDocumentCodec.readValue(BsonDocumentCodec.java:104) ~[graylog.jar:?]
        at com.mongodb.internal.operation.CommandResultDocumentCodec.readValue(CommandResultDocumentCodec.java:63) ~[graylog.jar:?]
        at com.mongodb.internal.connection.ReplyMessage.<init>(ReplyMessage.java:50) ~[graylog.jar:?]
        at com.mongodb.internal.connection.InternalStreamConnection.getCommandResult(InternalStreamConnection.java:538) ~[graylog.jar:?]
        at com.mongodb.internal.connection.InternalStreamConnection.receiveCommandMessageResponse(InternalStreamConnection.java:423) ~[graylog.jar:?]
        at com.mongodb.internal.connection.InternalStreamConnection.sendAndReceive(InternalStreamConnection.java:340) ~[graylog.jar:?]
        at com.mongodb.internal.connection.UsageTrackingInternalConnection.sendAndReceive(UsageTrackingInternalConnection.java:116) ~[graylog.jar:?]
        at com.mongodb.internal.connection.DefaultConnectionPool$PooledConnection.sendAndReceive(DefaultConnectionPool.java:643) ~[graylog.jar:?]
        at com.mongodb.internal.connection.CommandProtocolImpl.execute(CommandProtocolImpl.java:71) ~[graylog.jar:?]
        at com.mongodb.internal.connection.DefaultServer$DefaultServerProtocolExecutor.execute(DefaultServer.java:206) ~[graylog.jar:?]
        at com.mongodb.internal.connection.DefaultServerConnection.executeProtocol(DefaultServerConnection.java:119) ~[graylog.jar:?]
        at com.mongodb.internal.connection.DefaultServerConnection.command(DefaultServerConnection.java:85) ~[graylog.jar:?]
        at com.mongodb.internal.connection.DefaultServerConnection.command(DefaultServerConnection.java:75) ~[graylog.jar:?]
        at com.mongodb.internal.connection.DefaultServer$OperationCountTrackingConnection.command(DefaultServer.java:293) ~[graylog.jar:?]
        at com.mongodb.internal.operation.CommandOperationHelper.createReadCommandAndExecute(CommandOperationHelper.java:233) ~[graylog.jar:?]
        at com.mongodb.internal.operation.FindOperation.lambda$execute$1(FindOperation.java:332) ~[graylog.jar:?]
        at com.mongodb.internal.operation.OperationHelper.lambda$withSourceAndConnection$0(OperationHelper.java:356) ~[graylog.jar:?]
        at com.mongodb.internal.operation.OperationHelper.withSuppliedResource(OperationHelper.java:381) ~[graylog.jar:?]
        at com.mongodb.internal.operation.OperationHelper.lambda$withSourceAndConnection$1(OperationHelper.java:355) ~[graylog.jar:?]
        at com.mongodb.internal.operation.OperationHelper.withSourceAndConnection(OperationHelper.java:354) ~[graylog.jar:?]
        at com.mongodb.internal.operation.FindOperation.lambda$execute$2(FindOperation.java:329) ~[graylog.jar:?]
        at com.mongodb.internal.async.function.RetryingSyncSupplier.get(RetryingSyncSupplier.java:67) ~[graylog.jar:?]
        at com.mongodb.internal.operation.FindOperation.execute(FindOperation.java:340) ~[graylog.jar:?]
        at com.mongodb.internal.operation.FindOperation.execute(FindOperation.java:79) ~[graylog.jar:?]
        at com.mongodb.client.internal.MongoClientDelegate$DelegateOperationExecutor.execute(MongoClientDelegate.java:191) ~[graylog.jar:?]
        at com.mongodb.client.internal.MongoClientDelegate$DelegateOperationExecutor.execute(MongoClientDelegate.java:168) ~[graylog.jar:?]
        at com.mongodb.DBCursor.initializeCursor(DBCursor.java:810) ~[graylog.jar:?]
        at com.mongodb.DBCursor.hasNext(DBCursor.java:163) ~[graylog.jar:?]
        at org.mongojack.DBCursor.hasNext(DBCursor.java:255) ~[graylog.jar:?]
        at java.util.Iterator.forEachRemaining(Unknown Source) ~[?:?]
        at java.util.Spliterators$IteratorSpliterator.forEachRemaining(Unknown Source) ~[?:?]
        at java.util.stream.AbstractPipeline.copyInto(Unknown Source) ~[?:?]
        at java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source) ~[?:?]
        at java.util.stream.ReduceOps$ReduceOp.evaluateSequential(Unknown Source) ~[?:?]
        at java.util.stream.ReduceOps$5.evaluateSequential(Unknown Source) ~[?:?]
        at java.util.stream.AbstractPipeline.evaluate(Unknown Source) ~[?:?]
        at java.util.stream.ReferencePipeline.count(Unknown Source) ~[?:?]
        at org.graylog2.database.PaginatedDbService.findPaginatedWithQueryFilterAndSortWithGrandTotal(PaginatedDbService.java:200) ~[graylog.jar:?]
        at org.graylog2.database.PaginatedDbService.findPaginatedWithQueryFilterAndSort(PaginatedDbService.java:181) ~[graylog.jar:?]
        at org.graylog.events.processor.DBEventDefinitionService.searchPaginated(DBEventDefinitionService.java:65) ~[graylog.jar:?]
        at org.graylog.events.rest.EventDefinitionsResource.list(EventDefinitionsResource.java:222) ~[graylog.jar:?]
        at jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
        at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) ~[?:?]
        at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) ~[?:?]
        at java.lang.reflect.Method.invoke(Unknown Source) ~[?:?]
        at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory.lambda$static$0(ResourceMethodInvocationHandlerFactory.java:52) ~[graylog.jar:?]
        at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:134) ~[graylog.jar:?]
        at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:177) ~[graylog.jar:?]
        at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$TypeOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:219) ~[graylog.ja>
        at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:81) ~[graylog.jar:?]
        at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:478) ~[graylog.jar:?]
        at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:400) ~[graylog.jar:?]
        at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:81) ~[graylog.jar:?]
        at org.glassfish.jersey.server.ServerRuntime$1.run(ServerRuntime.java:255) [graylog.jar:?]
        at org.glassfish.jersey.internal.Errors$1.call(Errors.java:248) [graylog.jar:?]
        at org.glassfish.jersey.internal.Errors$1.call(Errors.java:244) [graylog.jar:?]
        at org.glassfish.jersey.internal.Errors.process(Errors.java:292) [graylog.jar:?]
        at org.glassfish.jersey.internal.Errors.process(Errors.java:274) [graylog.jar:?]
        at org.glassfish.jersey.internal.Errors.process(Errors.java:244) [graylog.jar:?]
        at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:265) [graylog.jar:?]
        at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:234) [graylog.jar:?]
        at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:684) [graylog.jar:?]
        at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.service(GrizzlyHttpContainer.java:356) [graylog.jar:?]
        at org.glassfish.grizzly.http.server.HttpHandler$1.run(HttpHandler.java:200) [graylog.jar:?]
        at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:180) [graylog.jar:?]
        at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [?:?]
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [?:?]
        at java.lang.Thread.run(Unknown Source) [?:?]
Caused by: com.fasterxml.jackson.databind.JsonMappingException: Null field
 at [Source: de.undercouch.bson4jackson.io.LittleEndianInputStream@8b4d45; pos: 316] (through reference chain: org.graylog.events.processor.$AutoValue_EventDefinitionDto$Builde>
        at com.fasterxml.jackson.databind.JsonMappingException.from(JsonMappingException.java:276) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.SettableBeanProperty._throwAsIOE(SettableBeanProperty.java:630) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.SettableBeanProperty._throwAsIOE(SettableBeanProperty.java:618) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.impl.MethodProperty.deserializeSetAndReturn(MethodProperty.java:173) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.BuilderBasedDeserializer.deserializeFromObject(BuilderBasedDeserializer.java:338) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.BuilderBasedDeserializer.deserialize(BuilderBasedDeserializer.java:240) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.jsontype.impl.AsPropertyTypeDeserializer._deserializeTypedForId(AsPropertyTypeDeserializer.java:170) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.jsontype.impl.AsPropertyTypeDeserializer.deserializeTypedFromObject(AsPropertyTypeDeserializer.java:136) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.AbstractDeserializer.deserializeWithType(AbstractDeserializer.java:263) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.std.CollectionDeserializer._deserializeFromArray(CollectionDeserializer.java:361) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.std.CollectionDeserializer.deserialize(CollectionDeserializer.java:244) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.std.CollectionDeserializer.deserialize(CollectionDeserializer.java:28) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.impl.MethodProperty.deserializeSetAndReturn(MethodProperty.java:158) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.impl.MethodProperty.deserializeSetAndReturn(MethodProperty.java:167) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.BuilderBasedDeserializer.vanillaDeserialize(BuilderBasedDeserializer.java:293) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.BuilderBasedDeserializer.deserialize(BuilderBasedDeserializer.java:217) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.DefaultDeserializationContext.readRootValue(DefaultDeserializationContext.java:323) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.ObjectMapper._readValue(ObjectMapper.java:4801) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.ObjectMapper.readValue(ObjectMapper.java:3043) ~[graylog.jar:?]
        at org.mongojack.internal.stream.JacksonDBDecoder.decode(JacksonDBDecoder.java:80) ~[graylog.jar:?]
        at org.mongojack.internal.stream.JacksonDBDecoder.decode(JacksonDBDecoder.java:64) ~[graylog.jar:?]
        ... 79 more
Caused by: java.lang.NullPointerException: Null field
        at org.graylog.plugins.views.search.searchtypes.pivot.series.AutoValue_Sum$Builder.field(AutoValue_Sum.java:118) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.impl.MethodProperty.deserializeSetAndReturn(MethodProperty.java:170) ~[graylog.jar:?]
        ... 79 more
Is this something that just recently started to happen in your cluster or has this been a problem for some time?
The error is pointing me in the direction of there being an error in one of the event definitions.
Also, do you happen to have any custom graylog plugins installed?
If there is an event definition with formatting issues, its possible to review these via graylog’s MongoDB database. You can export the events collection using the following command:
mongoexport --collection=event_definitions --db=graylog --out=event_definitions.json
If you feel comfortable sharing the output, we may be able to spot the issue.
Thanks.
But I don’t know what would qualify as custom plugin in this context.
Graylog Plugins:
Threat Intelligence Lookup
AWS
Geo-Location Processor
Sharing those should not be an issue without names and description.
Regex for the sanitized fields: “[A-Za-z ]*”
So I think we can be fairly certain that no strange character in there caused the problem.
there is very little as it only was for testing so far, but names and descriptions where already close to production.
{“_id”:{“$oid”:“628b89b102f3e719b540683d”},“title”:“clear”,“description”:“clear”,“priority”:3,“alert”:true,“config”:{“type”:“aggregation-v1”,“query”:“”,“query_parameters”:,“streams”:[“619ce5b986ec512199078eaf”],“group_by”:,“series”:[{“id”:“sum-”,“field”:null,“type”:“sum”}],“conditions”:{“expression”:{“expr”:“>”,“left”:{“expr”:“number-ref”,“ref”:“sum-”},“right”:{“expr”:“number”,“value”:10.0}}},“search_within_ms”:7200000,“execute_every_ms”:600000},“field_spec”:{},“key_spec”:,“notification_settings”:{“grace_period_ms”:57600000,“backlog_size”:50},“notifications”:[{“notification_id”:“628b862a02f3e719b5406467”,“notification_parameters”:null}],“storage”:[{“type”:“persist-to-streams-v1”,“streams”:[“000000000000000000000002”]}]}
{“_id”:{“$oid”:“64803e891855ce22530a1454”},“_scope”:“SYSTEM_NOTIFICATION_EVENT”,“title”:“clear”,“description”:“clear”,“updated_at”:{“$date”:“2023-06-07T08:23:37.942Z”},“priority”:1,“alert”:false,“config”:{“type”:“system-notifications-v1”},“field_spec”:{},“key_spec”:,“notification_settings”:{“grace_period_ms”:0,“backlog_size”:0},“notifications”:,“storage”:[{“type”:“persist-to-streams-v1”,“streams”:[“000000000000000000000003”]}],“state”:“ENABLED”}
Are those the only 2 event definitions you had?
The one with oid 628b89b102f3e719b540683d caught my eye here:
If you feel comfortable using the mongo command line you can try deleting the record. Note that deleting any data always carries risks and these instructions are provided as is. I tested them with Ubuntu Server 22.04 LTS and Mongo 6.0.12
  1. ssh to the server where mongodb is running
  2. run one of these commands, this will open a mongo shell and automatically select the graylog database:
    • mongo 5 or earlier: mongo graylog
    • mongo 6: mongosh graylog
  3. the terminal should show graylog> at this point. If it does not, you can run the following to select the graylog database:
    • use graylog
  4. Verify you get a result when searching for the record by its OID:
    • db.getCollection("event_definitions").find({"_id":ObjectId('628b89b102f3e719b540683d')})
    • Should return something like
  5. Delete the record by its OID:
    • db.event_definitions.deleteOne( {"_id":ObjectId('628b89b102f3e719b540683d')} )
Its possible this is realted to Event Definitions: Aggregation with `card()` or `max()` functions without fields prevents access to Events page after upgrade to `5.2.0`. · Issue #17367 · Graylog2/graylog2-server · GitHub , but i’m not 100% certain.
Did you recently upgrade to 5.2? I agree with @drewmiranda-gl that this looks like
Easiest solution is to delete the invalid event definition and recreate it.
