Web interface not working in OVA installation on VMware
I install graylog-2.3.0-1 all services are running but not able to access web interface.
output of nmap
[root@client2 ~]# nmap 10.248.14.144
Starting Nmap 5.51 ( http://nmap.org ) at 2017-08-25 16:05 IST
Nmap scan report for 10.248.14.144
Host is up (0.68s latency).
Not shown: 925 filtered ports, 73 closed ports
PORT STATE SERVICE
22/tcp open ssh
80/tcp open http
Nmap done: 1 IP address (1 host up) scanned in 149.61 seconds
output of netstat -tulnp
root@graylog:~# netstat -tulnp
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 127.0.0.1:2380 0.0.0.0:* LISTEN 894/etcd
tcp 0 0 0.0.0.0:34223 0.0.0.0:* LISTEN 896/java
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 4937/nginx.conf
tcp 0 0 10.248.14.144:9200 0.0.0.0:* LISTEN 896/java
tcp 0 0 10.248.14.144:9300 0.0.0.0:* LISTEN 896/java
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 923/sshd
tcp 0 0 0.0.0.0:33280 0.0.0.0:* LISTEN 896/java
tcp 0 0 0.0.0.0:3333 0.0.0.0:* LISTEN 896/java
tcp 0 0 0.0.0.0:27017 0.0.0.0:* LISTEN 892/mongod
tcp6 0 0 :::2379 :::* LISTEN 894/etcd
tcp6 0 0 :::22 :::* LISTEN 923/sshd
tcp6 0 0 :::4001 :::* LISTEN 894/etcd
tcp6 0 0 :::9000 :::* LISTEN 5577/java
udp 0 0 10.248.14.144:123 0.0.0.0:* 1021/ntpd
udp 0 0 127.0.0.1:123 0.0.0.0:* 1021/ntpd
udp 0 0 0.0.0.0:123 0.0.0.0:* 1021/ntpd
udp6 0 0 :::514 :::* 5577/java
udp6 0 0 :::12201 :::* 5577/java
udp6 0 0 fe80::250:56ff:feb2:123 :::* 1021/ntpd
udp6 0 0 ::1:123 :::* 1021/ntpd
udp6 0 0 :::123 :::* 1021/ntpd
root@graylog:~#
Could you please share your GL logs
root@graylog:/var/log/graylog# graylog-ctl tail
==> /var/log/graylog/server/current <==
==> /var/log/graylog/server/config <==
s209715200
n30
t86400
!gzip
==> /var/log/graylog/server/state <==
==> /var/log/graylog/etcd/current <==
==> /var/log/graylog/etcd/config <==
s209715200
n30
t86400
!gzip
==> /var/log/graylog/etcd/state <==
==> /var/log/graylog/elasticsearch/graylog.log <==
[2017-08-24T08:56:15,347][INFO ][o.e.n.Node ] [CfluYh6] starting …
[2017-08-24T08:56:15,454][INFO ][i.n.u.i.PlatformDependent] Your platform does not provide complete low-level API for accessing direct buffers reliably. Unless explicitly requested, heap buffer will always be preferred to avoid potential system instability.
[2017-08-24T08:56:15,772][INFO ][o.e.t.TransportService ] [CfluYh6] publish_address {10.248.14.144:9300}, bound_addresses {10.248.14.144:9300}
[2017-08-24T08:56:15,796][INFO ][o.e.b.BootstrapChecks ] [CfluYh6] bound or publishing to a non-loopback or non-link-local address, enforcing bootstrap checks
[2017-08-24T08:56:25,988][INFO ][o.e.c.s.ClusterService ] [CfluYh6] new_master {CfluYh6}{CfluYh6NQjKVpY96PZcOoQ}{Sk2OKjpzSk-ky7GePKtGVw}{10.248.14.144}{10.248.14.144:9300}, reason: zen-disco-elected-as-master ([0] nodes joined)
[2017-08-24T08:56:26,139][INFO ][o.e.h.n.Netty4HttpServerTransport] [CfluYh6] publish_address {10.248.14.144:9200}, bound_addresses {10.248.14.144:9200}
[2017-08-24T08:56:26,152][INFO ][o.e.n.Node ] [CfluYh6] started
[2017-08-24T08:56:26,534][INFO ][o.e.g.GatewayService ] [CfluYh6] recovered [1] indices into cluster_state
[2017-08-24T08:56:26,992][INFO ][o.e.c.r.a.AllocationService] [CfluYh6] Cluster health status changed from [RED] to [YELLOW] (reason: [shards started [[graylog_0][0], [graylog_0][1], [graylog_0][3]] …]).
[2017-08-24T09:27:39,614][INFO ][o.e.c.m.MetaDataMappingService] [CfluYh6] [graylog_0/QhbjdykySp2-KVWD3y5eaA] update_mapping [message]
==> /var/log/graylog/elasticsearch/current <==
==> /var/log/graylog/elasticsearch/graylog_deprecation.log <==
[2017-08-24T09:27:39,519][WARN ][o.e.d.i.m.TypeParsers ] Expected a boolean [true/false] for property [index] but got [not_analyzed]
[2017-08-24T09:27:39,521][WARN ][o.e.d.i.m.TypeParsers ] Expected a boolean [true/false] for property [index] but got [not_analyzed]
[2017-08-24T09:27:39,522][WARN ][o.e.d.i.m.TypeParsers ] Expected a boolean [true/false] for property [index] but got [not_analyzed]
[2017-08-24T09:27:39,523][WARN ][o.e.d.i.m.TypeParsers ] Expected a boolean [true/false] for property [index] but got [not_analyzed]
[2017-08-24T09:27:39,525][WARN ][o.e.d.i.m.TypeParsers ] Expected a boolean [true/false] for property [index] but got [not_analyzed]
[2017-08-24T09:27:39,527][WARN ][o.e.d.i.m.TypeParsers ] Expected a boolean [true/false] for property [index] but got [not_analyzed]
[2017-08-24T09:27:39,528][WARN ][o.e.d.i.m.TypeParsers ] Expected a boolean [true/false] for property [index] but got [not_analyzed]
[2017-08-24T09:27:39,530][WARN ][o.e.d.i.m.TypeParsers ] Expected a boolean [true/false] for property [index] but got [not_analyzed]
[2017-08-24T09:27:39,531][WARN ][o.e.d.i.m.TypeParsers ] Expected a boolean [true/false] for property [index] but got [not_analyzed]
[2017-08-24T09:27:39,532][WARN ][o.e.d.i.m.TypeParsers ] Expected a boolean [true/false] for property [index] but got [not_analyzed]
==> /var/log/graylog/elasticsearch/graylog_index_indexing_slowlog.log <==
==> /var/log/graylog/elasticsearch/config <==
s209715200
n30
t86400
!gzip
==> /var/log/graylog/elasticsearch/graylog_index_search_slowlog.log <==
==> /var/log/graylog/elasticsearch/state <==
==> /var/log/graylog/mongodb/current <==
==> /var/log/graylog/mongodb/config <==
s209715200
n30
t86400
!gzip
==> /var/log/graylog/mongodb/state <==
==> /var/log/graylog/nginx/current <==
==> /var/log/graylog/nginx/error.log <==
2017/08/25 10:14:04 [error] 4938#0: *16 connect() failed (111: Connection refused) while connecting to upstream, client: 10.248.2.187, server: , request: “GET / HTTP/1.1”, upstream: “http://127.0.0.1:9000/”, host: "10.248.14.144"
2017/08/25 10:14:04 [error] 4938#0: *16 connect() failed (111: Connection refused) while connecting to upstream, client: 10.248.2.187, server: , request: “GET / HTTP/1.1”, upstream: “http://[::1]:9000/”, host: "10.248.14.144"
2017/08/25 10:14:04 [error] 4938#0: *19 no live upstreams while connecting to upstream, client: 10.248.2.187, server: , request: “GET /config.js HTTP/1.1”, upstream: “http://localhost/config.js”, host: “10.248.14.144”, referrer: "http://10.248.14.144/"
2017/08/25 10:14:06 [error] 4938#0: *20 no live upstreams while connecting to upstream, client: 10.248.2.187, server: , request: “GET /assets/favicon.png HTTP/1.1”, upstream: “http://localhost/assets/favicon.png”, host: “10.248.14.144”, referrer: "http://10.248.14.144/"
2017/08/25 10:14:36 [error] 4938#0: *20 connect() failed (111: Connection refused) while connecting to upstream, client: 10.248.2.187, server: , request: “GET / HTTP/1.1”, upstream: “http://[::1]:9000/”, host: "10.248.14.144"
2017/08/25 10:14:36 [error] 4938#0: *20 connect() failed (111: Connection refused) while connecting to upstream, client: 10.248.2.187, server: , request: “GET / HTTP/1.1”, upstream: “http://127.0.0.1:9000/”, host: "10.248.14.144"
2017/08/25 10:14:36 [error] 4938#0: *23 no live upstreams while connecting to upstream, client: 10.248.2.187, server: , request: “GET /config.js HTTP/1.1”, upstream: “http://localhost/config.js”, host: “10.248.14.144”, referrer: “http://10.248.14.144/”
==> /var/log/graylog/nginx/config <==
s104857600
n5
t86400
!gzip
==> /var/log/graylog/nginx/state <==
