Hi there,
We’re running Graylog 2.0.2 on a VMWare environment as a Linux Virtual Appliance.
We tried updating to the latest available version yesterday evening, using the Graylog Omnibus package. The update itself went without a hitch, but post-update, we could not access the web interface anymore.
Before the update, we were using https://netlog.domain.com. We did not need to specify any ports or anything else.
After the update, https was not working anymore, and we had to specify port 9000 at the end of the URL or else it wasn’t working (http://netlog.domain.com:9000).
The person who configured the application is gone from our enterprise, so we have very little information on how the appliance is configured.
Is there a fix for this issue, and if so, how would I go about fixing this ?
I had initially posted this in the issues section of the GitHub page, was referred here as well as to the section about installing a custom SSL certificate. The certificate is already installed on the virtual appliance before the update, but doesn’t seem to be working after the update. Does it need to be reinstalled after each update ?
And also, I noticed that post-update the nginx service did not start back up. Does it need to be restarted manually post-update, or this means there are other issues ?
Thanks,
