mourad
February 18, 2020, 9:09pm
1
I just installed Graylog by following the documentation.
Graylog is on a dedicated server (VM) and behind a reverse proxy (Nginx).
When I enter the url, I find a blank page.
In the chrome console, I have errors:
Mixed Content: The page at ‘’ was loaded over HTTPS, but requested an insecure script ‘’. This request has been blocked; the content must be served over HTTPS
server.conf
http_external_uri = http://subdomain.mydomain.fr/
trusted_proxies = XX.XX.XX.XX/32
virtualHost
server {
server_name www.subdomain.mydomain.fr subdomain.mydomain.fr;
location / {
proxy_set_header X-Graylog-Server-URL http://$server_name/;
proxy_pass http://192.168.0.201:9000;
jan
(Jan Doberstein)
February 19, 2020, 6:55am
2
he @mourad
did you run your nginx https or http? That is missing
mourad
February 19, 2020, 9:31am
3
At the beginning, I tried in HTTP and the result was the same. Now I have installed the HTTPS certificate on the reverse proxy (with certbot --nginx).
Between reverse and VM graylog, it’s HTTP.
Thank.
jan
(Jan Doberstein)
February 19, 2020, 9:37am
4
when you have https you need to adjust that in the nginx configuration:
proxy_set_header X-Graylog-Server-URL https://$server_name/;
mourad
February 19, 2020, 9:53am
5
Thank you for that answer.
I modified the virtual host.
Now I still have a blank page, but with the following error in the chrome console:
Failed to load resource: net::ERR_NAME_NOT_RESOLVED
vendor.91c91d4a31d54d96392a.js:1 Failed to load resource: net::ERR_NAME_NOT_RESOLVED
polyfill.d5c12e9afb78da9fb1e7.js:1 Failed to load resource: net::ERR_NAME_NOT_RESOLVED
builtins.d5c12e9afb78da9fb1e7.js:1 Failed to load resource: net::ERR_NAME_NOT_RESOLVED
plugin.org.graylog.plugins.threatintel.ThreatIntelPlugin.af7c0b9d454081eb456f.js:1 Failed to load resource: net::ERR_NAME_NOT_RESOLVED
plugin.org.graylog.plugins.collector.CollectorPlugin.d07ac6288c8f9cbb7a66.js:1 Failed to load resource: net::ERR_NAME_NOT_RESOLVED
plugin.org.graylog.aws.AWSPlugin.2ddc104d2d22d32fea21.js:1 Failed to load resource: net::ERR_NAME_NOT_RESOLVED
app.d5c12e9afb78da9fb1e7.js:1 Failed to load resource: net::ERR_NAME_NOT_RESOLVED
mourad
February 19, 2020, 8:57pm
6
Since the previous modification, by looking at the chrome network tab, some files have a “failed” status
If anyone has an info.
Thank you.
jrunu
February 20, 2020, 8:34am
7
Your http_exernal_uri should be adjusted to https as well. What is the reason for the requests to fail? Presumambly it is a connection problem not a HTTP status problem. Please compare the uris of these requests (after selection one, you get detailed information about it on the right side) to what you would expect them to go to (Correct Protocol, domain/IP etc.)
mourad
February 20, 2020, 9:58am
8
I already tried to add the “s” to http_exernal_uri. The result is the same.
Here is the detail part:
Only the 1st seems ok.
I specify that I also tried the private navigation with disabled module (some forum speaks of adblock). But always the same.
Thank you
mourad
February 20, 2020, 10:20am
9
Additional information. When I test with firefox, the result is the same, but with slightly different info.
In the console, the error message is:
Failed to load for the <script> element whose source is "https://www.logs-manager.autosecuritas-dev.fr/config.js".
And in the network tab, here is the result
The message in the bubble (the one written in French) indicates:
"The connection used to retrieve this resource was not encrypted."
system
(system)
Closed
March 5, 2020, 10:20am
10
