Web Configuration of Graylog
Hello Graylog Support Team,
Thank you for all contributions for the carried questions from my side.
I would ask your attention for the images attached. On the top right side of the page, we can see In0/Out0 msg/s while I have made input and stream. It seems that the graylog does not operate since I cannot find any data in the last image and the histogram.
Any guide in this respect for me.
Kind Regards,
Just to clarify, this is the community board - not any kind of official support channel!
When you have no data incoming - check the sender and follow the trail and check on any hop if the messages pass by.
regards
Jan
Also make sure you’ve permitted the traffic through the graylog server firewall
No incoming messages and Input while the firewall is off.
No messages are passed by so it is not possible to follow them.
Graylog firewall is not active.
did you checked the settings mentioned in this guide: https://github.com/Graylog2/graylog-guide-syslog-linux
