Web access not available
How can I resolve this issue ?
    /home/ubuntu# graylog-ctl status
run: elasticsearch: (pid 731) 40s; down: log: 654s, normally up, want up
run: etcd: (pid 1163) 1s; down: log: 654s, normally up, want up
run: graylog-server: (pid 909) 654s; down: log: 654s, normally up, want up
run: mongodb: (pid 832) 35s; run: log: (pid 902) 6151s
run: nginx: (pid 28288) 3927s; down: log: 654s, normally up, want up
I tried graylog-ctl reconfigure / graylog-ctl restart
root@LOG01:/var/log/graylog/server# ls
@400000005c0798832faa27f4.s @400000005c0b41a608f54814.s config
@400000005c08ea0330d198c4.s @400000005c0f21e1180b6f04.u current
@400000005c09e39a15f325f4.u @400000005c0f2709150f3664.u lock
@400000005c09e67b2a37da8c.u @400000005c0f7601302d4274.u state
@400000005c09ef4333fd883c.u @400000005c0f8b7b091395e4.u
The problem is indicated pretty clearly:
Seems that a whole bunch of the services needed are down and not (re)starting.
The message in the browser also clearly suggests that you check the logs in /var/log/graylog/*/current. These should probably give you a hint or two. These logs are also needed if you’d like us to help.
