VMWare ESXi for Graylog
VMWare ESXi
@ddbnl
Download from Github
View on Github
Open Issues
Stargazers
Graylog content-pack for VMWare ESXi logs.
Contains:
  • Input
  • Extractors
  • Stream
  • Performance dashboard (VMotion)
  • Warnings & errors dashboard
Why is this not working? Going to system>content packs>upload and choosing the .json file gives error like check if this is a valid json file. Running graylao 4.3.2
Hey @rahulkmbl . Thanks for asking. I’m messaging the developer to see if he has a answer for you.
In the meanwhile, if other members have used VMWare ESXi, you’re welcome to join in with a response for @rahulkmbl
Same error, unfortunately. Would appreciate anyone’s insight!
full text is:
Error importing content pack, please ensure it is a valid JSON file. Check your Graylog logs for more information.
Unexpected character (‘<’ (code 60)): expected a valid value (number, String, array, object, ‘true’, ‘false’ or ‘null’) at [Source: (org.glassfish.jersey.message.internal.ReaderInterceptorExecutor$UnCloseableInputStream): line: 8, column: 21
@grroberts Thanks for posting. I’m reaching out again to @ddbnl, the developer to get his response. If you hear from him, please let the community know. Thanks!
