Views quick values
I am very new to graylog but it looks very nice ! I have got the node up and running and messages are coming in. I also installed the free enterprise license. I have looked at some video’s and have seen that it is realy easy to select thing like src / dest ip for instance and choose ( quick values )so you can really quickly see what is goin on.
I don’t see in my views how I can do that. It looks like something is missing. I am looking for enterprise views I think but that is not in the menu. The enterprise plugins are installed as far as I can tell.
thanks for your help…
Kind regards,
Olivier
You need to extract these fields (src/dest) using either extractor or pipeline rule. Check basics in docs:
https://docs.graylog.org/en/3.2/pages/extractors.html
https://docs.graylog.org/en/3.2/pages/pipelines.html
