Using extractors on forwarder inputs
I would like to configure extractors on my forwarder inputs but even though I have created the extractors, and tested them against log entries, they will not extract data.
I have noticed that if I “Show all messages” on the forwarder input (under System/Inputs) there is nothing, but if I look at the input configured on the forwarder there are logs.
  • OS Information: Ubuntu 22.04
  • Package Version:5.2
I have looked everywhere and I cannot find any info on this.
Please tell me if I have done something wrong or if this is even possible?
I don’t believe you can run extractors on forwarded inputs. You need to do the extraction in pipeline rules. Forwarder inputs are a very different animal.
Also if you want to show the received messages you want to navigate to the forwarder or forwarder profile page and launch it from there.
Thanks @Joel_Duffield!
