Hi Folks,
I have few questions, probably weird ones.
Currently, I have 1 pair of output and input under side-car collector configuration to index specific windows security logs. I am wondering what would be the use case where you have multiple inputs of nxlog under single side-car collector. Can I add another nxlog input for file input under same config?
Is it possible? How would it work? Would nxlog.conf be updated using multiple nxlog inputs under same collector config?
Also, my nxlog is managed by side-car collector, I am wondering if i have to add more functions to the nxlog config how would i go about doing it while still using side car. I don’t see much options to add more functions to nxlog using side car.
For indexing csv file or log file, out of 2 nxlog and filebeat, which one is better?
As always, thanks to all the awesome folks for being always helpful.
Cheers,
Navdeep
