Unprocessed messages during index optimization
Graylog Version: 2.4.5
Elastic Version: 5.6.9
Graylog Nodes: 8 CPUs, 32 MB RAM
Elastic Nodes: 4 CPU, 64 MB RAM
Indicies: 97, 1,816,743,448 documents, 1.7TB
We have a cluster with 2 Graylog and 4 Elastic Nodes. During index optimization, the number of unprocessed messages increases dramatically and the elastic nodes seem to slow indexing messages too much. Does anyone know a solution for this issue or have experience with customizing the index.merge.scheduler.throttle value in Elastic?
you might want to lower the refresh.index setting in your index template to something around 30seconds. This would be one option to lower the pain on elasticsearch.
regards
Jan
Hi Jan,
thanks.
I assume you mean the refresh_interval as described here
https://www.elastic.co/guide/en/elasticsearch/reference/5.6/indices-update-settings.html.
That would mean I would have to increase the interval with a cron job before optimizing and then set to default again.
Changing the index.merge.scheduler.throttle value is not a sensible permanent option ?
regards
Jürgen
He Jürgen,
you can do that, but with that I didn’t experiment much to have a valid opinion on that. Only the first one is something I do regular.
jan
ok, then i will first test your suggestion
thx
