Uneven distribution of unprocessed messages in graylog nodes
This topic Uneven distribution of unprocessed messages is insufficient for us so we require help from graylog community.
We have uneven distribution of unprocessed messages in ours graylog nodes.
9 graylog nodes:
  • Red Hat Enterprise Linux Server release 7.4 (Maipo)
  • RAM: 15G
  • CPU: 8
    7 es nodes:
  • RAM: 56G
  • CPU: 6
Graylog configurations:
server.conf
# WARNING: Maintained by Puppet, manual changes will be lost!
allow_highlighting = true
data_dir = /graylog/data
elasticsearch_hosts = http://GRAYLOG-elasticsearch.service.swmconsul:9200
elasticsearch_index_optimization_jobs = 100
elasticsearch_max_total_connections = 100
inputbuffer_processors = 2
is_master = true
message_journal_dir = /graylog/journal
message_journal_flush_interval = 1000000
message_journal_max_age = 72h
message_journal_max_size = 80g
message_journal_segment_age = 1h
mongodb_uri = mongodb://GRAYLOG-mongodb.service.swmconsul:27017/admin?replicaSet=graylog
node_id_file = /graylog/node-id
output_barch_size = 1000
outputbuffer_processors = 2
processbuffer_processors = 4
ring_size = 131072
es configurations:
elasticsearch.yml
### MANAGED BY PUPPET ###
bootstrap.memory_lock: 'true'
cluster.name: GRAYLOG-cluster
cluster.remote.connect: 'false'
discovery.zen.minimum_master_nodes: 3
discovery.zen.ping.unicast.hosts:
- graylog-esmaster1.swmcloud.net
- graylog-esmaster2.swmcloud.net
- graylog-esmaster3.swmcloud.net
- graylog-esmaster4.swmcloud.net
discovery.zen.ping.unicast.hosts.resolve_timeout: 5s
indices.breaker.accounting.limit: 50%
indices.breaker.fielddata.limit: 50%
indices.breaker.request.limit: 25%
indices.fielddata.cache.size: 60%
indices.recovery.max_bytes_per_sec: 150mb
network.breaker.inflight_requests.limit: 25%
network.host: 0.0.0.0
node.data: true
node.ingest: 'false'
node.master: false
node.name: graylog-esnode1
path.data: "/data/GRAYLOG-cluster/graylog-esnode1"
path.logs: "/var/log/elasticsearch/graylog-esnode1"
jvm.options
# This file is managed by Puppet -- graylog-esnode1
# Set the 'jvm_options' parameter on the elasticsearch class to change this file.
-Dfile.encoding=UTF-8
-Dio.netty.noKeySetOptimization=true
-Dio.netty.noUnsafe=true
-Dio.netty.recycler.maxCapacityPerThread=0
-Djava.awt.headless=true
-Djna.nosys=true
-Dlog4j.shutdownHookEnabled=false
-Dlog4j2.disable.jmx=true
-XX:+AlwaysPreTouch
-XX:+ExitOnOutOfMemoryError
-XX:+UseCMSInitiatingOccupancyOnly
-XX:-HeapDumpOnOutOfMemoryError
-XX:-OmitStackTraceInFastThrow
-XX:CMSInitiatingOccupancyFraction=75
-Xms28g
-Xmx28g
-Xss1m
-server
11-:-XX:+UseG1GC
11-:-XX:MaxGCPauseMillis=300
8:-XX:+PrintGCApplicationStoppedTime
8:-XX:+PrintGCDateStamps
8:-XX:+PrintGCDetails
8:-XX:+PrintTenuringDistribution
8:-XX:+UseConcMarkSweepGC
8:-XX:+UseGCLogFileRotation
8:-XX:GCLogFileSize=64m
8:-XX:NumberOfGCLogFiles=10
8:-Xloggc:/var/log/elasticsearch/gc.log
cluster setting:
  "persistent" : {
    "indices" : {
      "breaker" : {
        "fielddata" : {
          "limit" : "75%"
        "request" : {
          "limit" : "25%"
        "accounting" : {
          "limit" : "50%"
    "network" : {
      "breaker" : {
        "inflight_requests" : {
          "limit" : "25%"
  "transient" : { },
  "defaults" : {
    "cluster" : {
      "routing" : {
        "use_adaptive_replica_selection" : "false",
        "rebalance" : {
          "enable" : "all"
        "allocation" : {
          "node_concurrent_incoming_recoveries" : "2",
          "node_initial_primaries_recoveries" : "4",
          "same_shard" : {
            "host" : "false"
          "total_shards_per_node" : "-1",
          "type" : "balanced",
          "disk" : {
            "threshold_enabled" : "true",
            "watermark" : {
              "low" : "85%",
              "flood_stage" : "95%",
              "high" : "90%"
            "include_relocations" : "true",
            "reroute_interval" : "60s"
          "awareness" : {
            "attributes" : [ ]
          "balance" : {
            "index" : "0.55",
            "threshold" : "1.0",
            "shard" : "0.45"
          "enable" : "all",
          "node_concurrent_outgoing_recoveries" : "2",
          "allow_rebalance" : "indices_all_active",
          "cluster_concurrent_rebalance" : "2",
          "node_concurrent_recoveries" : "2"
      "indices" : {
        "tombstones" : {
          "size" : "500"
        "close" : {
          "enable" : "true"
      "nodes" : {
        "reconnect_interval" : "10s"
      "persistent_tasks" : {
        "allocation" : {
          "enable" : "all",
          "recheck_interval" : "30s"
      "blocks" : {
        "read_only_allow_delete" : "false",
        "read_only" : "false"
      "service" : {
        "slow_task_logging_threshold" : "30s"
      "name" : "GRAYLOG-cluster",
      "max_shards_per_node" : "1000",
      "remote" : {
        "node" : {
          "attr" : ""
        "initial_connect_timeout" : "30s",
        "connect" : "false",
        "connections_per_cluster" : "3"
      "info" : {
        "update" : {
          "interval" : "30s",
          "timeout" : "15s"
    "no" : {
      "model" : {
        "state" : {
          "persist" : "false"
    "logger" : {
      "level" : "INFO"
    "bootstrap" : {
      "memory_lock" : "true",
      "system_call_filter" : "true",
      "ctrlhandler" : "true"
    "processors" : "6",
    "ingest" : {
      "geoip" : {
        "cache_size" : "1000"
      "grok" : {
        "watchdog" : {
          "max_execution_time" : "1s",
          "interval" : "1s"
    "network" : {
      "host" : [
        "0.0.0.0"
      "tcp" : {
        "reuse_address" : "true",
        "keep_alive" : "true",
        "connect_timeout" : "30s",
        "receive_buffer_size" : "-1b",
        "no_delay" : "true",
        "send_buffer_size" : "-1b"
      "bind_host" : [
        "0.0.0.0"
      "server" : "true",
      "breaker" : {
          "overhead" : "1.0"
      "publish_host" : [
        "0.0.0.0"
    "pidfile" : "/var/run/elasticsearch/elasticsearch-graylog-esnode1.pid",
    "path" : {
      "data" : [
      "logs" : "/var/log/elasticsearch/graylog-esnode1",
      "shared_data" : "",
      "home" : "/usr/share/elasticsearch",
      "repo" : [ ]
    "search" : {
      "default_search_timeout" : "-1",
      "highlight" : {
        "term_vector_multi_value" : "true"
      "default_allow_partial_results" : "true",
      "max_open_scroll_context" : "2147483647",
      "max_buckets" : "-1",
      "low_level_cancellation" : "false",
      "keep_alive_interval" : "1m",
      "remote" : {
        "node" : {
          "attr" : ""
        "connect" : "true",
      "default_keep_alive" : "5m",
      "max_keep_alive" : "24h"
    "security" : {
      "manager" : {
        "filter_bad_defaults" : "true"
    "ccr" : {
      "wait_for_metadata_timeout" : "60s",
      "indices" : {
        "recovery" : {
          "recovery_activity_timeout" : "60s",
          "chunk_size" : "1mb",
          "internal_action_timeout" : "60s",
          "max_bytes_per_sec" : "40mb",
          "max_concurrent_file_chunks" : "5"
      "auto_follow" : {
    "repositories" : {
      "fs" : {
        "compress" : "false",
        "chunk_size" : "9223372036854775807b",
        "location" : ""
      "url" : {
        "supported_protocols" : [
          "http",
          "https",
          "ftp",
          "file",
          "jar"
        "allowed_urls" : [ ],
        "url" : "http:"
    "action" : {
      "auto_create_index" : "true",
      "search" : {
        "shard_count" : {
          "limit" : "9223372036854775807"
      "destructive_requires_name" : "false",
      "master" : {
        "force_local" : "false"
    "client" : {
      "type" : "node",
      "transport" : {
        "ignore_cluster_name" : "false",
        "nodes_sampler_interval" : "5s",
        "sniff" : "false",
        "ping_timeout" : "5s"
    "xpack" : {
      "watcher" : {
        "execution" : {
          "scroll" : {
            "size" : "0",
            "timeout" : ""
          "default_throttle_period" : "5s"
        "internal" : {
          "ops" : {
            "bulk" : {
              "default_timeout" : ""
            "index" : {
            "search" : {
        "thread_pool" : {
          "queue_size" : "1000",
          "size" : "30"
        "index" : {
          "rest" : {
            "direct_access" : ""
        "history" : {
          "cleaner_service" : {
            "enabled" : "true"
        "trigger" : {
          "schedule" : {
            "ticker" : {
              "tick_interval" : "500ms"
        "enabled" : "true",
        "input" : {
          "search" : {
        "encrypt_sensitive_data" : "false",
        "transform" : {
          "search" : {
        "stop" : {
          "timeout" : "30s"
        "watch" : {
          "scroll" : {
            "size" : "0"
        "require_manual_start" : "false",
        "bulk" : {
          "concurrent_requests" : "0",
          "flush_interval" : "1s",
          "size" : "1mb",
          "actions" : "1"
        "actions" : {
          "bulk" : {
          "index" : {
      "ilm" : {
        "enabled" : "true"
      "monitoring" : {
        "collection" : {
          "cluster" : {
            "stats" : {
              "timeout" : "10s"
          "node" : {
            "stats" : {
              "timeout" : "10s"
          "indices" : [ ],
          "ccr" : {
            "stats" : {
              "timeout" : "10s"
          "index" : {
            "stats" : {
              "timeout" : "10s"
            "recovery" : {
              "active_only" : "false",
              "timeout" : "10s"
          "interval" : "10s",
          "enabled" : "false",
          "ml" : {
            "job" : {
              "stats" : {
                "timeout" : "10s"
        "history" : {
          "duration" : "168h"
        "elasticsearch" : {
          "collection" : {
            "enabled" : "true"
        "enabled" : "true"
      "graph" : {
        "enabled" : "true"
      "rollup" : {
        "enabled" : "true",
        "task_thread_pool" : {
          "queue_size" : "4",
          "size" : "4"
      "sql" : {
        "enabled" : "true"
      "license" : {
        "self_generated" : {
          "type" : "basic"
      "logstash" : {
        "enabled" : "true"
      "notification" : {
        "hipchat" : {
          "host" : "",
          "port" : "443",
          "default_account" : ""
        "pagerduty" : {
        "email" : {
          "default_account" : "",
          "html" : {
            "sanitization" : {
              "allow" : [
                "body",
                "head",
                "_tables",
                "_links",
                "_blocks",
                "_formatting",
                "img:embedded"
              "disallow" : [ ],
              "enabled" : "true"
        "reporting" : {
          "retries" : "40",
          "interval" : "15s"
        "jira" : {
        "slack" : {
      "security" : {
        "dls_fls" : {
          "enabled" : "true"
        "transport" : {
          "filter" : {
            "allow" : [ ],
            "deny" : [ ],
            "enabled" : "true"
          "ssl" : {
            "enabled" : "false"
        "enabled" : "true",
        "filter" : {
          "always_allow_bound_address" : "true"
        "encryption" : {
          "algorithm" : "AES/CTR/NoPadding"
        "audit" : {
          "outputs" : [
            "logfile"
          "index" : {
            "bulk_size" : "1000",
            "rollover" : "DAILY",
            "events" : {
              "emit_request_body" : "false",
              "include" : [
                "ACCESS_DENIED",
                "ACCESS_GRANTED",
                "ANONYMOUS_ACCESS_DENIED",
                "AUTHENTICATION_FAILED",
                "REALM_AUTHENTICATION_FAILED",
                "CONNECTION_DENIED",
                "CONNECTION_GRANTED",
                "TAMPERED_REQUEST",
                "RUN_AS_DENIED",
                "RUN_AS_GRANTED",
                "AUTHENTICATION_SUCCESS"
              "exclude" : [ ]
            "queue_max_size" : "10000"
          "logfile" : {
            "emit_node_id" : "true",
            "emit_node_host_name" : "false",
            "emit_node_name" : "true",
            "events" : {
              "include" : [
                "ACCESS_DENIED",
                "ACCESS_GRANTED",
                "TAMPERED_REQUEST",
                "RUN_AS_DENIED",
                "RUN_AS_GRANTED"
              "exclude" : [ ]
            "prefix" : {
              "emit_node_host_address" : "false"
        "authc" : {
          "password_hashing" : {
            "algorithm" : "bcrypt"
          "success_cache" : {
            "size" : "10000",
            "expire_after_access" : "1h"
          "api_key" : {
            "cache" : {
              "hash_algo" : "ssha256",
              "max_keys" : "10000",
              "ttl" : "24h"
            "delete" : {
              "interval" : "24h",
              "timeout" : "-1"
            "hashing" : {
              "algorithm" : "pbkdf2"
          "anonymous" : {
            "authz_exception" : "true",
            "roles" : [ ],
            "username" : "_anonymous"
          "run_as" : {
            "enabled" : "true"
          "reserved_realm" : {
            "enabled" : "true"
          "token" : {
            "compat" : {
              "enabled" : "false"
            "delete" : {
              "interval" : "30m",
              "timeout" : "-1"
            "thread_pool" : {
              "size" : "1"
            "timeout" : "20m"
        "fips_mode" : {
          "enabled" : "false"
        "encryption_key" : {
          "length" : "128",
          "algorithm" : "AES"
        "http" : {
          "filter" : {
            "allow" : [ ],
            "deny" : [ ],
            "enabled" : "true"
          "ssl" : {
            "enabled" : "false"
        "automata" : {
          "max_determinized_states" : "100000",
          "cache" : {
            "size" : "10000",
            "ttl" : "48h",
            "enabled" : "true"
        "user" : null,
        "authz" : {
          "store" : {
            "roles" : {
              "index" : {
                "cache" : {
                  "ttl" : "20m",
                  "max_size" : "10000"
              "cache" : {
              "negative_lookup_cache" : {
              "field_permissions" : {
                "cache" : {
                  "max_size_in_bytes" : "104857600"
      "ccr" : {
        "enabled" : "true",
        "ccr_thread_pool" : {
          "queue_size" : "100",
          "size" : "32"
      "http" : {
        "default_connection_timeout" : "10s",
        "proxy" : {
          "host" : "",
          "scheme" : "",
          "port" : "0"
        "default_read_timeout" : "10s",
        "max_response_size" : "10mb"
      "ml" : {
        "utility_thread_pool" : {
          "queue_size" : "500",
          "size" : "80"
        "max_anomaly_records" : "500",
        "enable_config_migration" : "true",
        "max_open_jobs" : "20",
        "min_disk_space_off_heap" : "5gb",
        "node_concurrent_job_allocations" : "2",
        "max_model_memory_limit" : "0b",
        "enabled" : "true",
        "max_lazy_ml_nodes" : "0",
        "max_machine_memory_percent" : "30",
        "autodetect_process" : "true",
        "datafeed_thread_pool" : {
          "queue_size" : "200",
          "size" : "20"
        "process_connect_timeout" : "10s",
        "autodetect_thread_pool" : {
          "queue_size" : "80",
          "size" : "80"
    "rest" : {
      "action" : {
        "multi" : {
          "allow_explicit_index" : "true"
    "cache" : {
      "recycler" : {
        "page" : {
          "limit" : {
            "heap" : "10%"
          "type" : "CONCURRENT",
          "weight" : {
            "longs" : "1.0",
            "ints" : "1.0",
            "bytes" : "1.0",
            "objects" : "0.1"
    "reindex" : {
      "remote" : {
        "whitelist" : [ ]
    "max" : {
      "anomaly" : {
        "records" : "500"
    "resource" : {
      "reload" : {
        "enabled" : "true",
        "interval" : {
          "low" : "60s",
          "high" : "5s",
          "medium" : "30s"
    "thread_pool" : {
      "force_merge" : {
        "queue_size" : "-1",
        "size" : "1"
      "fetch_shard_started" : {
        "core" : "1",
        "max" : "12",
        "keep_alive" : "5m"
      "listener" : {
        "size" : "3"
      "index" : {
        "size" : "6"
      "refresh" : {
        "core" : "1",
        "max" : "3",
        "keep_alive" : "5m"
      "generic" : {
        "core" : "4",
        "max" : "128",
        "keep_alive" : "30s"
      "warmer" : {
        "core" : "1",
        "max" : "3",
        "keep_alive" : "5m"
      "search" : {
        "max_queue_size" : "1000",
        "size" : "10",
        "auto_queue_frame_size" : "2000",
        "target_response_time" : "1s",
        "min_queue_size" : "1000"
      "fetch_shard_store" : {
        "core" : "1",
        "max" : "12",
        "keep_alive" : "5m"
      "flush" : {
        "core" : "1",
        "max" : "3",
        "keep_alive" : "5m"
      "management" : {
        "core" : "1",
        "max" : "5",
        "keep_alive" : "5m"
      "analyze" : {
        "queue_size" : "16",
        "size" : "1"
      "get" : {
        "size" : "6"
      "bulk" : {
        "size" : "6"
      "estimated_time_interval" : "200ms",
      "write" : {
        "size" : "6"
      "snapshot" : {
        "core" : "1",
        "max" : "3",
        "keep_alive" : "5m"
      "search_throttled" : {
        "max_queue_size" : "100",
        "size" : "1",
        "auto_queue_frame_size" : "200",
        "min_queue_size" : "100"
    "index" : {
      "codec" : "default",
      "store" : {
        "type" : "",
        "fs" : {
          "fs_lock" : "native"
        "preload" : [ ]
    "monitor" : {
      "jvm" : {
        "gc" : {
          "enabled" : "true",
          "overhead" : {
            "warn" : "50",
            "debug" : "10",
            "info" : "25"
          "refresh_interval" : "1s"
      "process" : {
      "os" : {
      "fs" : {
    "transport" : {
      "tcp" : {
        "port" : "9300-9400",
      "bind_host" : [ ],
      "ping_schedule" : "-1",
      "connections_per_node" : {
        "recovery" : "2",
        "state" : "1",
        "bulk" : "3",
        "reg" : "6",
        "ping" : "1"
      "tracer" : {
        "include" : [ ],
        "exclude" : [
          "internal:discovery/zen/fd*",
          "cluster:monitor/nodes/liveness"
      "type" : "security4",
      "type.default" : "netty4",
      "features" : {
        "x-pack" : "true"
      "host" : [ ],
      "publish_port" : "-1",
      "tcp_no_delay" : "true",
      "publish_host" : [ ],
      "netty" : {
        "receive_predictor_size" : "64kb",
        "receive_predictor_max" : "64kb",
        "worker_count" : "12",
        "receive_predictor_min" : "64kb",
        "boss_count" : "1"
    "script" : {
      "allowed_contexts" : [ ],
      "max_compilations_rate" : "75/5m",
      "cache" : {
        "max_size" : "100",
        "expire" : "0ms"
      "painless" : {
        "regex" : {
          "enabled" : "false"
      "max_size_in_bytes" : "65535",
      "allowed_types" : [ ]
    "node" : {
      "data" : "true",
      "enable_lucene_segment_infos_trace" : "false",
      "local_storage" : "true",
      "max_local_storage_nodes" : "1",
      "name" : "graylog-esnode1",
      "id" : {
        "seed" : "0"
      "store" : {
        "allow_mmap" : "true",
        "allow_mmapfs" : "true"
      "attr" : {
        "xpack" : {
          "installed" : "true"
        "ml" : {
          "machine_memory" : "61165051904",
          "enabled" : "true"
      "portsfile" : "false",
      "ingest" : "false",
      "master" : "false",
      "ml" : "true"
    "indices" : {
      "cache" : {
        "cleanup_interval" : "1m"
      "mapping" : {
        "dynamic_timeout" : "30s"
      "memory" : {
        "interval" : "5s",
        "max_index_buffer_size" : "-1",
        "shard_inactive_time" : "5m",
        "index_buffer_size" : "10%",
        "min_index_buffer_size" : "48mb"
      "breaker" : {
        "request" : {
          "type" : "memory",
          "overhead" : "1.0"
        "total" : {
          "limit" : "70%"
        "accounting" : {
          "overhead" : "1.0"
        "fielddata" : {
          "type" : "memory",
          "overhead" : "1.03"
        "type" : "hierarchy"
      "query" : {
        "bool" : {
          "max_clause_count" : "1024"
        "query_string" : {
          "analyze_wildcard" : "false",
          "allowLeadingWildcard" : "true"
      "admin" : {
        "filtered_fields" : "true"
      "recovery" : {
        "recovery_activity_timeout" : "1800000ms",
        "retry_delay_network" : "5s",
        "internal_action_timeout" : "15m",
        "retry_delay_state_sync" : "500ms",
        "internal_action_long_timeout" : "1800000ms",
        "max_bytes_per_sec" : "150mb",
        "max_concurrent_file_chunks" : "1"
      "requests" : {
        "cache" : {
          "size" : "1%",
          "expire" : "0ms"
      "store" : {
        "delete" : {
          "shard" : {
            "timeout" : "30s"
      "analysis" : {
        "hunspell" : {
          "dictionary" : {
            "ignore_case" : "false",
            "lazy" : "false"
      "queries" : {
        "cache" : {
          "count" : "10000",
          "size" : "10%",
          "all_segments" : "false"
      "lifecycle" : {
        "poll_interval" : "10m"
      "fielddata" : {
        "cache" : {
          "size" : "60%"
    "plugin" : {
      "mandatory" : [ ]
    "max_running_jobs" : "20",
    "discovery" : {
      "type" : "zen",
      "zen" : {
        "commit_timeout" : "30s",
        "no_master_block" : "write",
        "join_retry_delay" : "100ms",
        "join_retry_attempts" : "3",
        "ping" : {
          "unicast" : {
            "concurrent_connects" : "10",
            "hosts" : [
              "graylog-esmaster1.swmcloud.net",
              "graylog-esmaster2.swmcloud.net",
              "graylog-esmaster3.swmcloud.net"
            "hosts.resolve_timeout" : "5s"
        "master_election" : {
          "ignore_non_master_pings" : "false",
          "wait_for_joins_timeout" : "30000ms"
        "send_leave_request" : "true",
        "ping_timeout" : "3s",
        "join_timeout" : "60000ms",
        "publish_diff" : {
          "enable" : "true"
        "publish" : {
          "max_pending_cluster_states" : "25"
        "minimum_master_nodes" : "2",
        "hosts_provider" : [ ],
        "publish_timeout" : "30s",
        "fd" : {
          "connect_on_network_disconnect" : "false",
          "ping_interval" : "1s",
          "ping_retries" : "3",
          "register_connection_listener" : "true",
          "ping_timeout" : "30s"
        "max_pings_from_another_master" : "3"
      "initial_state_timeout" : "30s"
    "tribe" : {
      "name" : "",
      "on_conflict" : "any",
      "blocks" : {
        "metadata" : "false",
        "read" : {
          "indices" : [ ]
        "write.indices" : [ ],
        "write" : "false",
        "metadata.indices" : [ ]
    "http" : {
      "cors" : {
        "max-age" : "1728000",
        "allow-origin" : "",
        "allow-headers" : "X-Requested-With,Content-Type,Content-Length",
        "allow-credentials" : "false",
        "allow-methods" : "OPTIONS,HEAD,GET,POST,PUT,DELETE",
        "enabled" : "false"
      "max_chunk_size" : "8kb",
      "compression_level" : "3",
      "max_initial_line_length" : "4kb",
      "pipelining" : "true",
      "enabled" : "true",
      "content_type" : {
        "required" : "true"
      "host" : [ ],
      "read_timeout" : "0ms",
      "max_content_length" : "100mb",
      "netty" : {
        "max_composite_buffer_components" : "69905",
      "tcp" : {
      "bind_host" : [ ],
      "reset_cookies" : "false",
      "max_warning_header_count" : "-1",
      "max_warning_header_size" : "-1b",
      "detailed_errors" : {
        "enabled" : "true"
      "port" : "9200-9300",
      "max_header_size" : "8kb",
      "pipelining.max_events" : "10000",
      "compression" : "true",
    "gateway" : {
      "recover_after_master_nodes" : "0",
      "expected_nodes" : "-1",
      "recover_after_data_nodes" : "-1",
      "expected_data_nodes" : "-1",
      "recover_after_time" : "0ms",
      "expected_master_nodes" : "-1",
      "recover_after_nodes" : "-1"
Add graylog nodes
Create multiple indices (with shards number equal es nodes number) to have a good shards distribution in elasticsearch cluster.
Create mapping template to reduce indexer failures errors.
Help use to find the root cause of uneven distribution of unprocessed messages.
Thanks for your help. :slight_smile:
Hello && welcome
I have been looking over you configurations for a couple days and correct me if I’m wrong but is this a 9 Node cluster and each node has ES. GL and MongoDb? The reason I asked this is most of the time in Graylog configurations with multiple instances of ES and MongoDb these settings would be configure like so.
elasticsearch_hosts = http://10.10.10.10:9200, http://10.10.10.11:9200, http://10.10.10.22:9200
mongodb_uri = mongodb://10.10.10.10:27017, http://10.10.10.11:27017, http://10.10.10.22:27017/graylog?replicaSet=replica01
What I’m not seeing in GL configure is this section. So I assume you made modification.
What versions of services do you have installed?
By change do you have a load balancer in from of your cluster?
Hello gsmith,
Thank you for your help.
In order to list es nodes and mongodb nodes, we use consul from hashicorps that allows to have a dynamic configuration and a nodes discovery.
Graylog version 4.2.8
Elasticsearch version: 6.8
Mongodb version: 4.2.7
For the loadbalancer, we have avi vantage that use the nodes discovery with consul.
After your comment, we analysed the load balancer and now we think that consul discovery does not do the work. Instead of our 9 graylog nodes, consul has only discovered 3 nodes.
Now the discovering from consul work but the uneven distribution persist :(.
We have 9 graylog nodes and 7 es nodes what did we configure wrong?
Thank you very much for your help.
My apologies I haven’t used avi vantage nor hashicorps so I probably wouldn’t be any help troubleshooting.
Since your using other software I’m not 100% sure where your issue could be. I could show you a mockup of what I did thou. I understand every environment is different but there are common configuration that are needed. Below is for Elasticsearch 5.x I also used these for 6.x. I cant remember but I think there were some new changes in the configuration file on 6.x.
Example:
For each node noticed how I configured each configuration file. 3 master nodes and 7 data nodes.
sudo vim /etc/elasticsearch/elasticsearch.yml
cluster.name: graylog
network.host: 10.10.10.10
http.port: 9200
node.name: lab-elastic-001
node.master: true
node.data: true
discovery.zen.ping.unicast.hosts: ["10.10.10.11","10.10.10.12","10.10.10.13",10.10.10.14,10.10.10.15,10.10.10.16]
network.host: 10.10.10.11
http.port: 9200
node.name: lab-elastic-002
node.master: true
node.data: true
discovery.zen.ping.unicast.hosts: ["10.10.10.10","10.10.10.12","10.10.10.13",10.10.10.14,10.10.10.15,10.10.10.16]
network.host: 10.10.10.12
http.port: 9200
node.name: lab-elastic-003
node.master: true
node.data: true
discovery.zen.ping.unicast.hosts: ["10.10.10.10","10.10.10.11","10.10.10.13",10.10.10.14,10.10.10.15,10.10.10.16]
network.host: 10.10.10.13
http.port: 9200
node.name: lab-elastic-004
node.master: true
node.data: true
discovery.zen.ping.unicast.hosts: ["10.10.10.10","10.10.10.11","10.10.10.12",10.10.10.14,10.10.10.15,10.10.10.16]
network.host: 10.10.10.14
http.port: 9200
node.name: lab-elastic-005
node.master: false
node.data: true
discovery.zen.ping.unicast.hosts: ["10.10.10.10","10.10.10.11","10.10.10.12",10.10.10.13,10.10.10.15,10.10.10.16]
network.host: 10.10.10.15
http.port: 9200
node.name: lab-elastic-006
node.master: false
node.data: true
discovery.zen.ping.unicast.hosts: ["10.10.10.10","10.10.10.11","10.10.10.12",10.10.10.13,10.10.10.14,10.10.10.16]
network.host: 10.10.10.16
http.port: 9200
node.name: lab-elastic-007
node.master: false
node.data: true
discovery.zen.ping.unicast.hosts: ["10.10.10.10","10.10.10.11","10.10.10.12",10.10.10.13,10.10.10.14,10.10.10.15]
Sum it up.
  • 3 Master nodes
  • 7 Data nodes
My graylog configuration file corresponds to these configurations for master nodes above.
elasticsearch_hosts = http://lab-elastic-001:9200, http://lab-elastic-002:9200, http://lab-elastic-003:9200,http://lab-elastic-004:9200
I have used nginx for load balancer but I haven’t had this issue with uneven distribution.
Not sure if that helps
Second part of my example:
This was for a three node MongoDb cluster
Only one instance runs as ‘PRIMARY’, all other instances are ‘SECONDARY’.
Data is written only on the ‘PRIMARY’ instance, the data sets are then replicated to all ‘SECONDARY’ instances.
Execute command
shell# mongo
shell# rs.initiate()
Add the ' lab-graylog-002 ' and ' lab-graylog-003 ' nodes to the replica sets.
Execute command
shell#rs.add("lab-graylog-002 ")
Shell#rs.add("lab-graylog-003 ")
## Check the replica sets status with the rs query below.
Shell# rs.status()
## Query to check the status on ‘lab-graylog-001 :
Shell# rs.isMaster()  // Should Show “isMaster” =True
NOTE: Enable reading from the 'SECONDARY' node with the query 'rs.slaveOk()'
My Graylog Configuration file corrisponds to those settings
mongodb_uri = mongodb://lab-graylog-001:27017,lab-graylog-002:27017,lab-graylog-003:27017/graylog?replicaSet=replica01
I used most of these suggestion in the documentation here.
Hope that helps
Thank you very very much gsmith.
We have identified the issue.
input gelf udp send messages to 3 nodes instead of 9.
We have also corrected a problem with the loadbalancer avi and now we have a more even distribution of messages for all inputs except for gelf udp.
But this raised a new problem, indexer failures with this message:
rejected execution of processing of [425888633][indices:data/write/bulk[s][p]]: request: BulkShardRequest [[tomcat__109][7]] containing [53] requests, target allocation id: 2Sv0bIIcR7WB9mkEZ8ZuVg, primary term: 1 on EsThreadPoolExecutor[name = graylog-esnode3/write, queue capacity = 200, org.elasticsearch.common.util.concurrent.EsThreadPoolExecutor@4596eefa[Running, pool size = 6, active threads = 6, queued tasks = 200, completed tasks = 412462213]]
I found this topic:
So, now i will try to correct the gelf udp input and the indexer failures.
If you have any tips, I’ll be happy to read them.
Thank you very much gsmith for your time.
Hello @teddy
Only thing that can come to mind is maybe raise output_batch_size to 1000 or 2000, raise outputbuffer_processor to 5 and set your index_refreshrate to 30 seconds in Elasticsearch.
EDIT:
Here is an example of my Graylog Server. I ingest about 30-40 GB message a day. This is just one node. I did have the same issue a while back. As shown below is what I stated above.
allow_highlighting = false
output_batch_size = 2000 <---- Raise
output_flush_interval = 1
processbuffer_processors = 8
outputbuffer_processors = 5 <-- Increase
In your index set “Edit” configurations
Of course when editing you GL configuration file you need to restart.
insure all the GL nodes have these configuration’s :+1:
Hope that helps
Hello @gsmith,
I have increased output_batch_size to 2000 but for other mentionned parameters, i can’t add more processors because we have a lack of resources. Right now, graylog works very well, i wait few days to analyse and adjust parameters.
Thank you for your help and your time.
Have a nice day :slight_smile:
Sound good :+1: Keep us updated.
