Unable to View Metrics
When attempting to view metrics (either node or input), there is an API error in the browser.
  • Could not fetch metrics from node: server returned api with a 500 status code.
  • Could not fetch metrics from node: server returned api with a 500 status code. Graylog
  • Could not fetch metrics from node: server returned api: Temporary failure in name resolution with a 500 status code
If I tail the server log, I see this:
2024-04-04T15:24:50.230Z WARN  [ProxiedResource] Failed to call API on node <0f0b9d45-d097-4d0f-98e6-ee3975ecc06b>, cause: api (duration: 137 ms)
2024-04-04T15:24:50.368Z WARN  [ProxiedResource] Failed to call API on node <0f0b9d45-d097-4d0f-98e6-ee3975ecc06b>, cause: api (duration: 8 ms)
2024-04-04T15:24:51.670Z WARN  [ProxiedResource] Failed to call API on node <0f0b9d45-d097-4d0f-98e6-ee3975ecc06b>, cause: api (duration: 11 ms)
We are not using HTTPS at all.
I have verified the URI settings in the server.conf and the appear to be correct.
http_bind_address = 172.16.20.15:9000
http_publish_uri = http://$http_bind_address/
http_external_uri = http://$http_bind_address/
  • OS Information: Ubuntu 22.04.2 LTS
  • Package Version: Graylog 5.1.7 (Open)
    MongoDB 6.0.5
    ES 7.10.2
Tried looking at the server.conf to see if I had any incorrect URI values. They appear to be corret.
Help me understand why I can’t access the metrics.
Hey @jfmeyer00
If you just going with HTTP you can comment these two out and restart Graylog service see if that clears it up.
Does your ES config match Graylog config?
Example:
Elasticsearch YAML file
network.host: 127.0.0.1
Graylog Configuration file
Default: https://127.0.0.1:9200
That did it. Thank you.
