I am trying to send a test data to Graylog via GELP UDP port 12201. However am getting an invalid error. Any advise will be greatly appreciated
Netcat query from one of docker container to graylog container
echo -n '{ "version": "1.1", "host": "example.org", "short_message": "A short message", "level": 5, "_some_info": "foo" }' | nc -w0 -u graylog_graylog 12201
Result
invalid wait-time 0
I am able to send logs via the GELP HTTP PORT 12201 though (after the necessary graylog input config).
My Environment Setup - Docker Swarm for AWS + AWS elasticsearch Cluster
version: '3.4'
services:
mongo:
image: mongo:3
networks:
- graylog_network
graylog:
image: graylog/graylog:3.1
environment:
- GRAYLOG_PASSWORD_SECRET=somepasswordpepper
# Password: admin
- GRAYLOG_ROOT_PASSWORD_SHA2=8c6976e5b5410415bde908bd4dee15dfb167a9c873fc4bb8a81f6f2ab448a918
- GRAYLOG_HTTP_EXTERNAL_URI=http://myaws.ap-southeast-1.elb.amazonaws.com:90/
- GRAYLOG_HTTP_BIND_ADDRESS=0.0.0.0:9000
# Elastic Settings
- GRAYLOG_ELASTICSEARCH_HOSTS=https:/myElasticsearchService/
depends_on:
- mongo
networks:
- graylog_network
ports:
- 90:9000
# Syslog TCP
- 1514:1514
# Syslog UDP
- 1514:1514/udp
# GELF TCP
- 12201:12201
# GELF UDP
- 12201:12201/udp
# Volumes for persisting data, see https://docs.docker.com/engine/admin/volumes/volumes/
networks:
graylog_network:
external: true
