Hello all, wonder if anybody can help? I see a similar post here: https://github.com/Graylog2/graylog2-server/issues/3660 but that doesn’t seem to help. Running Graylog 2.4.3+2c41897 and the error I receive is: Loading user list failed with status: Error: cannot GET http://x.x.x.x:9000/api/users (500) and I can’t see to add users as a result.
Any pointers much appreciated, but note, I’m not a graylog guru
Hi, oddly the log locations don’t tally up and i can’t access them. /var/log/graylog and in there I have a server directory which i can’t access as i get permission denied. Nor can I access the elasticsearch, mongodb directories either.
got it now here’s what i see when i tail ‘current’ and try and open the authentication tab:
2018-07-11_14:49:33.07833 at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) ~[graylog.jar:?]
2018-07-11_14:49:33.07834 at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) ~[graylog.jar:?]
2018-07-11_14:49:33.07835 at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) ~[graylog.jar:?]
2018-07-11_14:49:33.07836 at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [graylog.jar:?]
2018-07-11_14:49:33.07836 at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [graylog.jar:?]
2018-07-11_14:49:33.07837 at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [graylog.jar:?]
2018-07-11_14:49:33.07838 at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [graylog.jar:?]
2018-07-11_14:49:33.07841 at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [graylog.jar:?]
2018-07-11_14:49:33.07841 at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [graylog.jar:?]
2018-07-11_14:49:33.07844 at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [graylog.jar:?]
2018-07-11_14:49:33.07845 at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [graylog.jar:?]
2018-07-11_14:49:33.07846 at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [graylog.jar:?]
2018-07-11_14:49:33.07847 at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.service(GrizzlyHttpContainer.java:384) [graylog.jar:?]
2018-07-11_14:49:33.07847 at org.glassfish.grizzly.http.server.HttpHandler$1.run(HttpHandler.java:224) [graylog.jar:?]
2018-07-11_14:49:33.07848 at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:176) [graylog.jar:?]
2018-07-11_14:49:33.07849 at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_161]
2018-07-11_14:49:33.07850 at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_161]
2018-07-11_14:49:33.07850 at java.lang.Thread.run(Thread.java:748) [?:1.8.0_161]
2018-07-11_14:51:50.93691 ERROR [AnyExceptionClassMapper] Unhandled exception in REST resource
2018-07-11_14:51:50.93695 java.lang.ClassCastException: com.mongodb.BasicDBObject cannot be cast to [B
2018-07-11_14:51:50.93696 at org.graylog2.security.MongoDbSession.getAttributes(MongoDbSession.java:68) ~[graylog.jar:?]
2018-07-11_14:51:50.93697 at org.graylog2.security.MongoDbSession.getUsernameAttribute(MongoDbSession.java:98) ~[graylog.jar:?]
2018-07-11_14:51:50.93698 at org.graylog2.rest.resources.users.UsersResource.lambda$listUsers$0(UsersResource.java:147) ~[graylog.jar:?]
2018-07-11_14:51:50.93699 at java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:174) ~[?:1.8.0_161]
2018-07-11_14:51:50.93700 at java.util.ArrayList$ArrayListSpliterator.forEachRemaining(ArrayList.java:1382) ~[?:1.8.0_161]
2018-07-11_14:51:50.93700 at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:481) ~[?:1.8.0_161]
2018-07-11_14:51:50.93701 at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:471) ~[?:1.8.0_161]
2018-07-11_14:51:50.93702 at java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:708) ~[?:1.8.0_161]
2018-07-11_14:51:50.93703 at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) ~[?:1.8.0_161]
2018-07-11_14:51:50.93704 at java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:499) ~[?:1.8.0_161]
2018-07-11_14:51:50.93707 at org.graylog2.rest.resources.users.UsersResource.listUsers(UsersResource.java:148) ~[graylog.jar:?]
2018-07-11_14:51:50.93707 at sun.reflect.GeneratedMethodAccessor738.invoke(Unknown Source) ~[?:?]
2018-07-11_14:51:50.93708 at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_16
