Hello. Newbie here. I was wondering if Graylog supports two way SSL (between the client sending the logs and the Graylog server/input) ?
Thank you.
Some inputs do support mutually authenticated and encrypted connections over TLS, some do not.
Hello. Thank you for your answer. Is it possible to be a bit more specific please?
Sure, if you have a specific question, we can give you a more specific answer.
