Trying to create an extractor, need help
I’m trying to create an extractor where each of the <> </> fields become a graylog field. I can’t figure out what type of extractor technique should be used to do this.
example:
The Federation Service validated a new credential. See XML for details.
Activity ID: 494a36f8-9b89-4477-8676-0080000000e1
Additional Data
XML: <?xml version="1.0" encoding="utf-16"?>
<AuditBase xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="FreshCredentialAudit">
  <AuditType>FreshCredentials</AuditType>
  <AuditResult>Success</AuditResult>
  <FailureType>None</FailureType>
  <ErrorCode>N/A</ErrorCode>
  <ContextComponents>
    <Component xsi:type="ResourceAuditComponent">
      <RelyingParty>https://xxxxxx.xxxxxxx.edu/adfs/services/trust</RelyingParty>
      <ClaimsProvider>AD AUTHORITY</ClaimsProvider>
      <UserId>UNIVERSITY\xxxxxxxxxxxxxx</UserId>
    </Component>
    <Component xsi:type="AuthNAuditComponent">
      <PrimaryAuth>N/A</PrimaryAuth>
      <DeviceAuth>false</DeviceAuth>
      <DeviceId>N/A</DeviceId>
      <MfaPerformed>false</MfaPerformed>
      <MfaMethod>N/A</MfaMethod>
      <TokenBindingProvidedId>false</TokenBindingProvidedId>
      <TokenBindingReferredId>false</TokenBindingReferredId>
      <SsoBindingValidationLevel>NotSet</SsoBindingValidationLevel>
    </Component>
    <Component xsi:type="ProtocolAuditComponent">
      <OAuthClientId>N/A</OAuthClientId>
      <OAuthGrant>N/A</OAuthGrant>
    </Component>
    <Component xsi:type="RequestAuditComponent">
      <Server>https://xxxxx.xxxxxx.edu/adfs/services/trust</Server>
      <AuthProtocol>WSFederation</AuthProtocol>
      <NetworkLocation>Intranet</NetworkLocation>
      <IpAddress>x.x.94.22</IpAddress>
      <ForwardedIpAddress>x.x.128.226</ForwardedIpAddress>
      <ProxyIpAddress>N/A</ProxyIpAddress>
      <NetworkIpAddress>N/A</NetworkIpAddress>
      <ProxyServer>N/A</ProxyServer>
      <UserAgentString>Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0</UserAgentString>
      <Endpoint>/adfs/ls/</Endpoint>
    </Component>
  </ContextComponents>
</AuditBase>
he @giveen
as Graylog does not have a native XML parser/extractor you would need to go the regex route to get the data out.
Is that coming from MS Servers/devices? Maybe you can ingest them via winlogbeat directly so you have them parsed and no need to go the route with hard parsable xml logs.
