Hello Graylog Community,
I’m currently running Graylog on an All-In-One setup and looking for advice on optimizing its performance. The Graylog server is handling logs from multiple sources, including syslog and various application logs. While it performs well under moderate load, I anticipate an increase in log volume and want to ensure the aio computer remains reliable and scalable.
Questions:
Configuration Tuning: What Graylog settings should I adjust to improve performance on an AIO computer?
Resource Allocation: What are the recommended allocations for internal buffers and processing threads?
Scalability Considerations: At what point should I consider moving to a multi-node setup?
Best Practices: Any tips or pitfalls to avoid when running Graylog on an AIO computer?
Any insights or experiences with similar setups would be greatly appreciated.
