WebUI code block: <strong aria-label="In 1,081 / Out 1,087 msg/s" class="GlobalThroughput__ContentWrap-eqhsdn-1 lnGbKl"><span class="GlobalThroughput__ThroughputData-eqhsdn-2 eIJxID"><span>1,081</span> <i>in</i></span><span class="GlobalThroughput__ThroughputData-eqhsdn-2 gAKfFQ"><span>1,087</span> <i>out</i></span></strong>
Does any1 else have the same?
Did I forget something in the upgrade process?
Search improvement in views ME LIKE
Let the testing in the product environment continue…
Sorry was trying to write problem details while working
GL now only shows the throughput values from ONE server in my cluster of FIVE.
So, the “correct” value is about five times what the GUI shows. (here approx. In 5,400 / Out 5,400 msg/s)
