System information is currently unavailable (NODE)
I’m getting logs coming into my Graylog instance, however at the top right of the page it’s showing 0 messages coming in even though new messages show up on a search. I have also clicked onto the top right 0 messages per second button to look into the nodes details and all I can see is this:
I then click onto the nodes name and get directed to this error page:
How can I fix this?
Edited:This is on Graylog version 2.1.3
G
What’s in the logs of your Graylog node?
:arrow_right: http://docs.graylog.org/en/2.2/pages/configuration/file_location.html
This is the most recent item in my server log files. Everything else works perfectly which doesn’t make much sense.
2017-07-03T13:48:12.843+01:00 WARN  [ProxiedResource] Unable to call
https:/my.graylog.url:9000/api/system/metrics/multiple on node <414f9e2d-4938-4d8d-b59a-bf73cff9c73c>
javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed:
sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
    at sun.security.ssl.Alerts.getSSLException(Alerts.java:192) ~[?:1.8.0_131]
    at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1949) ~[?:1.8.0_131]
    at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:302) ~[?:1.8.0_131]
    at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:296) ~[?:1.8.0_131]
    at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1514) ~[?:1.8.0_131]
    at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:216) ~[?:1.8.0_131]
    at sun.security.ssl.Handshaker.processLoop(Handshaker.java:1026) ~[?:1.8.0_131]
    at sun.security.ssl.Handshaker.process_record(Handshaker.java:961) ~[?:1.8.0_131]
    at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1062) ~[?:1.8.0_131]
    at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1375) ~[?:1.8.0_131]
    at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1403) ~[?:1.8.0_131]
    at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1387) ~[?:1.8.0_131]
    at okhttp3.internal.connection.RealConnection.connectTls(RealConnection.java:241) ~[graylog.jar:?]
    at okhttp3.internal.connection.RealConnection.establishProtocol(RealConnection.java:198) ~[graylog.jar:?]
    at okhttp3.internal.connection.RealConnection.buildConnection(RealConnection.java:174) ~[graylog.jar:?]
    at okhttp3.internal.connection.RealConnection.connect(RealConnection.java:114) ~[graylog.jar:?]
    at okhttp3.internal.connection.StreamAllocation.findConnection(StreamAllocation.java:193) ~[graylog.jar:?]
    at okhttp3.internal.connection.StreamAllocation.findHealthyConnection(StreamAllocation.java:129) ~[graylog.jar:?]
    at okhttp3.internal.connection.StreamAllocation.newStream(StreamAllocation.java:98) ~[graylog.jar:?]
    at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:42) ~[graylog.jar:?]
    at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:92) ~[graylog.jar:?]
    at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:67) ~[graylog.jar:?]
    at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.java:109) ~[graylog.jar:?]
    at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:124) ~
[graylog.jar:?]
    at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:170) ~[graylog.jar:?]
    at okhttp3.RealCall.execute(RealCall.java:60) ~[graylog.jar:?]
    at retrofit2.OkHttpCall.execute(OkHttpCall.java:174) ~[graylog.jar:?]
    at org.graylog2.shared.rest.resources.ProxiedResource.lambda$null$0(ProxiedResource.java:76) ~[graylog.jar:?]
    at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_131]
    at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:1.8.0_131]
    at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:1.8.0_131]
    at java.lang.Thread.run(Thread.java:748) [?:1.8.0_131]
Caused by: sun.security.validator.ValidatorException: PKIX path building failed:
    at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:387) ~[?:1.8.0_131]
    at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:292) ~[?:1.8.0_131]
    at sun.security.validator.Validator.validate(Validator.java:260) ~[?:1.8.0_131]
    at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:324) ~[?:1.8.0_131]
    at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:229) ~[?:1.8.0_131]
    at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:124) ~[?:1.8.0_131]
    at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1496) ~[?:1.8.0_131]
    ... 36 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to
requested target
    at sun.security.provider.certpath.SunCertPathBuilder.build(SunCertPathBuilder.java:141) ~[?:1.8.0_131]
    at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:126) ~[?:1.8.0_131]
    at java.security.cert.CertPathBuilder.build(CertPathBuilder.java:280) ~[?:1.8.0_131]
    at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:382) ~[?:1.8.0_131]
Thankyou in advance
G
2017-07-03T14:51:19.590+01:00 WARN  [ProxiedResource] Unable to call
https://my.graylog.url:9000/api/system/metrics/multiple on node <414f9e2d-4938-4d8d-b59a-bf73cff9c73c>
These logs just came through.
G
Is my.graylog.url the Common Name (CN) used in your certificates?
Are your certificates self-signed or did you buy some from a well-known CA which is already part of the default JVM trust store on your systems?
We use Let’s Encrypt for our CA, I haven’t looked into this much as another member of the team has done all the work on this.
Could you point me in the direction of these CA’s then I will be able to provide more info.
Cheers,
G
@GTownson
you should ask your co-worker how he had setup the SSL/Cert.
He’s extremely bust at the minute, and also out of the office for a short while. I can ask when he returns.
G
My co-worker was able to look into it last night and he managed to sort it out, it was just a case off adding the Let’s Encrypt root CA to the trustfile.
Thankyou for you help.
G
