Graylog HTTPS signature check failed
Hi All,
I am trying to setup the SSL/TLS in graylog by using the following documentation but however i am getting the following error response and I am unable to proceed further.
2017-10-31T12:07:42.380Z WARN  [ProxiedResource] Unable to call https://130.211.227.109:9000/api/system/metrics/multiple on node <9d796bc5-acf0-4383-a933-0d377cbd7edc>
javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path validation failed: java.security.cert.CertPathValidatorException: signature check fai
led
        at sun.security.ssl.Alerts.getSSLException(Alerts.java:192) ~[?:1.8.0_131]
        at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1949) ~[?:1.8.0_131]
        at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:302) ~[?:1.8.0_131]
        at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:296) ~[?:1.8.0_131]
        at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1514) ~[?:1.8.0_131]
        at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:216) ~[?:1.8.0_131]
        at sun.security.ssl.Handshaker.processLoop(Handshaker.java:1026) ~[?:1.8.0_131]
        at sun.security.ssl.Handshaker.process_record(Handshaker.java:961) ~[?:1.8.0_131]
        at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1062) ~[?:1.8.0_131]
        at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1375) ~[?:1.8.0_131]
        at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1403) ~[?:1.8.0_131]
        at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1387) ~[?:1.8.0_131]
        at okhttp3.internal.connection.RealConnection.connectTls(RealConnection.java:242) ~[graylog.jar:?]
        at okhttp3.internal.connection.RealConnection.establishProtocol(RealConnection.java:200) ~[graylog.jar:?]
        at okhttp3.internal.connection.RealConnection.buildConnection(RealConnection.java:174) ~[graylog.jar:?]
        at okhttp3.internal.connection.RealConnection.connect(RealConnection.java:114) ~[graylog.jar:?]
        at okhttp3.internal.connection.StreamAllocation.findConnection(StreamAllocation.java:196) ~[graylog.jar:?]
        at okhttp3.internal.connection.StreamAllocation.findHealthyConnection(StreamAllocation.java:132) ~[graylog.jar:?]
        at okhttp3.internal.connection.StreamAllocation.newStream(StreamAllocation.java:101) ~[graylog.jar:?]
        at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:42) ~[graylog.jar:?]
        at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:92) ~[graylog.jar:?]
        at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:67) ~[graylog.jar:?]
        at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:120) ~[graylog.jar:?]
        at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:179) ~[graylog.jar:?]
Caused by: sun.security.validator.ValidatorException: PKIX path validation failed: java.security.cert.CertPathValidatorException: signature check failed
        at sun.security.validator.PKIXValidator.doValidate(PKIXValidator.java:352) ~[?:1.8.0_131]
        at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:260) ~[?:1.8.0_131]
        at sun.security.validator.Validator.validate(Validator.java:260) ~[?:1.8.0_131]
        at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:324) ~[?:1.8.0_131]
        at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:229) ~[?:1.8.0_131]
        at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:124) ~[?:1.8.0_131]
        at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1496) ~[?:1.8.0_131]
I am using Ubuntu 14.04 + Graylog 2.3 + Elasticsearch 5.x version and I have added the self signed certificate (cert.pem) to the keystore and I used the below command to verified that certificate is added.
jaikumarvin@graylogvm-1:~$ keytool -keystore /etc/graylog/cacerts.jks -storepass changeme -list | grep 130.211.227.109 -A1
130.211.227.109, Oct 31, 2017, trustedCertEntry,
Certificate fingerprint (SHA1): 21:D2:95:9A:5D:1B:F4:F5:2D:0A:C0:D3:94:4C:07:51:FA:D4:AE:F4
and further I have added the new JVM truststore in the Graylog JAVAOPTS variable in the location (/etc/default/graylog-server)
Please correct me if I am doing anything wrong and share your thoughts.
Regards,
Jayakumar
Hej @jaikumarkrishna
looks like your format is not the one Graylog expects … you might want to use this script to create your certificates in the correct format.
