Hey,
we’re using graylog docker image 2.2.2 / 2.2.3 (both tested) with installed collector plugin. (.jar file placed in the plugin directory). The plugin seems to work, because on the client side (collector sidecar), i get the log message “msg=”[RequestConfiguration] No configuration found for configured tags!""
But the main Problem is, that i can not see “Collectors” option under “System” in the WebUi.
We’re using docker version 17.03.0-ce on Debian Jessie.
30.4.2017 17:18:152017-04-30 15:18:15,025 INFO : org.graylog2.bootstrap.ServerBootstrap - Graylog server up and running.
30.4.2017 17:18:152017-04-30 15:18:15,050 INFO : org.graylog2.inputs.InputStateListener - Input [GELF TCP/5903028415f6cd000135c628] is now STARTING
30.4.2017 17:18:152017-04-30 15:18:15,051 INFO : org.graylog2.inputs.InputStateListener - Input [GELF UDP/5903098215f6cd000135cef3] is now STARTING
30.4.2017 17:18:152017-04-30 15:18:15,054 INFO : org.graylog2.inputs.InputStateListener - Input [Beats/5905f9f6e10b3f00016a0c4c] is now STARTING
30.4.2017 17:18:152017-04-30 15:18:15,098 WARN : org.graylog2.plugin.inputs.transports.NettyTransport - receiveBufferSize (SO_RCVBUF) for input BeatsInput{title=beats-input, type=org.graylog.plugins.beats.BeatsInput, nodeId=null} should be 1048576 but is 212992.
30.4.2017 17:18:152017-04-30 15:18:15,098 WARN : org.graylog2.plugin.inputs.transports.NettyTransport - receiveBufferSize (SO_RCVBUF) for input GELFTCPInput{title=GELP INPUT, type=org.graylog2.inputs.gelf.tcp.GELFTCPInput, nodeId=e7660f5c-4a80-4cd2-85ad-a284f35c4f38} should be 1048576 but is 212992.
30.4.2017 17:18:152017-04-30 15:18:15,101 INFO : org.graylog2.inputs.InputStateListener - Input [Beats/5905f9f6e10b3f00016a0c4c] is now RUNNING
30.4.2017 17:18:152017-04-30 15:18:15,103 INFO : org.graylog2.inputs.InputStateListener - Input [GELF TCP/5903028415f6cd000135c628] is now RUNNING
30.4.2017 17:18:152017-04-30 15:18:15,110 WARN : org.graylog2.plugin.inputs.transports.NettyTransport - receiveBufferSize (SO_RCVBUF) for input GELFUDPInput{title=GELP INPUT UDP, type=org.graylog2.inputs.gelf.udp.GELFUDPInput, nodeId=null} should be 262144 but is 212992.
30.4.2017 17:18:152017-04-30 15:18:15,113 INFO : org.graylog2.inputs.InputStateListener - Input [GELF UDP/5903098215f6cd000135cef3] is now RUNNING
30.4.2017 17:18:272017-04-30 15:18:27,961 INFO : org.apache.shiro.session.mgt.AbstractValidatingSessionManager - Enabling session validation scheduler...
30.4.2017 17:23:272017-04-30 15:23:27,962 INFO : org.apache.shiro.session.mgt.AbstractValidatingSessionManager - Validating all active sessions...
30.4.2017 17:23:272017-04-30 15:23:27,971 INFO : org.apache.shiro.session.mgt.AbstractValidatingSessionManager - Finished session validation. [1] sessions were stopped.
30.4.2017 17:26:372017-04-30 15:26:37,711 INFO : org.graylog2.inputs.InputStateListener - Input [Beats/5905f9f6e10b3f00016a0c4c] is now STOPPING
30.4.2017 17:26:372017-04-30 15:26:37,711 INFO : org.mongodb.driver.connection - Opened connection [connectionId{localValue:10, serverValue:72}] to mongo:27017
30.4.2017 17:26:372017-04-30 15:26:37,731 INFO : org.graylog2.inputs.InputStateListener - Input [Beats/5905f9f6e10b3f00016a0c4c] is now STOPPED
30.4.2017 17:26:372017-04-30 15:26:37,732 INFO : org.graylog2.inputs.InputStateListener - Input [Beats/5905f9f6e10b3f00016a0c4c] is now TERMINATED
30.4.2017 17:26:372017-04-30 15:26:37,733 INFO : org.graylog2.inputs.InputStateListener - Input [Beats/5905f9f6e10b3f00016a0c4c] is now STARTING
30.4.2017 17:26:372017-04-30 15:26:37,741 WARN : org.graylog2.plugin.inputs.transports.NettyTransport - receiveBufferSize (SO_RCVBUF) for input BeatsInput{title=beats-input, type=org.graylog.plugins.beats.BeatsInput, nodeId=null} should be 1048576 but is 212992.
30.4.2017 17:26:372017-04-30 15:26:37,743 INFO : org.graylog2.inputs.InputStateListener - Input [Beats/5905f9f6e10b3f00016a0c4c] is now RUNNING
30.4.2017 17:28:272017-04-30 15:28:27,962 INFO : org.apache.shiro.session.mgt.AbstractValidatingSessionManager - Validating all active sessions...
30.4.2017 17:28:272017-04-30 15:28:27,965 INFO : org.apache.shiro.session.mgt.AbstractValidatingSessionManager - Finished session validation. No sessions were stopped.
30.4.2017 17:33:272017-04-30 15:33:27,962 INFO : org.apache.shiro.session.mgt.AbstractValidatingSessionManager - Validating all active sessions...
30.4.2017 17:33:272017-04-30 15:33:27,968 INFO : org.apache.shiro.session.mgt.AbstractValidatingSessionManager - Finished session validation. [1] sessions were stopped.
30.4.2017 17:38:272017-04-30 15:38:27,962 INFO : org.apache.shiro.session.mgt.AbstractValidatingSessionManager - Validating all active sessions...
30.4.2017 17:38:272017-04-30 15:38:27,965 INFO : org.apache.shiro.session.mgt.AbstractValidatingSessionManager - Finished session validation. No sessions were stopped.
30.4.2017 17:39:072017-04-30 15:39:07,991 INFO : org.graylog2.commands.Server - SIGNAL received. Shutting down.
30.4.2017 17:39:072017-04-30 15:39:07,993 INFO : org.graylog2.system.shutdown.GracefulShutdown - Graceful shutdown initiated.
30.4.2017 17:39:072017-04-30 15:39:07,995 INFO : org.graylog2.system.shutdown.GracefulShutdown - Node status: [Halting [LB:DEAD]]. Waiting <3sec> for possible load balancers to recognize state change.
30.4.2017 17:39:202017-04-30 15:39:20,321 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: Elastic Beats Input 2.2.2 [org.graylog.plugins.beats.BeatsInputPlugin]
30.4.2017 17:39:202017-04-30 15:39:20,324 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: Collector 2.2.2 [org.graylog.plugins.collector.CollectorPlugin]
30.4.2017 17:39:202017-04-30 15:39:20,599 INFO : org.graylog2.bootstrap.CmdLineTool - Running with JVM arguments: -Xms1g -Xmx2g -XX:NewRatio=1 -XX:MaxMetaspaceSize=256m -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:+UseParNewGC -XX:-OmitStackTraceInFastThrow -Dlog4j.configurationFile=/usr/share/graylog/data/config/log4j2.xml -Djava.library.path=/usr/share/graylog/lib/sigar/ -Dgraylog2.installation_source=docker
can anyone help? any idea whats happened?
