Hi.
The “Collectors” option is not displayed within the “System” menu of the Graylog web interface. The collector-sidecar plugin is inside the default plug-in directory defined in the server.conf file. (/usr/share/graylog-server/plugin/)
I’ve tried restarting graylog-server and sidecar collector services, but the “Collectors” option still does not appear.
I noticed that the problem may be related to the fact that Graylog does not install the downloaded plugins in the default directory.
I am with version 2.2.1 installed which is the same version of the plugins that exist in the default directory. My server is a virtual machine running Ubuntu 16.04.
I wonder if there is a way to fix this problem, or if there is any graylog-server configuration that can be done so that you can use the collector-sidecar on the web interface.
Greetings and excuse my spelling errors.
