Syslog without timestamp
I have two types of switches sending logs to my Graylog version 6.0 server, they are DM2104 and DM4370.
I tested with tcpdump and I receive logs from both on the server, but Graylog cannot process the DM2104 logs.
When comparing the equipment logs, I identified that the DM2104 does not send the timestamp, is there any way to get around this?
DM2104:
15:30:39.018909 IP (tos 0x0, ttl 58, id 0, offset 0, flags [DF], proto UDP (17), length 83)
10.183.255.30.syslog > 10.211.0.97.syslog: [udp sum ok] SYSLOG, length: 55
Facility local0 (16), Severity notice (5)
Msg: : <5> User **** authenticated by tacacs^J
DM4370:
15:34:04.559373 IP (tos 0x0, ttl 58, id 26613, offset 0, flags [DF], proto UDP (17), length 209)
10.183.255.21.49040 > 10.211.0.97.syslog: [udp sum ok] SYSLOG, length: 181
Facility local0 (16), Severity info (6)
Msg: Oct 21 15:34:04 RIOS-ANEL2-2023470641 : 1/1 : %AAA-REMOTE_AUTHENTICATION_SUCCESS : authenticator-app[6775] : User [****]: User authenticated by Tacacs server.^J
Error in /var/log/graylog-server/server.log:
ERROR [DecodingProcessor] Unable to decode raw message RawMessage{id=ad331910-8fe3-11ef-949c-bc2411f03e5a, messageQueueId=360977, codec=syslog, payloadSize=83, timestamp=2024-10-21T19:35:49.793Z, seqenceNr=108, remoteAddress=/10.183.255.30:514} on input <670427a812e6655b1e346bc1>.
Difficult one, could be on the UDP level, is it possible to switch to SYSLOG TCP?
Other options: Increase the Receive Buffer Size on the input.
Graylog is able parse RFC 5424 and RFC 3164 compliant syslog messages.
Your messages dont look like RFC5424 neither RFC3164 for me.
I would recommend to deliver it via a RAW input and then normalize it manually with rules and pipelines or adjust your log message to the RFC for syslog
Syslog Inputs
