I wanted to upgrade form 5.2.4 ti 6.0 but it failed. Reason was no syslog-output plugin. In 6.0 there is no longer provided syslog-output plugin.
So I found plugin on github, but have problems building it.
OS Information: Oracle Linux 8.7
Package Version: graylog RPM package 6.x
Downloaded from github plugin, it says it supports 6.0:
GitHub - wizecore/graylog2-output-syslog: Customizable, production ready syslog and ArcSight output plugin for Graylog
created maven envirnment on linux
downloaded jdk 17
But I have several problems when building that with command $ mvn package, latest error is :
T E S T S
Running com.wizecore.graylog2.plugin.test.TestFullSender
Tests run: 2, Failures: 1, Errors: 1, Skipped: 0, Time elapsed: 0.107 sec <<< FAILURE!
testMessageTruncation(com.wizecore.graylog2.plugin.test.TestFullSender) Time elapsed: 0.073 sec <<< ERROR!
java.lang.NoClassDefFoundError: com/swrve/ratelimitedlogger/RateLimitedLog
at org.graylog2.plugin.utilities.ratelimitedlog.RateLimitedLogFactory.createRateLimitedLog(RateLimitedLogFactory.java:31)
at org.graylog2.plugin.Message.(Message.java:89)´
Anybody solved similar problems when building plugin with maven ?
