Supported Elasticsearch Field Types
Hi all,
I found an old thread from 2018 here, which was not answered:
I tried to use field type “ip” in a GROK rule, but got the error message “not supported”. We use ES 6.8.6 on our ES cluster members.
According to this page (IP datatype | Elasticsearch Guide [6.8] | Elastic), the type “ip” is nothing special.
Do you have an overview which datatypes are supported in GL? A hint with the GitHub source would be enough for me.
Best,
Sascha
EDIT:
Found this: https://github.com/Graylog2/graylog2-server/blob/master/graylog2-web-interface/src/views/logic/fieldtypes/FieldType.js
The type “ip” is there:
IP: createType('ip', [Properties.Enumerable]),
Now I’m even more confused…
Hi @shenke,
What do you mean by:
Can you give an example for that? Because GROK does not support the type IP.
I wanted to change the field %{Client_IP:src_ip} to %{Client_IP:src_ip;ip} which did not work.
This is the full extractor:
%{HTTP_PROXY_DATE}%{PROXY}%{Client_IP:src_ip}%{SPACE:UNWANTED}%{HTTP_METHOD:http_method}%{SPACE:UNWANTED}%{HTTP_Host}%{URI_PARAM}%{SPACE:UNWANTED}%{HTTP_VERSION}%{USER_AGENT}
Hello @shenke,
GROK does not know a type IP and does not know of the elasticsearch field types.
GROK only knows int, float, string and perhaps boolean but I could not find anything about that.
As far as I know, sending a string to elastic search should be enough and elastic search will map it as IP if you configured it that way.
Hmkay, I’ll try it that way. Thank you!
I just read again what I wrote and I want to make my self clear. It should be enough to do no type casting in the Grok Pattern at all.
Hope this helps! Let me know if I can be of any further help.
Best regards,
Konrad
