Hi, I’m seeing some discrepency between the data field type I set in my grok extractor, compared to how the index gets created in elasticsearch. I do not have any custom mappings for this entire index.
When I set “int” as the field data type in my grok extractor, that appears to be ignored, and the index field type gets created as “long”. In another case (not the extractor below) I set it to int, and the elasticsearch index was created as type “keyword” (yes I rotated the index after making changes).
My question is, if I use one of the field types listed in this doc, how does that relate to how the index field types are configured in elasticsearch? It seems like there is a “loose” correlation, but not a strict one. The “float” data type seems to be passed through from grok extractor to elasticsearch index.
I know I can configure a custom mapping, but I’d prefer to use those as little as possible, and instead put the data type in the grok so my users can create groks without my assistance making changes directly to elasticsearch.
Here is the grok extractor in question. The problematic fields with inconsistency in this case are “mysql_rows_sent, and mysql_rows_examined”.
^# User@Host: %{NOTSPACE:mysql_user} @ %{HOSTNAME:mysql_hostname}%{GREEDYDATA}\n# Query_time: %{BASE16FLOAT:mysql_query_time;float}\s+Lock_time: %{BASE16FLOAT:mysql_lock_time;float}\s+Rows_sent: %{BASE10NUM:mysql_rows_sent;int}\s+Rows_examined:\s+%{BASE10NUM:mysql_rows_examined;int}\nSET timestamp=%{BASE10NUM:timestamp};\n%{GREEDYDATA:mysql_query;string}
05/16 17:45[root@admin3]# curl -XGET localhost:9200/graylog_19/_mapping/field/mysql_*?pretty
"graylog_19" : {
"mappings" : {
"message" : {
"mysql_lock_time" : {
"full_name" : "mysql_lock_time",
"mapping" : {
"type" : "float"
"mysql_query_time" : {
"full_name" : "mysql_query_time",
"mapping" : {
"type" : "float"
"mysql_rows_sent" : {
"full_name" : "mysql_rows_sent",
"mapping" : {
"type" : "long"
"mysql_rows_examined" : {
"full_name" : "mysql_rows_examined",
"mapping" : {
"type" : "long"
"mysql_user" : {
"full_name" : "mysql_user",
"mapping" : {
"mysql_user" : {
"type" : "keyword"
"mysql_query" : {
"full_name" : "mysql_query",
"mapping" : {
"mysql_query" : {
"type" : "keyword"
"mysql_hostname" : {
"full_name" : "mysql_hostname",
"mapping" : {
"type" : "keyword"
