Stream x not found
I got a list of my stream ids which matches with the explanation given here:
But i still get a stream not found error. I tested an admin account to evade possible permission problems.
API calls in question:
/streams/my-streamid/alerts/check
Do i need to add something to the stream ID? special formatting?
Please explain more in detail what you want to achive? Which graylog version do you use? You want to use Rest API or something different?
My mistake, streams and inputs are not the same, I used input ids.
