how do I implement ssl certificate for web front-end.
I have a single server and a valid ca certificate.
Please refer to http://docs.graylog.org/en/2.2/pages/configuration/https.html for setup instructions.
I already tried mentioned steps.
Do I need to import ssl certificate to java store?
# The X.509 certificate chain file in PEM format to use for securing the web interface.
web_tls_cert_file = /path/to/graylog-certificate.pem
# The PKCS#8 private key file in PEM format to use for securing the web interface.
web_tls_key_file = /path/to/graylog-key.pem
# The password to unlock the private key used for securing the web interface.
web_tls_key_password = secret
Above doesn’t exist in my graylog configuration file.
Which version of Graylog are you using?
I am running with graylog appliance - 2.2.3+7adc951, codename Stiegl
Please refer to the appropriate documentation: http://docs.graylog.org/en/2.2/pages/configuration/graylog_ctl.html#install-custom-ssl-certificates
followed the steps as per article and ran command sudo graylog-ctl enforce-ssl however still no luck.
Running on http only…
Now finally I could make it work. As per document shared by jochen, have to copy ssl certificate to
/opt/graylog/conf/nginx/ca
Run graylog-ctl enforce-ssl and finally run graylog-ctl reconfigure
And… now it works on https…
