I had to revert, so this is from memory. I’m sure others may have already reported these, but if not:
I use graylog behind a proxy. Everything is working except the stream links from the menu. They are redirecting to the wrong place, and I get the 404 gorilla. Everything is fine if I access the backend directly.
For dashboards, I have some stacked columns. The problem is that in addition to the aggregates that I want, graylog is also adding all values combined as another data set.
I liked the ability to ‘play’ a widget’s query search. Is this hopefully coming back? I feel the workflow now is tedious and frustrating.
I look forward to using the new version when these things are addressed.
There might be an issue with your graylog config. Please have a look at this config section:
#### External Graylog URI
# Default: $http_publish_uri
#http_external_uri =
We did not implement it for this version but will bring something like this back for 3.3 which should be released hopefully in summer. In the mean time have a look at Show documents for value in the value actions.
