Hello.
I’m having an issue with the login on the webapp at port 9000. While using the admin login and password and clicking on “signin in”, nothing happens.
OS Information: Rocky Linux 9.5 / Debian 12
Package Version: Graylog 6.1 / MongoDB 6.0.14 / Wazuh.indexer 4.11.2 (Elasticsearch:7.10.2)
Graylog logs :
graylog | 2025-04-04 09:04:06,233 INFO : org.graylog2.bootstrap.ServerBootstrap - Graylog server 6.0.6+4aa664f starting up
graylog | 2025-04-04 09:04:06,234 INFO : org.graylog2.bootstrap.ServerBootstrap - JRE: Eclipse Adoptium 17.0.12 on Linux 5.14.0-503.34.1.el9_5.x86_64
graylog | 2025-04-04 09:04:06,234 INFO : org.graylog2.bootstrap.ServerBootstrap - Deployment: docker
graylog | 2025-04-04 09:04:06,235 INFO : org.graylog2.bootstrap.ServerBootstrap - OS: Ubuntu 22.04.4 LTS (jammy)
graylog | 2025-04-04 09:04:06,235 INFO : org.graylog2.bootstrap.ServerBootstrap - Arch: amd64
graylog | 2025-04-04 09:04:06,236 INFO : org.graylog2.bootstrap.ServerBootstrap - Node ID: 4c9a40f3-5b92-483e-8d27-eba197c4d4ba
graylog | 2025-04-04 09:04:06,319 INFO : org.graylog2.bootstrap.ServerBootstrap - Running 67 migrations...
graylog | 2025-04-04 09:04:08,055 INFO : org.graylog2.shared.initializers.PeriodicalsService - Starting 25 periodicals ...
graylog | 2025-04-04 09:04:08,057 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.ThroughputCalculator] periodical in [0s], polling every [1s].
graylog | 2025-04-04 09:04:08,069 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog.plugins.pipelineprocessor.periodical.LegacyDefaultStreamMigration] periodical, running forever.
graylog | 2025-04-04 09:04:08,078 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.ClusterHealthCheckThread] periodical in [120s], polling every [20s].
graylog | 2025-04-04 09:04:08,101 INFO : org.graylog2.shared.initializers.PeriodicalsService - Not starting [org.graylog2.periodical.ContentPackLoaderPeriodical] periodical. Not configured to run on this node.
graylog | 2025-04-04 09:04:08,102 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.IndexerClusterCheckerThread] periodical in [5s], polling every [30s].
graylog | 2025-04-04 09:04:08,103 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.IndexBlockCheck] periodical in [0s], polling every [30s].
graylog | 2025-04-04 09:04:08,104 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.IndexRetentionThread] periodical in [0s], polling every [300s].
graylog | 2025-04-04 09:04:08,105 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.IndexRotationThread] periodical in [0s], polling every [10s].
graylog | 2025-04-04 09:04:08,111 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.NodePingThread] periodical in [0s], polling every [1s].
graylog | 2025-04-04 09:04:08,142 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.LeaderPresenceCheckPeriodical] periodical in [0s], polling every [5s].
graylog | 2025-04-04 09:04:08,156 INFO : org.graylog.plugins.pipelineprocessor.periodical.LegacyDefaultStreamMigration - Legacy default stream has no connections, no migration needed.
graylog | 2025-04-04 09:04:08,224 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.VersionCheckThread] periodical in [300s], polling every [1800s].
graylog | 2025-04-04 09:04:08,239 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.ThrottleStateUpdaterThread] periodical in [1s], polling every [1s].
graylog | 2025-04-04 09:04:08,242 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.events.ClusterEventPeriodical] periodical in [0s], polling every [1s].
graylog | 2025-04-04 09:04:08,245 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.events.ClusterEventCleanupPeriodical] periodical in [0s], polling every [86400s].
graylog | 2025-04-04 09:04:08,253 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.IndexRangesCleanupPeriodical] periodical in [15s], polling every [3600s].
graylog | 2025-04-04 09:04:08,255 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.TrafficCounterCalculator] periodical in [0s], polling every [1s].
graylog | 2025-04-04 09:04:08,256 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical] periodical in [0s], polling every [1s].
graylog | 2025-04-04 09:04:08,269 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog.scheduler.periodicals.ScheduleTriggerCleanUp] periodical in [120s], polling every [86400s].
graylog | 2025-04-04 09:04:08,270 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.ESVersionCheckPeriodical] periodical in [0s], polling every [30s].
graylog | 2025-04-04 09:04:08,273 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.UserSessionTerminationPeriodical] periodical, running forever.
graylog | 2025-04-04 09:04:08,281 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.telemetry.cluster.TelemetryClusterInfoPeriodical] periodical in [0s], polling every [540s].
graylog | 2025-04-04 09:04:08,282 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.bootstrap.preflight.GraylogCertificateProvisioningPeriodical] periodical in [2s], polling every [2s].
graylog | 2025-04-04 09:04:08,282 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog.plugins.sidecar.periodical.PurgeExpiredSidecarsThread] periodical in [0s], polling every [600s].
graylog | 2025-04-04 09:04:08,283 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog.plugins.views.search.db.SearchesCleanUpJob] periodical in [3600s], polling every [28800s].
graylog | 2025-04-04 09:04:08,304 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog.events.periodicals.EventNotificationStatusCleanUp] periodical in [120s], polling every [86400s].
graylog | 2025-04-04 09:04:10,831 INFO : org.glassfish.grizzly.http.server.NetworkListener - Started listener bound to [0.0.0.0:9000]
graylog | 2025-04-04 09:04:10,833 INFO : org.glassfish.grizzly.http.server.HttpServer - [HttpServer] Started.
graylog | 2025-04-04 09:04:10,834 INFO : org.graylog2.shared.initializers.JerseyService - Started REST API at <0.0.0.0:9000>
graylog | 2025-04-04 09:04:10,834 INFO : org.graylog2.shared.initializers.ServiceManagerListener - Services are healthy
graylog | 2025-04-04 09:04:10,836 INFO : org.graylog2.shared.initializers.InputSetupService - Triggering launching persisted inputs, node transitioned from Uninitialized [LB:DEAD] to Running [LB:ALIVE]
graylog | 2025-04-04 09:04:10,837 INFO : org.graylog2.bootstrap.ServerBootstrap - Services started, startup times in ms: {GracefulShutdownService [RUNNING]=0, LocalKafkaMessageQueueReader [RUNNING]=0, InputSetupService [RUNNING]=1, UserSessionTerminationService [RUNNING]=1, FailureHandlingService [RUNNING]=2, NotificationSystemEventPublisher [RUNNING]=3, BufferSynchronizerService [RUNNING]=3, UrlWhitelistService [RUNNING]=7, PrometheusExporter [RUNNING]=7, LocalKafkaMessageQueueWriter [RUNNING]=9, EtagService [RUNNING]=9, JobSchedulerService [RUNNING]=13, LocalKafkaJournal [RUNNING]=17, GeoIpDbFileChangeMonitorService [RUNNING]=18, ConfigureCertRenewalJobOnStartupService [RUNNING]=20, OutputSetupService [RUNNING]=24, LookupTableService [RUNNING]=26, StreamCacheService [RUNNING]=51, MongoDBProcessingStatusRecorderService [RUNNING]=170, PeriodicalsService [RUNNING]=252, JerseyService [RUNNING]=2780}
graylog | 2025-04-04 09:04:10,844 INFO : org.graylog2.bootstrap.ServerBootstrap - Graylog server up and running.
Configs from graylog.conf :
elasticsearch_hosts = https://admin:***********@wazuh.indexer:9200
password_secret and root_password_sha2 where modified with the correct procedure.
Other :
No logs from the other services. When i inspect the web interface, no network traffic is seen after clicking on signin in.
I previously had issues with compatibility.override_main_response_version: true, that i had to enable in the .yml file.
- Downgrading the graylog, wazuh.indexer and mongodb versions.
- Changing OS.
- Modifying the password_secret.
